Author Topic: [IC] Retro + Innovation = ALF X3 Renova GB in 3 hours!  (Read 36175 times)
Offline AuthenticDanger
Re: [IC] Retro + Innovation = ALF X3 Renova (price and more!)
« Reply #100 on: Wed, 02 May 2018, 15:26:42 »
I actually think the best option would be for the 40 kits to be able to choose your base and accent color instead of these 4 fixed ones.
I 100% agree. I'd love Red with a grey shell.
F Keys belong on the left.
Offline Peiweisgreat
« Reply #101 on: Wed, 02 May 2018, 17:44:08 »
Yeah Id love a green/white combo for this board.
Offline lecorsair
« Reply #102 on: Wed, 02 May 2018, 20:34:51 »
I agree, for this price, one should be able to freely choose accent colors.
Offline unmuscular_michael
« Reply #103 on: Wed, 02 May 2018, 22:01:28 »
Just got the notification e-mail for this. I really wish they'd allow plate/case selection too - white with red would look great with Honeywell.
Offline Starius
« Reply #105 on: Thu, 03 May 2018, 08:00:47 »
I've been monitoring this thread for awhile, and never actually felt the need to create a account here and participate.  That is, until now... because I have a couple things I just wanted to verify before taking a stab at the group buy tomorrow night.
1. Am I correct in assuming that this is still a "kit keyboard," in that no switches or keycaps come with it?
2. If so, does. the PCB have hot swap sockets or will the buyer need to solder their switches?
3. Will anything else be required separately to make it fully functional?  Such as stabilizers?
4. I know the keyboard has bluetooth, but does it also have a USB port?  And if so, which type of USB?
And finally,
5.  With only 40 offered in the Asian market and 40 offered in the western market, are we just looking at a total of 80 boards in existence for the X3 Renova?  Is this a one time run or might it be offered again in the future?
Offline Peppermint216
« Reply #106 on: Thu, 03 May 2018, 08:19:34 »
And finally,
From what we know:
1. Correct.
2. Soldered switches.
3. Stabs, switches and keycaps, possibly leds for the indicator top.
4. Yes, unknown port, probably mini usb.
5. 80 yes if they sell out, unknown future buys.
Offline Starius
« Reply #107 on: Thu, 03 May 2018, 09:08:03 »
And finally,
From what we know:
1. Correct.
Thank you for the reply, Peppermint.  I appreciate it.
One follow up question..... (and forgive me if this is a newbie-ish question) Would this board require the plate mount style of stabilizer, opposed to the pcb screw in style?
« Reply #108 on: Thu, 03 May 2018, 09:50:58 »
No it will need PCB mount. Not all PCB mount are screw-in.
Offline Starius
« Reply #109 on: Thu, 03 May 2018, 10:57:14 »
Looks like we now have a ALF X3 Renova placeholder page up, with ALF X2 content inside....
https://en.zfrontier.com/products/group-buy-alf-x3-renova
Offline Photoelectric
« Reply #110 on: Thu, 03 May 2018, 11:01:40 »
zFrontier shows its old group buy webpages even after group buys have closed.  It's likely not a placeholder, and X3 will have its own page.
« Reply #111 on: Thu, 03 May 2018, 11:08:19 »
It does say ALF X3 Renova....
« Reply #112 on: Thu, 03 May 2018, 11:09:41 »
Oh yeah, I should have looked :facepalm:  If only that price were correct, sigh.
« Reply #113 on: Thu, 03 May 2018, 11:12:41 »
Haha I thought the same.
Offline Starius
« Reply #114 on: Thu, 03 May 2018, 12:07:38 »
And now the page disappeared.
Guess we weren't supposed to see that just yet. ;)
Offline zF_ScrambledEggz
    • zFrontier
« Reply #115 on: Fri, 04 May 2018, 02:57:16 »
Yup guys;)
A little updates regarding colors and usb before the buy:
MINI - USB
and
The aluminum insert and mid-piece will have the same color, four options - purple, green, red, orange
The housing and plate will have the same color, four options - white, silver, gray, black
And Yes, you don’t have to go with the combos I mentioned previously.
« Reply #116 on: Fri, 04 May 2018, 02:59:08 »
Yup guys;)
MINI - USB
and
So in a way it's 40 fcfs of any colour?
    • zFrontier
« Reply #117 on: Fri, 04 May 2018, 04:10:16 »
Yup guys;)
MINI - USB
and
40 units in total, color does not affect the total number.
    • zFrontier
« Reply #118 on: Fri, 04 May 2018, 12:16:14 »
 :thumb: and now you could do that!
« Reply #119 on: Fri, 04 May 2018, 12:28:29 »
What are the layout options?
Offline Poesjuh
« Reply #120 on: Fri, 04 May 2018, 17:08:14 »
NAISUUUUUU. For those ordering that is
Sent from my iPad using Tapatalk
« Last Edit: Fri, 04 May 2018, 17:12:06 by Poesjuh »
    • zFrontier
« Reply #121 on: Fri, 04 May 2018, 19:43:11 »
GB will begin in less than 3 hours ;D
GB post already submitted https://geekhack.org/index.php?topic=95452.0
Offline Starius
Re: [IC] Retro + Innovation = ALF X3 Renova GB in 3 hours!
« Reply #122 on: Fri, 04 May 2018, 23:27:51 »
Do you guys think these stabilizers will work well with the Renova PCB?
https://www.massdrop.com/buy/transparent-gold-plated-pcb-mount-screw-in-stabilizers
Offline ptiede
« Reply #123 on: Sat, 05 May 2018, 00:17:54 »
Yep! Zeal stabs are expensive though.
