Author Topic: Need Some Model AT F Help....  (Read 3009 times)
Offline skcheng
    • Tenafly Dentistry
« on: Mon, 12 April 2010, 13:28:22 »
I thought I would post this here, but I'll delete this and move it over to the Classifieds if that's more appropriate.   I received an IBM Model AT F keyboard today and unfortunately it was banged around a bit and several keys were loose by the time it arrived at my door.
Does anyone have a right Enter key that they could sell/trade me.  Please....I would like to try out the keyboard, but it's hard without the Enter key.
Thanks everyone!!
skc
Offline nowsharing
  • Swoop
« Reply #1 on: Mon, 12 April 2010, 14:27:33 »
HaaTa's excellent Model F backspace thread might sort out your situation, unless you wanted to keep yours completely stock.
http://geekhack.org/showwiki.php?title=Island:8893
Offline nowsharing
  • Swoop
« Reply #2 on: Mon, 12 April 2010, 14:57:48 »
I guess I read your post to quickly. You were talking about the number pad's enter key, in which case the HaaTa thread won't be of help.
I don't have an F near me, but would a key from a Model M work? If not, you might try asking Unicomp if they stock them. There's a small chance that they might. They still stock the old hat style ctrl and alt keys.
Offline skcheng
    • Tenafly Dentistry
« Reply #3 on: Mon, 12 April 2010, 15:11:47 »
Quote from: nowsharing;171636
I just got off the phone with Chucky and he simply laughed when I asked him if he had any of the large L shaped Enter keys.   I hope I don't need to purchase an XT simply for the Enter key??
Offline skcheng
    • Tenafly Dentistry
« Reply #4 on: Mon, 12 April 2010, 15:12:32 »
Quote from: nowsharing;171632
You know.....that is EXACTLY what I will do.  Or attempt to do  ;-))
Offline ch_123
« Reply #5 on: Mon, 12 April 2010, 15:33:22 »
The Model F doesn't have a numpad enter.
Offline nowsharing
  • Swoop
« Reply #6 on: Mon, 12 April 2010, 15:54:48 »
Best of both worlds: a fixed enter key and it's probably more what you're used to using.
You're right, it's a + key on the F
Offline EverythingIBM
« Reply #7 on: Tue, 13 April 2010, 01:55:50 »
Quote from: skcheng;171626
Thanks everyone!!
skc
That must have been some pretty shoddy shipping... it's kind of hard to damage a Model F; the notion is inconceivable!
Offline sethstorm
« Reply #8 on: Tue, 13 April 2010, 09:17:32 »
Depends if the AT F will accept a single-row enter.  Swap the spring+hammer that's left of backspace for where the top row of the enter key is now.  Then put the | \ key from a Model M there.  Finally, put the single-row Enter key in.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline trievalot
« Reply #9 on: Tue, 13 April 2010, 09:28:54 »
i also have done the big backspace mod - where are you living??? (continent wise?)
[SIGPIC]
Offline skcheng
    • Tenafly Dentistry
« Reply #10 on: Tue, 13 April 2010, 11:21:58 »
Quote from: trievalot;171826
I'm in Northern Jersey.  I fixed my key.  Just glued the entire thing together and it appears to work fine.
Interesting keyboard to say the least.  Layout is a HOT mess imho.   Truly a luxurious typing experience though.   Well, except for the space bar which is a beast.   I actually need to look for the Backspace key since I keep hitting the tilde key to the left of it.   UgghhhmusthavestrongerthumbsLOL.  Keyboard sure is "twangy".
Offline JBert
« Reply #11 on: Tue, 13 April 2010, 14:20:07 »
Quote from: skcheng;171871
Sure it is twangy, that's just what it's praised for.
You can mod that space bar for a finer feel if you aren't afraid of opening up the keyboard, just follow the instructions for a lighter space bar.
However, if this is your first time opening up the keyboard, be wary that you will have to take your time.
Most parts are quite durable, just make sure you don't get the buckling springs caught up in something or bend them.
The storage list:
Currently ignored by: nobody?
[/SIZE]
