Author Topic: [GB] QXP 60% Keyboard - Completed  (Read 215341 times)
Offline Quantastrophus
Re: [GB] QXP 60% Keyboard (Invoices Paid. Submitting Order May 2)
« Reply #200 on: Wed, 23 May 2018, 09:12:59 »
Hi All,
The form in the OP is reopened for anyone wishing to order an extra. I'll message you if you submit for an option that is unavailable.
Offline Mcnos
    • GMK Fuyu
Re: [GB] QXP 60% Keyboard (Additional Spots. No Delays)
« Reply #201 on: Wed, 23 May 2018, 11:40:09 »
I went ahead and put in an order form. I'm not sure what's the status of orders right now. I hope I can get in
Offline SJHL
« Reply #202 on: Fri, 25 May 2018, 20:47:19 »
Anyone thinking of designing an Alps plate (WKL)? If so, I would like to join.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #203 on: Fri, 25 May 2018, 21:02:30 »
I'm making an alps plate but for standard with an AEK bottom row.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline Mcnos
    • GMK Fuyu
« Reply #204 on: Mon, 28 May 2018, 17:42:10 »
I'd be down for this.
« Reply #205 on: Mon, 28 May 2018, 18:21:39 »
I've already done some of the work making this so as long as the man Quan's okay with it we can do it.
Here's a picture of what I've got so far.
If there's more interest I could add MX stabilizer holes.
I don't know Geekhack ettiquate is it incorrect to discuss this here? Apologies quan if I've overstepped.
EDIT: Added spacebar MX cutouts as i'm using a spacebar with MX stabilizers.
« Last Edit: Mon, 28 May 2018, 19:38:18 by Acereconkeys »
Offline ryancopenhaver
« Reply #206 on: Mon, 28 May 2018, 18:53:05 »
So I've filled out the form for one of the extras, but have not received an invoice for it yet. Is that coming later, or should I have expected it already?
Sent from my SM-G965U using Tapatalk
Offline odd
« Reply #207 on: Tue, 29 May 2018, 11:15:53 »
I would be down to purchase a Alps plate as well so count me in.
« Reply #208 on: Tue, 29 May 2018, 15:42:30 »
All invoices for extras have been sent out. I see that I sent one out for you specifically as well. Contact me via PM or Discord so I can double check that the email I received for you was correct.
Offline ryan60197
« Reply #209 on: Wed, 30 May 2018, 00:32:21 »
I only just submitted today. Am I still able to get one?
« Reply #210 on: Wed, 30 May 2018, 12:28:40 »
You're right...I'm dumb. I found the invoice and made the payment. Thanks for replying! Everything seems to be set.
Offline lunr
« Reply #211 on: Fri, 01 June 2018, 09:21:53 »
Is there still spots left? Taking a look at the spreadsheet and not sure if it's updated or not.
Offline Tonkatonk
« Reply #212 on: Fri, 01 June 2018, 21:02:54 »
Order submitted!  :thumb:
Noxary PC268.2 | Red Nunu | Purple PC Nunu | Ogre | Vulcan Pro
« Reply #213 on: Fri, 01 June 2018, 21:48:22 »
I'd imagine if the forms still open then there are still spots left.
Offline OracleKev
« Reply #214 on: Sat, 02 June 2018, 08:39:37 »
+1
« Reply #215 on: Sat, 02 June 2018, 11:19:44 »
Hi All,
Update: The manufacturer is set to receive the bulk raw material in the coming week and then machining can begin shortly after.
If you are interested in purchasing a board here are the kits that are still available: https://docs.google.com/spreadsheets/d/1YttqhwpyjsRi2hG0m7JBProIy4jf3-8hZKvHRRYH4vs. If you do not see a color that means a color can still be chosen.  After the end of this weekend, boards will no longer be available at GB price and will change to $300 (previously $250) for a base kit (Top, Bottom, Weight Plate).
Thanks
Offline Tonkatonk
« Reply #216 on: Sat, 02 June 2018, 22:49:34 »
Oooof I made it in! So excited for the blue gray to come in!
« Last Edit: Sun, 03 June 2018, 15:31:24 by Tonkatonk »
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #217 on: Sun, 03 June 2018, 15:37:45 »
All paid up! Glad I made it in.
Offline hayt
« Reply #218 on: Wed, 06 June 2018, 15:09:22 »
I'm in if not too late :) PM'd you on slack I have a question for ya
Offline Poesjuh
« Reply #219 on: Wed, 20 June 2018, 15:12:04 »
Still any available?
« Reply #220 on: Wed, 20 June 2018, 15:13:40 »
I'm not the man himself but the form is still open and the google doc still says there's spots so i'd say go for it?
Offline Poesjuh
« Reply #221 on: Wed, 20 June 2018, 15:14:15 »
Wh0000p that's a fast reply :P Hot damn.
« Reply #222 on: Wed, 20 June 2018, 15:53:47 »
I'm very excited for the board/I just got lucky with refreshing geekhack at the right time.
« Reply #223 on: Wed, 27 June 2018, 12:09:47 »
Hello fellow QXP friends I mentioned above i was working on an alps specific plate just wanted to give an update on that.
I've got a prototype in which you can see below. Upon immediate inspection i'm really happy with it the alps clip in great and it looks fantastic.
The next step will be confirming all the switches are in the right location and hopefully, Quan willing, i'll get a chance to check whether it properly mates with the case prototype.
Offline midnight2903
« Reply #224 on: Thu, 28 June 2018, 06:50:53 »
I would definitely be up for one if its HHKB compatible. My orange alps are still waiting for a HHKB Alps board and this would be perfect.
« Reply #225 on: Thu, 28 June 2018, 12:15:31 »
At this point it's more of an issue of figuring out what layout a majority/enough people would be interested in to make them.
Offline OracleKev
« Reply #226 on: Fri, 29 June 2018, 04:02:34 »
AEK! My distant second preference would be Winkey with Cherry stab on SPC in order to use Taobao keycaps.
Offline OnceSavedGaming
« Reply #227 on: Sun, 01 July 2018, 21:55:30 »
I feel aek would the easiest but with me having the hhkb case i would want that. But I have to ask, how do you go about spacebar foe that with a 7u?
Sent from my VS996 using Tapatalk
Offline hansichen
« Reply #228 on: Mon, 02 July 2018, 04:33:32 »
Not sure if we really get enough people to like one layout. Some people want standard aek, others with mx space bar, there are so many options with alps and multi layout plates are nearly impossible compared to mx plates. I hope we can get the plate files open sourced so that everybody can make his own layout plate. From what I've heard https://www.laserboost.com/ 60% plates are around 40$ shipped to the US, to me that sounds like a valid option for alps interested people. And for EU people like me this may even be the better option compared to expensive US>EU shipping.
I personally would probably be interested in a standard aek plate, but as shipping from the US is probably 14$ alone + taxes, I'm not sure if I really commit to that as my primary build will be with mx switches.
Btw: is there any update about production?  ;D Is the cnc work already done or did it already move to the anodizing company?  :D
Offline packman86
  • Morning Coffee
« Reply #229 on: Mon, 02 July 2018, 08:55:20 »
Quant posted a teaser pic on the discord a few days ago. Things moving along smoothly ;)
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline hansichen
« Reply #230 on: Mon, 02 July 2018, 09:49:23 »
Good to hear  :)  Which discord do I have to join or can someone reupload the pictures here?  ;D
Offline hayt
« Reply #231 on: Mon, 02 July 2018, 09:52:44 »
Would love to see ne teasers or updates in the GH thread  :D
Offline clasicks
  • Formerly KeyboardUser4
« Reply #232 on: Mon, 02 July 2018, 10:00:01 »
Please give more money to iMav to unlock this post
« Last Edit: Tue, 03 July 2018, 11:45:27 by clasicks »
« Reply #233 on: Sun, 08 July 2018, 22:49:55 »
Hi All,
Latest update: CNC is completed for all of the boards. They are being prepared with a final step before they go to anodizing. I'll keep you posted when I have more info. There are still a few boards unclaimed so check the Order Check link in the OP.  Rows in GRAY are boards that are available.
Thanks
« Reply #234 on: Sun, 08 July 2018, 23:50:08 »
Hi All,
Thanks
Thanks for the update Quan! Any chance for a leak of a photo?
Can't wait!
Offline dantambok
« Reply #235 on: Mon, 09 July 2018, 23:01:51 »
Filled in for a spot! This will be my first WKL 60%. When is this estimated to ship? :)
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline packman86
  • Morning Coffee
« Reply #236 on: Mon, 09 July 2018, 23:27:13 »
CNC done and waiting for ano. So probably pretty soon.
Offline dantambok
« Reply #237 on: Mon, 09 July 2018, 23:37:24 »
oh cool. I'm guessing anodizing goes pretty fast? I wonder if Quant mentioned any timeline for this. Maybe like august?
Stuff  I have
100+ GMK sets
Offline packman86
  • Morning Coffee
« Reply #238 on: Mon, 09 July 2018, 23:42:16 »
Last I heard was "Soon^TM".
Offline joe405
« Reply #239 on: Tue, 10 July 2018, 00:39:21 »
Put in an order but as the spreadsheet doesn't automatically get updated I'm not sure if I got a spot? Also dropped quant a PM here and on discord
Offline Quakemz
« Reply #240 on: Wed, 11 July 2018, 02:38:17 »
Thanks for the updates, Quan! Can't wait for this WKL goodness.
Offline saucybulgogi
« Reply #241 on: Sat, 14 July 2018, 21:09:05 »
Finally pulled the trigger on this. Hope I can grab the spot I want. Great looking board at a great price!
Offline juaninamilli
« Reply #242 on: Tue, 24 July 2018, 09:15:34 »
Any extra alu hhkb/wkl plates?
Offline friglesnart
« Reply #243 on: Fri, 27 July 2018, 16:51:48 »
I would be interested depending on the layout supported. My Ideal layout is HHKB layout using AEK standard bottom row as I have a M0116 to fill out the proper compat I need. I would also do the 1 - 1.5 - 7 - 1.5 - 1 bottom row w/ cherry stabbed spacebar if anyone has a link to where they are readily available.
Offline petamva
« Reply #244 on: Sat, 28 July 2018, 11:30:26 »
Filled in for a spot... Am i too late though?  :'( :'( :'(
Offline SJHL
« Reply #245 on: Mon, 30 July 2018, 08:01:38 »
Any sweet pictures to hold us off?  :p
« Reply #246 on: Tue, 07 August 2018, 14:09:21 »
It's been almost a month since an update and production is scheduled to have been completed 4 days ago any chance we can get some info as to the current status of the buy?
Can't freaking wait.
Offline amnesia0287
  • Formerly Amnesia
« Reply #247 on: Tue, 07 August 2018, 18:27:27 »
Cases are in polishing. That’s where they have been for the last 3 weeks, this part takes a while since it’s a slow manual process. After polishing is anodizing.
« Reply #248 on: Tue, 07 August 2018, 18:29:21 »
So then we are behind schedule at least a couple weeks. These are updates that would have been good to know before the expected ship date already passed.
Offline mudcakehoney
« Reply #249 on: Tue, 07 August 2018, 18:34:15 »
I never enter a GB expecting it to run on time, once I’m in I just put it out of my mind and get on with my life playing with the keebs I already have and then, surprise, shipping notice! Feels more zen that way
