Author Topic: Alps switch putting out double characters  (Read 3618 times)
« on: Thu, 17 May 2018, 19:56:33 »
I have a keyboard with Alps switches, a Dell AT-101W into which I transplanted orange Alps from an Apple.
It works great and I really like it but 2 of the switches sometimes return double characters from a single key press. The comma "," does it often, perhaps almost half the time, and the "s" does it perhaps 10%-20% of the time.
Any ideas on what might cause it, and/or should i just replace those 2?
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
Offline Delirious
Re: Alps switch putting out double characters
« Reply #1 on: Thu, 17 May 2018, 20:02:57 »
Yea the switchplates are getting worn-out and faulty. You can try to clean them with air duster see if that'll help. Most of the time I just replace them.
Offline Kilgarah
« Reply #2 on: Thu, 07 June 2018, 08:45:51 »
I'd replace the two switches. It could be some dust in the switch is causing it to chatter. Alps switches are notorious for easily collecting dirt.
Sent from my SM-G955U1 using Tapatalk
