Author Topic: Looking for certain build.  (Read 2714 times)
Offline DonnyD
« on: Fri, 23 March 2018, 08:56:07 »
I am looking for keyboard build, where plate was integrated into the case. Case was milled from the bottom, also milling keyswitch holes. In other words, with that kind of case you put pcb from bottom, not top. And maybe this technique has a name ?
Offline Blaise170
  • ALPS キーボード
    • XYZ
Offline ppp
  • KappaKeepoKoopa
Re: Looking for certain build.
« Reply #2 on: Fri, 23 March 2018, 09:44:57 »
Or like the preonic case?
https://olkb.com/preonic/formed-top
Offline ojrask
  • juuh elikkäs
« Reply #3 on: Fri, 23 March 2018, 09:45:19 »
Clueboard?
Current:
Coming up:
IC/GB:
Offline DonnyD
« Reply #4 on: Fri, 23 March 2018, 09:57:17 »
Preonic plate/case thing is closest. It looks like its bend from single sheet of metal. I am looking cnc machined one. But you got the idea, thanks for shatlring them, guys !!
« Reply #5 on: Fri, 23 March 2018, 10:04:04 »
Like this??
Offline gr4v3m4n
    • my store
« Reply #6 on: Fri, 23 March 2018, 20:21:49 »
than probably this?
HOLO Custom Keyboard
https://r.tapatalk.com/shareLink?share_fid=2190&share_tid=94376&url=https%3A%2F%2Fgeekhack%2Eorg%2Findex%2Ephp%3Ftopic%3D94376&share_type=t
edit : oops, sorry this has a removable plate.
« Last Edit: Fri, 23 March 2018, 20:24:21 by gr4v3m4n »
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
« Reply #7 on: Fri, 23 March 2018, 21:51:36 »
Like this?
