Author Topic: Need help with Custom Matias Board  (Read 2228 times)
Offline MackMattacker
« on: Thu, 19 April 2018, 16:27:12 »
Good afternoon everyone. I am looking to custom build a board using the new matias quiet linear switches. These are the plate mounted switches and I cannot solder switches. I was wondering if anyone had any suggestions for PCB, plate, and case for this build. Another option I was considering was taking a matias keyboard and replacing the switches.
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Need help with Custom Matias Board
« Reply #1 on: Thu, 19 April 2018, 17:45:34 »
If you can't solder and you aren't willing to learn, you'll need someone to do it for you. As far as I know there are not any PCBs with Alps/Matias compatible hotswapping.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #2 on: Wed, 25 April 2018, 23:34:14 »
I would wager that a KBParadise V80 Matias QC board would be worth the same new as it would with all the switches desoldered and removed with out damage... maybe worth more as a bare kit that people could then solder in SKCM or whatever they wanted.
-Dana
Offline nguyenhimself
« Reply #3 on: Wed, 25 April 2018, 23:43:42 »
Well I'm kinda-sorta maintaining a list of Alps-compatible PCBs and plates here, though admittedly I'm not sure if Alps-compatible = Matias-compatible.
And unless you know someone who can solder for you, you won't be able to avoid that part.
« Last Edit: Thu, 26 April 2018, 01:59:30 by nguyenhimself »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Thu, 26 April 2018, 01:25:11 »
Matias switches are 99% compatible with Alps switches, they are copies of the Alps SKBx (simplified) series. If I remember correctly, Matias actually uses Forward's old equipment since they stopped manufacturing SKBx switches about a decade ago, but this is second hand knowledge and I have no source to confirm that with.
