Author Topic: PULSE SA Alphas with Cherry modifiers?  (Read 4901 times)
Offline BserLarry
« on: Wed, 14 March 2018, 04:17:34 »
Hi guys,
With the upcoming GB for Pulse SA R3 (https://www.massdrop.com/buy/pulse-sa-keycap-set?mode=guest_open) I would like to ask if it’s possible/comfortable to mix those kick ass cyan alphas with cherry mod keycaps?
Offline Techno Trousers
  • ʘ_ಠ
Re: PULSE SA Alphas with Cherry modifiers?
« Reply #1 on: Wed, 14 March 2018, 08:29:11 »
SA caps are among the tallest you can get, and Cherry profile is among the lowest. You'll have to decide if that sounds like a workable combination.
« Reply #2 on: Thu, 15 March 2018, 11:17:59 »
pretty much
i hate SA so i just use cherry
« Reply #3 on: Thu, 15 March 2018, 12:18:17 »
pretty much
I concur SA is only good for making pretty photos.
Offline dblack
  • Formerly ZuXzu
« Reply #4 on: Thu, 15 March 2018, 15:47:34 »
pretty much
i think they look wonky on everything haha. to answer your question op I would definitely stay away from a combo like that. theres obviously going to be a aesthetic mismatch but also sound and feel are going to be all over the place.
« Reply #5 on: Thu, 15 March 2018, 20:48:47 »
pretty much
Uniform R3 SA is not as bad, but sculptured takes a lot of getting used to.
Still wouldn't make an aesthetic or functionable combination with Cherry modifiers though.
