Author Topic: Anyone able to build a keyboard with joystick. I am a klutz.  (Read 2107 times)
Offline ForanPower
« on: Thu, 05 April 2018, 21:41:46 »
Hello,
If anyone would build a keyboard with joysticks.
I would be very grateful. I am not rich, but will pay whatever I can.
Need this keyboard because playing video games makes my arm cramp up and it's very painful, so I am unable to game anymore.
Already created the design, it took about a year to find a setup that's natural...
...am a complete klutz when it comes to wiring and building things.
Thanks for taking your time to consider!
/Forest
Offline vvp
Re: Anyone able to build a keyboard with joystick. I am a klutz.
« Reply #1 on: Fri, 06 April 2018, 04:20:31 »
You forgot to post an image showing what the keyboard and joystick layout should look like.
Offline MC Qwerty
« Reply #2 on: Fri, 06 April 2018, 05:22:59 »
Hey man,
You can in theory put a joystick into a keyboard, I have seen stuff done with the IBM nub thing they work pretty fine, and you can put a joystick in an
Arduino Micro But I don't know how you would also hook up a pcb or handier a keyboard with it, but I have seen it done check around geek hack theirs
some stuff with a ATREUS62 and an ibm nub thing,
Might I recommend if you are having pains in your arm getting a set up with any of the following,
A vertical mouse like a Anker really nice been using them for gaming and work, works really well, and also cheap about $12 or so
https://www.amazon.co.uk/Wireless-Vertical-Ergonomic-Optical-1600DPI/dp/B00BIFNTMC/ref=sr_1_1?ie=UTF8&qid=1523009767&sr=8-1&keywords=anker+mouse
If you don't mind small form factor keyboards I would recommend getting an  Viterbi Keyboard - 5x7 70% Split Ortholinear, it split so you can angle it
how ever you want, and put the wasd cluster and the anger mouse next to each other making it put far less strain on your arms,
https://keeb.io/collections/frontpage/products/viterbi-keyboard-pcbs-5x7-70-split-ortholinear?variant=1302704554014
or maybe if you want low profile switches or something go to novel keys, they got a new split keyboard with is looking pretty nice and is relatively cheap
about 80-100$ including all components such as, keycaps, switches, and the kit which has the electronic components,
So yeah hope that helps
MC Qwerty
