Author Topic: [IC] Createboard 60% Solid Wood Case (GB is currently live)  (Read 16180 times)
Offline Createboardhk
    • Createboard
Re: [IC] Createboard 60% Solid Wood Case (Update :22/5/2018)
« Reply #50 on: Sun, 27 May 2018, 08:46:23 »
Are you referring to the first case (the one without keycaps and everything?)
Our second update (the one with keycaps) is indeed the second case as we adjusted the angles and ask the factory to adapt.
Design-wise we didn't change much really, but we would also like to say since each and every case is polished by hand in the end, so there may be slight differences. :)
The GB of the wood case has started. You can see more details in the following link.
GB link: https://geekhack.org/index.php?topic=95817.0
