Author Topic: clickclack's custom keycaps =)  (Read 222383 times)
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« on: Wed, 07 April 2010, 20:45:45 »
Image heavy page! Images are kept small to ease loading issues, thank you for your patience =)
Clack Factory keys have arrived!!!
As of December 2, 2010
Available through EliteKeyboards.com!!!! =)
This first limited quantity will help determine how I/we will proceed.
The collaboration with Elitekeyboards has not only brought about higher quality keys, it has also been an integral part
in expanding possibilites and making them realized. I am excited to see how this goes, and if well,
the word "awesome" will be given new meaning ;)
THE ARMY HAS ARRIVED!!!
From left to right
-Topre/HHKB compatible tri-colored skulls (equivalent to 3-shot)
-Cherry switch compatible Red, EK Yellow, and EK Blue
-Cherry switch compatible tri-colored skulls (equivalent to 3-shot)
I also plan on offering keys on ClackFactory.com through FXESC.com (both under construction atm) in order to cater to
a yet wider range of keyboards and styles.
For the moment though I am "testing the waters" and calculating different processes.
I want to thank everyone for the support, interest, and guidance!
I appreciate it more than I could possibly aknowledge in written form =)
I would also like to give a special thanks to iMav (our fearless leader) for the above reasons and for the
confidence that was very much needed.
-clickclack =)
FAQ being updated at the bottom of this first post!
Hi everyone =)
I am posting some new prototypes as well as some ideas. A brief description will follow the pictures and I will continually
be uploading new prototypes and limited production runs.
Please feel free to ask questions as well as reference the FAQ at the bottom of this page.
 [strike]I am currently reconfiguring my equipment to enable a more consistent process.[/strike]
Enjoy =)
First up...
1) This keycap is dual molded or double molded (dual shot refers to a different process for the same result).
The thickness of the white plastic is the depth of the skull itself. When I have the GeekHack prototype out and ready
I will be trying to do an orange and charcoal version first =)
2) These three are gunmetal metallic bonded plastic. This is different than plating, it can be as thick
or as thin as plating but it is not "on top" of the keycap, it's in the actual plastic. I have not finished the plated ones
yet but I intend to soon (well... soon-ish). I have a bit more creative possibilities with bonding at the moment (many, many more colors, textures and designs). Taken under diffused lighting.
3) This is another example of the bonded metallic keycaps. The top three keycaps are metallic silver bonded
in different ways and places. The bottom keycap is metallic gunmetal but with a bolder application. These are the ultra lowprofile (flat-ish) skulls btw.
4) This is a low profile skull for model M styled key switches. This one is only the cap, I have not finished the prototype
for the full stem one. I also have prototypes of M keys with the original skull, as well as other larger keys.
5) Model M compatible key caps in the gunmetal metallic bonded style mentioned earlier. These are also in the low profile skull design. These are taken under more direct lighting giving them a more metallic POP!
6) Another M keycap but this one was detailed with silver teeth, gunmetal skull and gold metalic tooth. A kind of ghetto pirate look =D  aaarrrrrr!
7) This model M keycap was dual molded in black and red for that cute menacing look, haahaa =)
8) Here are some prototype blank keys (some are in the wrong place), I figured I needed to throw up some color in this post! These are just some random colors that I had been testing, it has little relation to what I will be doing as standard or what I can do. Btw the white one in this picture is not bright white, it's a warm eggshell.
9) And for those who want that extra stealthy menacing look, here is a black original skull.
10) This is an aluminum keycap that I cast a long time ago, it's sandblasted with a heavy ruby aggregate. I am debating if I should/could sell these, in very, very limited numbers. I will give specs when I find notes for it.
11) I figured I would throw this pic up after ripsters post =)
12) This is another original skull keycap in a wicked chartreuse 8)
13) This is an early prototype (when they were still very thin) and you can see how easily the TG3's LED's light them up. It's a red keycap and the brightness of the LED's was on the lower side in this pic (though not on the lowest setting).
14) This is another pic with the LED's on a brighter setting, same red keycap. (not on the highest setting). The new prototypes (for illuminated boards) will be either thinner in eyes or will be dual molded in a translucent red in the eyes.
15) This is also one of the original "thin" prototypes in white. This just illustrates how easily light penetrates the keycap in a lighter color. The keycap is backlit indirectly from a desklamp.
16) Same white original "thin" keycap backlit (lower setting) on a TG3.
17) This is a dual molded "SPLAT" design (other colors and combinations possible) for those "take no prisioner" gamers =P. I actually really, really like these keys and have been typing on them for quite a while now. I think a black keyboard and keys with multiple colors would be like a Jackson Pollock experience! Haahaa, seriously though they look really great =D
18) By popular demand here are some more examples of the Dual molded "SPLAT" keys. If you notice on the left hand side of both pictures I tried to emulate the charcoal base color keys on the HHKB and came pretty close. I am just a bit on the light and cool side though. I should be able to get reasonably spot on with more tests.
19) The two photos above are dual molded skulls (original style) but with red eyes.
20) This is another dual molded skull but this one is the flat profile skull design.
21) This photo is to illustrate the contrast of a few previously shown keys.
22) This is a dual molded black and white MX compatible keycap.
23) This is a dual molded white and red MX compatible skull keycap and will also be the prototype for the illuminated board keys. So the eyes will still be illuminated red even if the backlight happenes to be white.
24) This was the first picture I posted of my custom skull esc key, and was the prize for the "Guess how many keys" contest.
25) These are how the first individual prototype keys were sent off. Yes, I sold the first baches of prototypes to help fund this endevour... and what a wacky journey it has become! =P   (previously posted picture)
26) The above two pictures are of a setup I was using for a while when I was in one of my more Zen, feng shui, red dot notan moods apparently. (previously posted pictures)
27) These are some purple-ish test keys I had made long ago and I gathered them up and posted a pic in response to an inquiry. (previoulsy posted picture)
28) The above two pictures are of a key that was one of the first keys I had made. It is bonded metalic plastic, and was one of the first prototypes that I had made. I posted these pictures as a April FOOLS stating they were real gold plated silver. I "CAN" actually make them in gold plated silver, and perhaps if there is enough interest it might be feasable to make a short run. It doesn't have to be this design either. (previously posted pictures)
29) The above two pictures are some prototypes that I am calling ICE or Glass skulls (I can also make them in plain blank versions). The one on the left is a dead ringer for actual ice, and I am trying to replicate frosted glass. These look really, really refreshing on a keyboard. Just Imagine all the keys like this!!! I am also working on very smooth and clear keys that I might call Crystal. These all started when I made an actual glass key, It came out kinda wonky though so I decided to go this route with the plastic. The glass keys I think would be just too cost prohibitive, at least at the moment. BTW these keys are sick when they are illuminated via a backlit keyboard! YEEOWZA!
30) This is a comparison sample for a recent inquiry. I will update this explanation soon. =)
31) The above two photos are the aged metallic silver and gold  bonded technique. These ones happen to be for MX compatible switches.
32) The above two photos are aged purple and white skulls. This was a commission many months back and is done with a slightly different bonded technique. The dual tone purple goes about as deep as a dye sublimated key.
Pictures and descriptions continued in 2nd post! Enjoy =)
I will be continually updating the pictures.
Thanks again everyone for the interest =)
FAQ section:
updated Dec/2/2010
Q: When will these be available?
A: December 2, 2010 !!!
updated Dec/2/2010Q: How much do these or will these cost?
A: Please check EliteKeyboards.com for current pricing.
Please keep in mind that these are not only limited and made by hundreds of
gnomes in the Clack Factory but the prices will fluctuate.
updated Dec/2/2010
Q: Which keyboards/switches are they available for?
A: This FIRST run includes Cherry and Topre compatible keys
updated Dec/2/2010
Q: Which keys will you be making, and will you be making blank keys?
A: I intend to make many different types (first up are the original top row skulls) as well as blank "standard-ish" keys.
updated Dec/2/2010
Q: Do your keys weigh more or less than the old 2-shot keys.
A: My standard as well as designed keys weigh considerably more than 2-shot keys and way, way more than "standard" keys. They are also substantially thicker and feel more robust =)
Measurements will be updated soon as well as comparisons
updated Dec/2/2010
Q: Will you be making legends on the keys?
A: I would like to do some, but complete sets regardless of what process I choose would be daunting, so I am focusing on more unique designs and aspects of the keys.
updated JAN/2/2011
Q: Will you make custom stuff?
A: I thought that's what I was doing!?!?! =P Yes, I will take custom commissions and I have for both keys and boards. Currently I am backed up with production but feel free to drop a line if you have something "specific" in mind. =)
CURRENTLY NOT TAKING CUSTOM OR COMMISSIONED ORDERS
updated Dec/2/2010
Q: What colors and/or styles can you make them in?
A: Waaaaay to many to list outright, however I am working on a "key" (no pun intended) for reference.
updated Dec/2/2010Q: Are you going to make a GeekHack key?
A: Yes, I already have but I was not satisfied with the results. I am currently redoing some prototypes.
Q: Are these keys your "Project Board Chow"?
A: Nope (well... not entirely) that project just inspired me to pursue these keys and to find this forum.
Q: Are you taking suggestions on what stuff to make?
A: No, I am too cool! Of course I am, and I love to hear the interest, it keeps me motivated! =)
The FAQ will be updated continually =)
« Last Edit: Tue, 18 January 2011, 04:10:48 by clickclack »
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline clickclack
« Reply #1 on: Wed, 07 April 2010, 20:50:15 »
The two pics above show the "cobalt steel metallic" bonded key. It's a rich metallic key that shifts color with viewing angle. It goes from a light metallic blue to a rich blue to purple and idigo.
The above two pics are some leftover keys I had from a commission for Paddywagon. Some of these bunny keys were double molded with a pink ear and nose. Because of the lower requested key height they happen to look particuarly good on an MX 11800, so I took a pic of em on one =)
This commission sample illustrates a scissor switch skull key in two colors. Eventhough these are a bit more difficult to make they can still be dual molded.
Titanium keycap! I finally finished the prototype! YAY!!!! =) It took so long because it's a two part keycap. I designed It so I could test it with Topre, Cherry, ALPS, and Model M switches. In this photo it has the Topre/HHKB back. If I choose to make a limited number of them they would be a one piece key except for perhaps a Model M version, we shall see. I don't think there will be key wear on this one! =P. This one is semi polished but I will try a sandblasted one later when I have the time.
The above 4 photos show the "Heavy Metal" keys that I experimented with that I mentioned long ago. The are made from a bismuth alloy. They weigh a ton! I will go and weigh this one again later to get an exact measurement, as I don't trust my memory =P.
This one is aged, polished, and coated. I can replicate this look (even with the sheen) in the plastic version of these keys, as evident in my tests (not present in previous proto pics).
This is a comparision photo between the Heavy Metal skull key and the black DM/DS red eyes skull key.
1,2... 3???   ;)
The above 3 photos are of the Filco "Ice" keys with various colored cherry switches. They happened to be on a Cherry board so don't be fooled by the profiles, they are direct replacements for Filco keys.
Candy Corn skull key in MULTI-shot configuration. 3 colors, WERD! ;)
Don't be scared it's just a skull =P
Candy Corn WASD keys in Multi-shot configuration, hoooray!
The above two photos are of keys I made recently in order to test flexibility of a multi-shot process with different opacities. They look good enough to eat, so I guess they were successfull. ;)
More pictures to come... updated reguarly =)
« Last Edit: Wed, 27 October 2010, 17:27:56 by clickclack »
Offline clickclack
« Reply #2 on: Wed, 07 April 2010, 20:50:47 »
room for pics holder 2
Offline clickclack
« Reply #3 on: Wed, 07 April 2010, 20:51:18 »
room for pics holder 3
Offline rdjack21
« Reply #4 on: Wed, 07 April 2010, 20:53:57 »
Quote from: clickclack;170493
Wow I really like these :) I want some and if I'm not mistaken those are Topre caps as well :) When you have them ready I will order a set ASAP...
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline Specter_57
« Reply #5 on: Wed, 07 April 2010, 21:02:00 »
Ah-ha!
I see you've already began the experimenting with metallizing plastic caps, as I suggested as a possibility a short time ago in the Alu Cherry caps thread.
These examples you posted so far...looking pretty good...and I am anxious to see some other creative efforts on your part posted here.
This idea...could be huge!!!
Spec_57
Offline clickclack
« Reply #6 on: Wed, 07 April 2010, 21:32:25 »
Quote from: rdjack21;170498
Thanks, thats great to hear =)
And yes indeed they are Topre/HHKB pro keys (on a HHKB).
I am actually using them right now in a dark room (no lights other than monitors) and they show up really, really well!
Edit: more pics uploaded =)
Offline clickclack
« Reply #7 on: Wed, 07 April 2010, 21:37:51 »
Quote from: Specter_57;170503
Ah-ha!
Spec_57
Thanks =D
I did some really wicked ones about five months ago at work that I can't wait to upload. Hint: I call one of them "cobalt steel", its painfully hawt! ;)
Edit: new pics uploaded =)
Offline kriminal
« Reply #8 on: Wed, 07 April 2010, 21:45:53 »
sigh.... i cant wait for my piece of this keycap porn :(
did like the gold one you posted on the other thread, if actually created real gold limited editions i would buy surely!!!
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline didjamatic
« Reply #9 on: Wed, 07 April 2010, 21:46:04 »
Wow, those look incredible.  Very nice work!
Offline clickclack
« Reply #10 on: Wed, 07 April 2010, 22:02:13 »
Quote from: kriminal;170516
I wish I could go faster buddy, trust me, but these are time consumers for sure, and I can't seem to convince my employers that this is a good excuse to come in late or miss deadlines =P haahaa.
If/when I make those actual gold keycaps (not just the bonded plastic ones), you would be among the first I will contact! =)
Quote from: didjamatic;170517
Thanks, that means alot =)
Edit: more pics and descriptions just uploaded! =)
Offline wellington1869
« Reply #11 on: Wed, 07 April 2010, 22:04:18 »
How much? And whats your paypal address? :)
using: ms 7000/Das 3
Offline jpeck
« Reply #12 on: Wed, 07 April 2010, 22:17:02 »
Want! How many virgins must I sacrifice?
Offline Nonmouse
« Reply #13 on: Wed, 07 April 2010, 22:26:16 »
Quote from: clickclack;170515
Thanks =D
The new pics, they no workee...
Offline kriminal
« Reply #14 on: Wed, 07 April 2010, 22:30:34 »
Quote from: Nonmouse;170526
yup yup!! not working!!
Offline clickclack
« Reply #15 on: Wed, 07 April 2010, 22:35:24 »
hmmm... lemme check something quick...
(they seem fine on my compy hmm...)
I am guessing you guys can't see the last 3 new ones?
Edit:
I just logged out an back in and... YUP, they don't show up! oooops! I guess I need to hone my
forum skills some more. Let me see what I can do...
Edit again: nope they show up fine now when I refresh :S
« Last Edit: Wed, 07 April 2010, 22:44:18 by clickclack »
« Reply #16 on: Wed, 07 April 2010, 22:49:02 »
no skeletor love for me. I did control-f5 and everything.
Offline Nonmouse
« Reply #17 on: Wed, 07 April 2010, 22:56:24 »
I think they need to be attached, not just uploaded...
Offline clickclack
« Reply #18 on: Wed, 07 April 2010, 23:10:17 »
Quote from: Nonmouse;170536
hmm... I was wondering why I couldn't find "manage attachments" when I went back after first posting.
let me try some more stuff... (it's weird that the forum still lets me see them though).
Offline clickclack
« Reply #19 on: Wed, 07 April 2010, 23:23:28 »
I will post the pics here and then update the first posts, I hope this works :S
(crosses fingers)
and thanks Welly I just learned what ctrl F5 does now!
These are the missing pics, now lets see if I can get them into that first post....
Offline eunjea
    • http://kbdholic.net/
« Reply #20 on: Wed, 07 April 2010, 23:30:37 »
Wow... Ready to order. I''m waiting...
Give your paypal address. ;-)
Offline Nonmouse
« Reply #21 on: Wed, 07 April 2010, 23:35:51 »
Quote from: clickclack;170539
You need to "Go Advanced" after hitting the edit key.  It'll pull up the Attachments Manager.
Offline clickclack
« Reply #22 on: Wed, 07 April 2010, 23:39:26 »
Quote from: wellington1869;170521
haahaa =)
Prices have not been set and I will post info in the FAQ section at the bottom of the first post soon.
Quote from: jpeck;170523
ALL OF THEM!!!!
 Muuuuhaaaahaahaaaa! =P
Offline clickclack
« Reply #23 on: Wed, 07 April 2010, 23:44:52 »
Quote from: eunjea;170544
I am not quite ready yet, but please refer to the FAQ section on the first post for more info, I should have some info up on there soon.
Thanks for your interest I really appreciate it!
Quote from: Nonmouse;170545
They should be up/working now, I am apparently blind and did not see the attachment link earlier. I will check out what you are refereing to now though. Thanks for the help! =)
« Last Edit: Thu, 29 April 2010, 05:31:35 by clickclack »
Offline EverythingIBM
« Reply #24 on: Wed, 07 April 2010, 23:49:53 »
First up...
I like how the cranial part of the skull is somewhat translucent against the black. Is that going to be the most expensive cap out of the bunch?
Offline hyperlinked
« Reply #25 on: Wed, 07 April 2010, 23:59:28 »
Quote from: EverythingIBM;170549
You need a rubber dome to get that translucent effect. ;)
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline clickclack
« Reply #26 on: Thu, 08 April 2010, 00:42:56 »
I don't know, but I doubt it. There are more labor and time consuming ones.
Thanks for noticing the slighty translucent forehead! I tried it without that but its just too stark white, and there is not enough rounded volume up there to give a good shadow. So I made it thinner in that spot to show more depth.
Quote from: hyperlinked;170550
watch it buddy, don't hurt the skulls feelings =P
Edit: new pic and description posted... =)
Offline Rajagra
« Reply #27 on: Thu, 08 April 2010, 01:44:40 »
If the World of Warcraft people ever bring out a keyboard (they already have a mouse and headset) they should use ClickClack's keys, or maybe get him on the design team.
Offline clickclack
« Reply #28 on: Thu, 08 April 2010, 03:46:01 »
Quote from: Rajagra;170560
Thanks for compliment, that would be fun =)
Months ago I mentioned this to some friends that play online games WOW included and they liked the idea but I think I found WOW keyboards already.
Quote from: webwit;170563
Great stuff man, these will be legendary. I think you should make a choice: Either 1) sell these limited edition to the geekhack members here, and then ceremonially destroy the molds, or 2) think big ("panic key") and sell a couple of million and retire to your own island in the Caribbean. I think I prefer 1. Makes it more exclusive.
Haahaa, thanks, I appreciate it =)
My own island huh? That would be ideal I suppose, but if I went that route I would secretly have to make uber special limited editions for you guys!
Edit: more pics and descriptions added as well as FAQ section =)
« Last Edit: Thu, 29 April 2010, 05:35:43 by clickclack »
Offline ch_123
« Reply #29 on: Thu, 08 April 2010, 03:55:09 »
Post pics on kbdmania; profit big time.
Offline Specter_57
« Reply #30 on: Thu, 08 April 2010, 06:04:42 »
That group of coloured keycaps in your updated first post...I do not think the camera/lighting you are using is doing justice to the items.
A metallic look is aswsome, but that photo just doesn't seem to catch it.
Those colours look pretty intense.
And can you put legends onto these keys? Or is it going to be blank all the way?
All-in-all....terrific work.
The things one can do with imagination...haha  and the proper manufacturing equipment...I am so envious!!!         :-)
Spec_57
« Last Edit: Thu, 08 April 2010, 06:06:48 by Specter_57 »
Offline Shawn Stanford
« Reply #31 on: Thu, 08 April 2010, 08:28:49 »
Want...
The Brat Prince of COBOL
Offline InSanCen
« Reply #32 on: Thu, 08 April 2010, 12:47:56 »
I *need* a full set to fit a US M13, no Win keys..
Guess my bonus is about to go out of the window...
I am loving the black, with a slightly silvered/gunmetal logo on it.
Let me move some cash around, and I'll PM you if I can free some up.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Oqsy
« Reply #33 on: Thu, 08 April 2010, 12:49:04 »
I'd LOVE to get a full set of cherry OR IBM like the blank metallic plastic Alt pictured on the Topre, double shot / molded with black legends... Is there any chance this combination will crop up in the future? :D
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline nowsharing
  • Swoop
« Reply #34 on: Thu, 08 April 2010, 15:03:11 »
These are looking awesome, great work clickclack.
Offline clickclack
« Reply #35 on: Thu, 08 April 2010, 17:34:49 »
Quote from: ch_123;170570
Quote from: ripster;170606
Good idea.  AFTER you sell your first batch here.
haahaa, I really don't know anything about that site though, I went there a few times but my compy (internet) has a problem uploading it. Sometimes it works sometimes not, and sometimes I have to wait ten or more minutes to load it.
Edit: new pic and description uploaded =)
Offline clickclack
« Reply #36 on: Thu, 08 April 2010, 17:51:36 »
Quote from: Specter_57;170579
Hmm... I think I just finally found out which  metalic ones you were refering to. In the photo with a bunch of colored keys none of them are metalic. There are two keys in the center that have that flat profile skull on them and the lighting is to show they are dished and smooth (almost polished like). I think that is what you are refering to. If not, hmmm...???
I can make the colors either more intense/vibrant and more pastel, those were just a sample.
Thanks for the compliments btw :)
Quote from: Shawn Stanford;170595
Want..
I have some free time today, so I will be making some new prototypes and molds. I will also make a few skull MX keycaps for sale to the first prototype buyers for feedback. Off I go....
Edit: new pic and description added =)
« Last Edit: Thu, 08 April 2010, 17:52:45 by clickclack »
Offline clickclack
« Reply #37 on: Fri, 09 April 2010, 02:43:10 »
Quote from: InSanCen;170667
Thanks for the interest, just keep me posted :)
Edit: Just updated the descriptions
Offline clickclack
« Reply #38 on: Fri, 09 April 2010, 02:55:54 »
Quote from: Oqsy;170669
I plan on being able to make Cherry and M keys blank and in metallic. At this time because of the huge number of combinations most "legends" are not a current focus. I have a few prototypes of recessed legends but they are not in a contrasting color (yet?). Doing a metallic and dual molded cap with legends is a bit of a reach at the moment :S
Quote from: nowsharing;170697
Thanks! =)
Quote from: ripster;170699
How about trades?
DoubleShot Cherry Switch compatible.  I think it means ESCAPE in Korean.  You'd have to ask the KBDMania guys. :biggrin1:
Hmmm... I have an idea... (I will keep you posted)
I think I will throw in a pic of an orange cap in honour of your post :)
Edit: Model M keycaps pictures added and an orange original skull for MX
« Last Edit: Fri, 09 April 2010, 03:29:03 by clickclack »
Offline krstf
« Reply #39 on: Fri, 09 April 2010, 03:36:27 »
Those all look VERY nice.
Sign me up for some blank egg-shell white Model M keycaps please.
Oh and how about some glow in the dark(room) keys ;)
Offline kriminal
« Reply #40 on: Fri, 09 April 2010, 10:11:53 »
what about a clear or "foggy"? caps? so that if an led is placed under i can get a nice glow?
got a mod project in mind...
Offline Oqsy
« Reply #41 on: Fri, 09 April 2010, 10:38:07 »
Ok, thanks clickclack.  Metallic with recessed legends sounds very darn close to what I was looking for anyway.  I'm very interested.  :D
Oh I'd also like a set of ALPS compatible made of pure diamond in the D-F color range with clarity of flawless to VS-2 with emerald legends, packaged in phoenix feathers, and hand delivered by the Dalai Lama.  Any chance you can get them ready before the quickening?  :P :P :P
Offline clickclack
« Reply #42 on: Fri, 09 April 2010, 10:38:16 »
Quote from: krstf;170826
Thanks =)
I have a few glow in the dark and UV reactive ones, but I am just testing them at the moment. I will update the FAQ to include some of that info.
Thanks for the interest!
Quote from: kriminal;170870
I have some pics I need to upload that are similar to what you are inquiring about. I have done some clear, translucent, and milky/foggy caps for purposes of either being illuminated (cherry switch) or just too look cool. I will throw up a some pics soon that have the old (original prototypes) keys illuminated with a TG3. It wont work so well on the new styled keys (because they are thicker) so I have made a special illuminated prototype that has either a thinner section in the cap where light can pass or has a dual molded  with translucent plastic in those sections.
I will be updating the FAQ section soon with info that will relate to what I just mentioned =)
Offline clickclack
« Reply #43 on: Fri, 09 April 2010, 10:49:40 »
Quote from: Oqsy;170882
Pheeeeew! Haahaa, but seriously though legends are not a huge focus at the moment because there is such an overhwelming amount of them :S
OOOOOOOOOO diamonds 8(   eeeeek! I will get right on it!!!! Haaahaaa =D
I must admit I really, really like the emerald idea! When I make a few more translucent ones I will try an emerald test, I'm kinda excited about that one now =)
« Last Edit: Sat, 10 April 2010, 17:51:58 by clickclack »
Offline InSanCen
« Reply #44 on: Fri, 09 April 2010, 17:34:09 »
This... I want. I assume the raised profile is minimal? Much better than Blanks
How much for 40 M caps? Feel free to PM me with a price on both in that Quantity.
Offline clickclack
« Reply #45 on: Sat, 10 April 2010, 03:20:13 »
Quote from: InSanCen;171039
PM sent :S haahaa
btw I am uploading some more pics and descriptions later today =)
« Last Edit: Sat, 10 April 2010, 03:20:58 by clickclack »
Offline Specter_57
« Reply #46 on: Sat, 10 April 2010, 07:50:09 »
CC:
In my previous post, the group of coloured keys, etc...(this pic)
OK...my mistake...I thought the whole group of keys were all metallized, not just those two skulls I see upon closer inspection...so my comments about the pics were off-base.  Sorry.
As you said, I now realize they are plastic caps except for the skulls.
I can see sooo much potential here for creative and interesting keyboard caps...and for that matter...outside of the keyboard caps area too...
Spec_57
« Last Edit: Sat, 10 April 2010, 07:53:02 by Specter_57 »
Offline iMav
  • geekhack creator/founder
« Reply #47 on: Sat, 10 April 2010, 08:00:49 »
I would definitely be interested in a complete set (or two) of keycaps for the HHKB (Pro, of course).  One of my biggest pet peeves is that you can't get white keycaps with all the keys the same color...the modifier keys are always grayish.  What I want is a white set for the HHKB.  Of course, I'd be interested in some of the caps having some custom design and/or bright colored esc and WASD keys.
If you were able to do printing, that would be cool (imagine the URL for geekhack on the front side of the space bar).  :)
Offline Oqsy
« Reply #48 on: Sat, 10 April 2010, 10:41:57 »
Quote from: clickclack;170888
OOOOOOOOOO diamons 8(   eeeeek! I will get right on it!!!! Haaahaaa =D
Glad my silly suggestion served as inspiration :D  Now that I think about it, clear keys with emerald green legends would be pretty neat.  If I could convert my wife to mechanicals (she's stuck on domes and scissors), I would give her a set and refer to it as "jewelry".
Offline clickclack
« Reply #49 on: Sat, 10 April 2010, 17:55:39 »
Quote from: Specter_57;171137
CC:In my previous post, the group of coloured keys, etc...(this pic)
OOOOH No! haahaa, you still got it wrong =P haahaa
On that board there are NO metallic keycaps. The two skulls are just a different texture (smoother/polished) which is why they shine a bit. =)
