Author Topic: [opensource] TOAD v2 | 70% keyboard | Now with Alps and aluminum case.  (Read 231736 times)
Offline TalkingTree
    • My projects
Re: [opensource] TOAD v2 | 70% keyboard | Now with Alps and aluminum case.
« Reply #100 on: Thu, 25 June 2020, 09:07:23 »
I have noticed that the usb-C connector you have used on your design, seems that it does not support data transference. The pins connected to the signal D+ and D- are connected to the signals CC1 and CC2 as seen in the datasheet.
Indeed, it won't work. I'll have to change it. Thanks for the heads up.
Edit: changed to 16 pins.
« Last Edit: Thu, 25 June 2020, 11:23:23 by TalkingTree »
Offline Kabonkers
« Reply #101 on: Tue, 22 September 2020, 18:26:23 »
I've recently bought the parts to make my own TOAD using the rev4 pcb and I can't for the life of me solder the usb-c in place. The pads are directly under the pins which make it hard to stick a soldering iron down there without melting the plastic on the usb-c and using a heatgun to try and solder it on just isn't working. Any tips on how to solder this usb-c down? It's hard to find any videos of people soldering something like this.
« Last Edit: Tue, 22 September 2020, 19:20:23 by Kabonkers »
Offline TalkingTree
    • My projects
« Reply #102 on: Sun, 22 November 2020, 13:12:35 »
I finally managed to make RGB LEDs work. Two will be then featured on the TOAD in the near future.
Sadly EasyAVR won't support it so now it's QMK firmware alone.
Huge thanks to nevin who helped me figure out the code.
Here's a demo on a breadboard:
Offline treeleaf64
    • treeleaf64
« Reply #103 on: Tue, 15 December 2020, 12:30:17 »
I will look into this.
Everyone must pay the cat tax
« Reply #104 on: Tue, 15 December 2020, 16:12:32 »
so sad I never got mine built, got too sad after I messed up cutting the plate :( loved seeing all the progress and other people's builds though.
Offline TalkingTree
    • My projects
« Reply #105 on: Wed, 16 December 2020, 01:23:28 »
Too bad for you. It means that you'll have to buy one from the upcoming GB.
« Reply #106 on: Wed, 16 December 2020, 04:56:41 »
CAN'T WAIT
still have the OG pcb in pristine condition, maybe i'll frame it
Offline mj1212
« Reply #107 on: Mon, 21 December 2020, 01:06:17 »
I was looking for a an open source 60% case and stumbled on this thread. This is amazing. This thread provided me lot of info on creating a custom case. Really appreciate the work of the designer. Thank you so much for putting all the effort on this and giving it to the community.
Offline moxie keyboards
« Reply #108 on: Tue, 22 December 2020, 17:00:56 »
Thank you for documenting this build, it is helping me greatly!
Offline TalkingTree
    • My projects
« Reply #109 on: Sun, 24 January 2021, 12:27:04 »
I put a couple of PCBs together and I can confirm that everything works as intended.
I'm in touch with a vendor in the community to organize a group buy but I'll be fine tuning a couple of things with the case first.
Offline TalkingTree
    • My projects
« Reply #110 on: Thu, 28 January 2021, 14:22:21 »
I put a rev.4 into the original case and everything fits perfectly.
Here's a test with RGB LED indicators.
Offline Earther
« Reply #111 on: Sat, 30 January 2021, 04:20:20 »
This is truly amazing, that you chose to open source your project. But there is a problem. The source file links for the case is not working. Did you change your mind about open sourcing the case?
Offline TalkingTree
    • My projects
« Reply #112 on: Sat, 30 January 2021, 05:49:52 »
Nope, I've redesigned it from the ground up but I'm testing a few details. I'll be publishing the .f3d file as soon as I'm sure it's good to go.
Offline meklahi
« Reply #113 on: Sun, 10 October 2021, 22:43:37 »
is it possible to support f13 key in the next iteration?
Offline grayboards
« Reply #114 on: Sat, 30 October 2021, 02:19:09 »
clean
Offline neru
« Reply #115 on: Thu, 18 November 2021, 02:23:26 »
I've been eyeing this project for a good 2 months and I think now is a good time to tackle it. However, there is still one thing, the online cad viewer simply doesn't let me download the files and also the google drive link is dead. May I ask about the new link to download?
Offline ToCHoNeR
« Reply #116 on: Thu, 25 November 2021, 07:21:14 »
Man awesome work. I can only say thanks for all the efford and time you put on this project. I read in between that you were thinking about a GB. Are there any plans on that moving forward?? I would like to participate for sure!
Offline HappyB0T
  • I'm a Piggie
« Reply #117 on: Wed, 12 January 2022, 12:09:24 »
This project is awesome - looking forward if you get to a GB. I really wish the community had more contributors like you. Keep up the fantastic work!
Offline PlayBox
« Reply #118 on: Sun, 11 September 2022, 06:18:49 »
hello so i want to make my own pcb for it and i want it to be f13 and also elite-c/pro micro compatible how do i do it?
propably sent from my amazon kindle 10th gen
