Author Topic: You need to buy a Leopold now!  (Read 60713 times)
Offline Colourr
  • no worries
Re: You need to buy a Leopold now!
« Reply #50 on: Sat, 02 June 2018, 10:40:47 »
Trying to find a 980m myself!
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #51 on: Wed, 06 June 2018, 23:13:20 »
It's so hard to decide because they just have so many good ones, but Leopold FC750R PD might be the one to go!!
Offline crystalflame
« Reply #52 on: Wed, 06 June 2018, 23:54:47 »
I use this FC 900R in Navy with browns. I absolutely love it. Definitely agree that it's an amazing out of the box keyboard.
Offline LiL_BrOwNiE247
« Reply #53 on: Thu, 07 June 2018, 08:58:44 »
I'm still hoping to get my hands on a FC660C some day...  ^-^
You won't regret it once you get one, that's for sure. I've been using mine at work everyday for the past several months and it's been amazing. The form factor is perfect, the steel plate is nice and sturdy, and the simple keycap design doesn't stand out at all at the office.
Offline Kilgarah
« Reply #54 on: Thu, 07 June 2018, 08:59:04 »
My 660C is my work driver. They really are fantastic boards. Amazing build quality.
Sent from my SM-G955U1 using Tapatalk
Offline hyperlite218
« Reply #55 on: Thu, 07 June 2018, 18:14:59 »
How does the new fc660c compare to the old one? I've got a 2017 660c that i'm in love with already.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #56 on: Thu, 07 June 2018, 18:55:12 »
Too new to make an assessment it seems. Some people are happy, others are reporting issues...
« Reply #57 on: Thu, 07 June 2018, 20:22:10 »
Thats what i've heard. Supposedly the new keycaps are worse than the old ones
Offline Dennyroxsox
  • a.k.a. Lollipopsaurus
« Reply #58 on: Fri, 08 June 2018, 11:54:31 »
Are the new versions available in the West? What retailer has them?
Offline AugustCanaille
« Reply #59 on: Fri, 08 June 2018, 15:37:03 »
I just bought one in May, from Widebasket on eBay, with the black on black legends. I'm not sure how they compare to the old ones, but I bought some KBDfans alphas and the thock is virtually the same.
Offline giangtran19x
« Reply #60 on: Fri, 08 June 2018, 19:27:16 »
 :p
Offline rob2stepin
« Reply #61 on: Thu, 20 August 2020, 02:10:36 »
I realize that this is an older topic, but I got a Leopold FC750 pd with Cherry silent reds. I noticed that it had more dampening felt under the spacebar and above the nav cluster. I also noticed that the stabs were already clipped. I am not sure if this is new from Leopold. I freaking love this thing. I just finished desoldering it and will be adding Durock T1s tonight.
Offline HungerMechanic
« Reply #62 on: Thu, 20 August 2020, 11:33:47 »
If the Leopold Star tactile switches are actually good, and they are actually fitted into Leopold keyboards that you can buy, then we really will have to buy Leopolds right now!
And no desoldering needed!
