Author Topic: [IC] Keyboard Storage Rack  (Read 9152 times)
Offline Peppermint216
« on: Sun, 29 April 2018, 06:12:21 »
Checking for interest in an acrylic storage rack.
After a very crudely made wood version I thought acrylic would be much nicer.
- 9 Slots
- Maximum thickness for smallest insert: 55mm
- Maximum thickness for biggest insert: 75mm 70mm
- 15° 21° seating angle
- Supplied foam tape for seating edge
- Total length: 700mm
- Minimum keyboard size: 60% or 250mm
194772-0
« Last Edit: Mon, 30 April 2018, 15:02:18 by Peppermint216 »
Re: [IC] Keyboard Storage Rack
« Reply #1 on: Sun, 29 April 2018, 06:37:57 »
The wood version I made
Offline xondat
  • i'm not a star
« Reply #2 on: Sun, 29 April 2018, 06:40:22 »
That angle looks too shallow imo. Maybe something like 25 would give more confidence :p
Anyway, I like the idea so I'll be following this.
Offline Ponkan
« Reply #3 on: Sun, 29 April 2018, 08:54:12 »
Would be very interested! I agree w/ xondat making the angle around 25d.
« Reply #4 on: Sun, 29 April 2018, 08:59:34 »
I've adjusted the angle to 21 degrees, any more and the dimensions would have to change. Based on a 1:1 printout, 21 should be more thank enough, much better than 15.
Offline Makerthink
« Reply #5 on: Sun, 29 April 2018, 09:25:46 »
I think I can make some especially designed for each keyboard, by 3d printing.
从我的 iPad 发送,使用 Tapatalk
Online LightningXI
  • PPD
    • ArtisanMacro
« Reply #6 on: Sun, 29 April 2018, 09:32:44 »
I'm very interested.
Sent from my mobile using Tapatalk
Offline vewy_nice
« Reply #7 on: Mon, 30 April 2018, 08:23:58 »
I'd be VERY interested in a wall-mounted option, with longer shelves with little "fingers" on the end to "display" the keys at a shallow angle... (I don't have much desk space)
But you just do you! I'm just spouting ideas ;)
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #8 on: Mon, 30 April 2018, 09:15:30 »
I actually like the wood one quite a bit! Especially if it had some kind of non skid feet to prevent sliding around on a shelf.
Offline Kyi195
« Reply #9 on: Mon, 30 April 2018, 09:33:25 »
+1 for a wooden wall-mounted rack.  In the same boat as vewy_nice where I don't have much desk space but I could mount it to the side of my desk or the wall next to it if need be.
Offline kennardsmith
« Reply #10 on: Mon, 30 April 2018, 12:34:02 »
oh yes i would buy this
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline Darknight00z
« Reply #11 on: Mon, 30 April 2018, 12:50:14 »
I actually would prefer Wood over acrylic.
Offline kidcongo
« Reply #12 on: Mon, 30 April 2018, 12:51:06 »
How about laser cut plywood?
« Reply #13 on: Mon, 30 April 2018, 13:37:19 »
What is everybody's price expectation? Based on my first couple of laser cut quoted, 50GBP/70USD without postage. It's a lot more than I wanted, the acrylic accounts for 34GBP and the little brass cubes for mounting add an extra 9GBP. The price above is based on an MOQ of 20.
I've also requested CNC quotes and some plywood quotes.
What is your main concern with the acrylic version, I can assure the build will be solid. I was thinking black, frost, opaque acrylic. Feet to prevent sliding will be included.
Offline odd
« Reply #14 on: Tue, 01 May 2018, 05:24:04 »
I'll take 4 of them please  :thumb:
Offline parityb1t
  • 60% or less \m/
« Reply #15 on: Wed, 09 May 2018, 18:40:16 »
interested in this :) personally have no preference between wood and acrylic tbh. so long as there is weight to it, its fine imo.
Alps64 w/ Orange Alps | SatanGH60 Gartistotles
Offline parityb1t
  • 60% or less \m/
« Reply #16 on: Wed, 09 May 2018, 18:46:07 »
I think at MOQ 20, 50GBP if you're cutting in the UK is sort of expected :P could I ask what happens if you make dimensions smaller? i.e. so 50% instead of 60% I guess, would that recude cost and simultaneously still able to cater for most boards thats 60% and not sacrifice rigidity etc.?
Also, if there's enough interest, a 40% version for those of us with 40-60% XD (I will not go as far as asking 30% just for the gherkin lol)
Offline foxmancore
« Reply #17 on: Thu, 10 May 2018, 00:12:11 »
In for one!
Offline ullr
« Reply #18 on: Sun, 24 June 2018, 15:32:54 »
Any further interest in this? I'm running out of space on my shelf...
Offline dimo
« Reply #19 on: Sun, 24 June 2018, 21:40:51 »
What’s the difference in what you’re doing to Typearrays?
