Author Topic: [GB] Orange75 and Orange numpad  (Read 96950 times)
Offline senter
Re: [GB] Orange75 and Orange numpad (Last one day to join)
« Reply #100 on: Thu, 19 April 2018, 02:41:57 »
I noticed that on the upgrade order option, there is a $16 shipping charge tagged on, I'm a little confused can you clarify?
The GB has ended. If you need anything please tell me and I will relay that to zFrontier so they could create an invoice for you.
Offline oldcat
  • 65% is Life
« Reply #101 on: Thu, 19 April 2018, 11:28:47 »
Thank you so much, this is awesome! It is great to be part of this drop! Do you know when the shipping invoice will be sent? Also, could you kindly confirm the build specifications when you send the invoice? I have requested a few changes after placing the order, including case/insert color and changing the default PCB to the QMK PCB. Thank you very much!
Offline senter
« Reply #102 on: Thu, 19 April 2018, 11:40:23 »
Thank you. It will be zFrontier sending the invoice so I don't know. I will tell them tho.
Your PCB has been changed to QMK version. I will get all the order info from zFrontier in the following days. You can PM later to confirm your final specifications.
Offline senter
Re: [GB] Orange75 and Orange numpad (GB closed)
« Reply #103 on: Thu, 19 April 2018, 11:44:51 »
A lot more Orange75 were sold than I expected. The GB period wasn't long, but I hope it reached to everyone who wanted an Orange series.
Offline M
« Reply #104 on: Thu, 19 April 2018, 11:49:27 »
Do you mind telling us how many bought the all-brass version?
Offline oldcat
  • 65% is Life
« Reply #105 on: Thu, 19 April 2018, 14:26:41 »
Thank you so much! Will send a PM confirming the details.
Offline senter
« Reply #106 on: Thu, 19 April 2018, 16:29:34 »
I haven't received the final order info from zFrontier. It was 3 for brass version when total number was 48 two days ago.
Offline lecorsair
« Reply #107 on: Thu, 19 April 2018, 18:40:35 »
I know I should ask zFrontier directly but just curious anyone else got tagged with a shipping charge just on the upgrade to brass weight?
Offline oldcat
  • 65% is Life
« Reply #108 on: Thu, 19 April 2018, 23:26:56 »
Can't wait to see these get into production! Thank you for the great work!
Offline oldcat
  • 65% is Life
« Reply #109 on: Fri, 20 April 2018, 18:01:56 »
By the way, Senter, will you do another 65% Pizza board (or something similar) in the future? Would be interesting too!
Offline xondat
  • i'm not a star
« Reply #110 on: Fri, 20 April 2018, 18:08:16 »
He said this is the last in the Orange series above
Offline senter
« Reply #111 on: Sun, 22 April 2018, 09:54:40 »
First batch of 32a version PCBs.
will be testing it tomorrow.
Offline oldcat
  • 65% is Life
« Reply #112 on: Sun, 22 April 2018, 10:10:17 »
Wow great!
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #113 on: Sun, 22 April 2018, 10:38:49 »
That's a great looking PCB. Very clean and I like the color!
Offline oldcat
  • 65% is Life
« Reply #114 on: Sun, 22 April 2018, 11:05:23 »
This is the USB-C one?
Offline lecorsair
« Reply #115 on: Sun, 22 April 2018, 17:37:18 »
It actually looks yummy in keeping with the theme - almost lickable! So looking forward to the final product.
« Last Edit: Sun, 22 April 2018, 17:38:58 by lecorsair »
Offline captsis
  • Formerly matt2dlg
« Reply #116 on: Sun, 22 April 2018, 17:59:45 »
almost lickable!
Do you lick circuit boards often? How does fibreglass taste?
Offline senter
Re: [GB] Orange75 and Orange numpad (last day to change PCB version)
« Reply #117 on: Mon, 23 April 2018, 12:36:08 »
If you want to get the 32u4 version of pcb instead of the default 32a version, please manage to pm me your order number by 23:59:59 EDT today.
Offline Kevadu
« Reply #118 on: Mon, 23 April 2018, 15:47:36 »
I sent you a PM a couple weeks ago and never got a response.  Should I be worried?
Offline senter
« Reply #119 on: Mon, 23 April 2018, 16:18:01 »
Sorry, I missed your message. Now I've noted it down.
Offline macclack
    • Macclack
« Reply #120 on: Mon, 23 April 2018, 17:28:17 »
What is the difference between the two versions?
Offline captsis
  • Formerly matt2dlg
« Reply #121 on: Mon, 23 April 2018, 17:38:21 »
The 32u4 is QMK and USB C.
Offline senter
« Reply #122 on: Mon, 23 April 2018, 20:23:07 »
32A and 32u4 are all commonly used MCUs on keyboard PCBs.
The 32A version PCB can be easily re-programmed with a software called bootmapper client. bootmapper client has a GUI and is straightforward to use. It can run on Windows OS and OS X.
The 32u4 version PCB can be re-programmed with QMK/TMK. QMK/TMK is an open-sourced code framework written in C/C++. It's more powerful but has a steeper learning curve than bootmapper client. You will have to install a lot of dependency packages on your computer, compile the source codes, and flash the hex file to get the firmware updated. It can be compiled on most Linux distributions, Windows, and OS X.
The 32A version can also be programmed with QMK in theory. I won't bother to port the code tho.
The 32A version we provide in this GB comes with USB mini female connector. The 32u4 version comes with USB Type C female connector. The Type C connector is a little better than mini  on the design perspective in my opinion, not that good you need to throw away a fancy Yarbo cable to get this version tho.
TL; DR: You are a newbie, you are lazy, choose 32A version. You write codes, you are cool, choose 32u4 version.
Offline oldcat
  • 65% is Life
« Reply #123 on: Tue, 24 April 2018, 01:23:13 »
Haha very good summary!
Offline macclack
    • Macclack
« Reply #124 on: Tue, 24 April 2018, 15:48:12 »
So I guess that makes me lazy and uncool ;)
Offline oldcat
  • 65% is Life
« Reply #125 on: Tue, 24 April 2018, 22:36:27 »
People who write codes = cool people? haha! Need to start writing some codes.
Offline Kevadu
« Reply #126 on: Tue, 24 April 2018, 23:05:14 »
I write code and I am definitely not cool...
Offline senter
« Reply #127 on: Tue, 24 April 2018, 23:13:46 »
Most developers would think compiling QMK codes is cooler than just using a software.
Writing codes is skill everyone should try. It's not just about cool. There's a lot of fun as well. :)
Offline senter
« Reply #128 on: Tue, 24 April 2018, 23:17:06 »
Try to learn some niche PLs such as Lisp/Haskell if you haven't yet. At least other people will think you are cool.
Offline oldcat
  • 65% is Life
« Reply #129 on: Wed, 25 April 2018, 00:07:48 »
I used emacs a while back... now back to Sublime Text. Problem is that I don't use programming that often, easy to forget if you don't always use it...
Offline oldcat
  • 65% is Life
« Reply #130 on: Wed, 25 April 2018, 00:09:02 »
By the way, please kindly consider doing a 65% Orange/Pizza GB one day :)
Offline M
« Reply #131 on: Wed, 25 April 2018, 00:50:47 »
GB will end on April 18th 23:59:59 PDT.
Don't miss out the last GB (most likely) of Orange series.
chances seem slim...
Offline oldcat
  • 65% is Life
« Reply #132 on: Wed, 25 April 2018, 16:05:24 »
 :eek: :eek:
Offline oldcat
  • 65% is Life
« Reply #133 on: Fri, 27 April 2018, 00:44:18 »
Will a plate-mounted stab work in this pcb/plate? Or only cherry? Is this what we are supposed to buy: https://kbdfans.cn/collections/keyboard-part/products/cherry-original-pcb-stabilizers
Thank you very much. Trying to stock the stab to prepare for the beauty.
Offline senter
« Reply #134 on: Fri, 27 April 2018, 11:37:09 »
PCB mount stabs. The ones you linked are correct. The spacebar also supports costar stab.
Don't forget to follow Nathan's ultimate guide when you install the stabs.
Offline oldcat
  • 65% is Life
« Reply #135 on: Fri, 27 April 2018, 18:23:58 »
Thanks very much! This is very helpful!
Offline jlee755
« Reply #136 on: Mon, 21 May 2018, 10:53:46 »
Aww bummer, I had no idea this keyboard existed! (New to the scene). Hope they turn out as beautiful as the images!  :thumb:
Offline oldcat
  • 65% is Life
« Reply #137 on: Mon, 04 June 2018, 12:07:13 »
Ordered a MAO color, can't wait!
Offline TechieWeirdo
« Reply #138 on: Sat, 09 June 2018, 07:33:05 »
Update?
b o a r d s
Offline dimo
« Reply #139 on: Sat, 09 June 2018, 12:06:50 »
Update?
yuh..
Offline 112227
« Reply #140 on: Tue, 12 June 2018, 12:28:04 »
https://imgur.com/a/izXJXdh
Someone posted this on reddit earlier today, looks great.
« Reply #141 on: Wed, 13 June 2018, 05:07:20 »
That green looks sick! But would love to have an official update from senter, just to see how everything is going.
b o a r d s
Offline oldcat
  • 65% is Life
« Reply #142 on: Fri, 15 June 2018, 23:57:46 »
Yeah, waiting patiently here. Wondering if this will ship on time :)
Will be an endgame one!
Offline dimo
« Reply #143 on: Sat, 16 June 2018, 14:47:17 »
was that even a color option? or are they just messing around with colors.
Offline oldcat
  • 65% is Life
« Reply #144 on: Sat, 16 June 2018, 22:00:03 »
Someone already got this??? wow the speed...
Offline dimo
« Reply #145 on: Sun, 17 June 2018, 11:57:29 »
don't think they're shipping yet, u/runninghack (the one who posted it) is one of the gb organizers.
But this might mean they’re shipping soon.
Offline oldcat
  • 65% is Life
« Reply #146 on: Mon, 18 June 2018, 02:24:31 »
Looks amazing! Can't wait!
Offline dimo
« Reply #147 on: Wed, 20 June 2018, 18:29:40 »
Did they ever say what connector the PCB would be?
Offline moonmembrane
« Reply #148 on: Wed, 20 June 2018, 22:23:16 »
You choose between two PCB's. One is Type C and Mini for the other.
« Reply #149 on: Wed, 20 June 2018, 22:35:27 »
QMK is USB-C, Bootmapper is Mini
b o a r d s
