Author Topic: A minimalistic way to mount the pro micro  (Read 3871 times)
Offline ju6ju8Oo
« on: Fri, 13 April 2018, 08:24:00 »
Is there a minimalistic way to mount the pro micro in a 3d printed case, without PCB?
Offline AMongoose
  • happy workman user
Re: A minimalistic way to mount the pro micro
« Reply #1 on: Fri, 13 April 2018, 08:46:02 »
hot glue  :))
Offline TalkingTree
    • My projects
« Reply #2 on: Fri, 13 April 2018, 08:46:32 »
Hot glue.
Offline Phenix
« Reply #3 on: Fri, 13 April 2018, 08:54:37 »
some sort of "rails" to slip it in. hot glue is easier and cheaper tough
Winter is coming.
Offline ju6ju8Oo
« Reply #4 on: Fri, 13 April 2018, 09:05:58 »
There's a 'rail' in dactyl manuform. I'm thinking of a similar way but with a smaller footprint.
Instead of mounting the pro micro on the longer side, maybe I can mount it on its shorter side and the pin headers?
Also maybe I can use a mix of right angle / straight male pin header. Or use 2 of the pin headers for mounting.
« Last Edit: Fri, 13 April 2018, 09:50:16 by ju6ju8Oo »
Offline Tactile
« Reply #5 on: Fri, 13 April 2018, 11:38:03 »
If, in your 3D printing, you can add a small ridge behind the Pro Micro, that should do it. You just need a firm surface behind for support when the cable is pushed in. For when the cable is pulled out, the case wall should work as support and prevent the Pro micro from moving. I have a similar setup in one of my keyboards but not a 3D printed case. To prevent the Pro Micro from shifting side to side, I just taped it down with Kapton tape. Works great.
REΛLFORCE
Offline ju6ju8Oo
« Reply #6 on: Sat, 14 April 2018, 06:54:40 »
Kapton tape seems to be 'cleaner' than duct tape or hot glue :P let me try that
