Author Topic: Gamdias Hermes M3 -any thoughts on this keyboard?  (Read 3345 times)
Offline coccosoids
  • A?
« on: Wed, 16 May 2018, 06:50:27 »
Hi guys.
So do you have any thoughts on this keyboard? Anything better in the price range? It's about 73E/$ in my region. Brown gamdias switches -whatever those are.
Here is a link: http://www.gamdias.com/products-en-gb/keyboards/hermes-m3-rgb-en-gb
Thanks
Offline ag36
Re: Gamdias Hermes M3 -any thoughts on this keyboard?
« Reply #1 on: Thu, 17 May 2018, 05:45:52 »
As long as you like low profile switch, but this look very overpriced. Non cherry rgb are usually around 20~50€.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2 on: Thu, 17 May 2018, 06:28:31 »
Looks like a cheap overseas keyboard with low profile switches.
Probably a medium quality board with mediocre keycaps. If you like RGB and low profile I guess it's fine though.
Offline coccosoids
  • A?
« Reply #3 on: Thu, 17 May 2018, 07:07:26 »
I can't find anything cheaper in my region... or alas -I don't know what to look for. Anything comes to mind?
I think I do prefer low profile -I once played with a Logitech G Pro TKL keyboard and didn't like it at all. Not a sucker for RGB but some kind of backlighting is welcome.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Thu, 17 May 2018, 09:42:04 »
Gamdias' older stuff was actually quite good - I own the Gamdias GKB2010 which had genuine Cherry MX Red switches. I haven't kept up with the company as of late though, and if they are now using their own switches then they have probably lowered the quality of their stuff quite a bit. I'm going to guess that they are probably rebranded versions of Kailh's new low-profile switch, which may or may not be as good as their regular MX-compatible line.
Offline ag36
« Reply #5 on: Thu, 17 May 2018, 09:54:54 »
Which region are you at? For Chinese budget boards I usually browse on Amazon.co.uk presumably your local Amazon sell them too, alternatively go ebay.
https://www.amazon.co.uk/s/ref=nb_sb_ss_i_3_5?url=search-alias%3Daps&field-keywords=mechanical+keyboard&sprefix=mecha%2Caps%2C147&crid=1LW5K0CV4SCFL
Edit: If this is using kailh low profile then replacement keycaps can be hard to get,
« Last Edit: Thu, 17 May 2018, 12:54:37 by ag36 »
