Author Topic: Tina-C source code.  (Read 2499 times)
Offline Sup
Tina-C source code.
« on: Thu, 12 April 2018, 14:45:31 »
So i bought a Tina-c kit at the moment i am working on the layout. I am trying to download the source code from Qmkkeyboard.cn trough firefox but i can only download the hex file and not the source file i get the error Unable to retrieve files. I fixed the 7u problem trough changing the wires. But i would like to add different RGB profiles. Anyone got a source file for Tina-C or a solution?
Help would be appreciated. :)
Edit: nvm figured it out
I just edited a exisiting layout in the QMK DZ60 folder and compiled it and then flashed the board :).
« Last Edit: Sat, 14 April 2018, 16:57:26 by Sup »
current
Coming soon
Offline jedazar
Re: Tina-C source code.
« Reply #1 on: Fri, 13 April 2018, 20:53:27 »
I was using qmkeyboard.cn for my Tina-C with no issues at all last night on Chrome, have you tried a different browser? When you say the source file, do you mean the .json?
Offline nguyenhimself
« Reply #2 on: Fri, 13 April 2018, 21:08:03 »
Wow, a real-life, circa-2018 "nvm figured it out also screw you if you're trying to solve the same problem figure it out yourself" post.
I can't believe these still exist.
Offline Sup
« Reply #3 on: Sat, 14 April 2018, 16:36:35 »
current
Coming soon
