Author Topic: Suggestions for 60% cases with backlight?  (Read 3123 times)
Offline pentawater
« on: Wed, 16 May 2018, 18:46:52 »
I'm looking for a metal case with acrylic windows' which would show off backlighting from a DZ60 in the standard Pok3r layout without going full acrylic. Some cases I'm considering currently are the Sentraq sandwich case, and this guy https://www.aliexpress.com/item/Anodized-Aluminium-case-for-xd60-xd64-60-custom-keyboard-acrylic-panels-acrylic-diffuser-can-support-gh60/32823154578.html.
Loose upper bound on the price of $300, although the Duck Eagle is intriguing.
Offline Sup
Re: Suggestions for 60% cases with backlight?
« Reply #1 on: Fri, 18 May 2018, 02:31:33 »
KBDFans Tina keyboard.
current
Coming soon
Offline ptykozoon
« Reply #2 on: Fri, 18 May 2018, 17:29:43 »
« Reply #3 on: Fri, 18 May 2018, 19:19:36 »
The term you are seeking is "underglow". Backlighting does not need any special case.
Offline mjin03
« Reply #4 on: Sun, 20 May 2018, 10:00:58 »
I really only know of 3 cases with acrylic insert underglow for 60%.
* XD64 kit from Massdrop,
* Tina from KBD fans
* Aliexpress one you linked.
You probably can't get the Massdrop one and the Tina only has acrylic towards the back half of the keyboard. I think the one you found is probably the best choice at this point but I cannot say anything about it's quality as I have never seen it in real life.
NightfoxCampingXD64CarbonCorsair K70RGB
Offline bluwrain
« Reply #5 on: Thu, 24 May 2018, 18:32:19 »
I have a tina-c with a dz60 and lubed 62g outemu ice and I have to say this is one of the nicest boards. The backlighting is just perfect and the hhkb layout is a HUGE plus.
