Author Topic:  C³-LDN RGB80% PCB(Complete)  (Read 114475 times)
Re:  C³-LDN RGB80% PCB
« Reply #100 on: Wed, 30 May 2018, 21:16:14 »
Is it possible to get a TLDR about the custom PC plate working or not working with TX87 PCB?  I'm traveling and on super slow internet, with limited time to read.  Not talking about case compatibility but rather stabilizer placement and orientation.
judging by the picture posted above, it should work with TX87
Offline C³—Ears
« Reply #101 on: Thu, 31 May 2018, 00:04:13 »
It comes down to two things: plate (for stab orientation) and footprint (for whether or not it'll fit into the case)
The plate varies case by case, so it's hard to know for sure without testing. While stab orientation may not matter in the Mira, it might matter in an LZ CLS or an Eqaulz 80.
The B.87 standard is smaller than A.87, and the USB port is mounted differently on the Z-axis. This, again, comes down to a case-by-case basis. Some cases will have the USB port in a place that allows for easier access of a B.87 port, and some cases may not have the space to allow for an A.87 port.
The problem comes in with the TX87, which uses a slightly modified A.87 standard. This makes it closer to the size of a B.87 PCB, while still maintaining some aspects of an A.87 (stab orientation, USB port placement).
So, by my understanding, for any case that is confirmed to work with TX87, B.87 is the PCB to buy from this GB due to the slightly modified USB port placement to better suit A.87 cases. However, it mostly comes down to the case you're using. In some cases, the stab wires can only be used in one direction (TGR A.17 comes to mind)
This is my understanding of the situation.
Yeah,Most of this is correct. Since B.87 size is the most common size in China,we have this B.87 size. Our B.87 size are very similar to TX.87.The only difference is the stabs hole for spacebar so it come down to plate.So Tx.87 is like a modified B.87 to my opinion. But like you said it may not fit every TX.87 case. This is why we put measurement for the PCB,everyone should look into it and see if can fit in each case since we don't have the ablity to test every case.Anyway,if you send me a plate file for Tx.87 case plate,we can modify a little to make sure the stabs works fine.But other than that we can do nothing,like changing usb port size etc...
Offline C³—Ears
« Reply #102 on: Thu, 31 May 2018, 00:05:40 »
Is it possible to get a TLDR about the custom PC plate working or not working with TX87 PCB?  I'm traveling and on super slow internet, with limited time to read.  Not talking about case compatibility but rather stabilizer placement and orientation. I've been considering getting the PC plate for my MiRA SE to use with tX87 PCB.
Sorry i don't know what is TLDR. Our Mira PC plate is compatiable for Tx.87 PCB as well. So this should not be a problem...
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #103 on: Thu, 31 May 2018, 08:30:16 »
TLDR stands for "too long, didn't read," and is usually a request for someone to highlight the important points because it may take too long to read everything that has been said. I think you've already done that, though. =)
« Reply #104 on: Thu, 31 May 2018, 16:18:24 »
do your polycarb plates have uv resistance coating
Offline Stayfrostys
« Reply #105 on: Thu, 31 May 2018, 22:04:17 »
Hi, hopefully this will be my first PCB purchase, will this come with all the LED's and diodes pre soldered like in the pictures?
Sorry if this is a silly question also, How will we know if we are are selected to be in the GB?
Offline C³—Ears
« Reply #106 on: Thu, 31 May 2018, 23:53:49 »
I don't think so...
Offline C³—Ears
« Reply #107 on: Thu, 31 May 2018, 23:56:14 »
Everything is pre-soldered. So rest assure.
I havent send out every invoices. If you fill the form,you will receive a invoice from me.paid it on time then you are in.
Thanks :thumb: :thumb: :thumb:
Offline xtazy222
« Reply #108 on: Fri, 01 June 2018, 13:27:33 »
Would it be possible to make a version with north LED position and Kailh hot-swap socket? Or maybe in the future?
Offline Singular
« Reply #109 on: Mon, 04 June 2018, 15:23:10 »
Are invoices going out? Submitted a form a couple days ago, but haven't got an invoice at all.
Offline C³—Ears
« Reply #110 on: Tue, 05 June 2018, 00:58:30 »
sorry i will be away for 2days. There's a family emergency. Everything will be delayed for 2days. Haven't send out all the invoices and i will send out rest of them on Thursday. And i will give everyone 2 more days to pay.
Offline eyedrop
« Reply #111 on: Tue, 05 June 2018, 08:31:25 »
Hope everything will be ok.
Offline C³—Ears
« Reply #112 on: Thu, 07 June 2018, 02:56:22 »
Hi, I am back. Just send out all the invoices. I will give you guys some time to pay for it. The leadtime will remain the same. Thanks everyone for all your love ;D ;D
Offline foxmancore
« Reply #113 on: Thu, 07 June 2018, 03:03:11 »
any chance for alps support?
Offline C³—Ears
« Reply #114 on: Thu, 07 June 2018, 05:01:14 »
Maybe in the future. It will help if the need is strong.
Offline Unforgivable
« Reply #115 on: Mon, 11 June 2018, 17:05:49 »
Sent a pm whenever you have a free moment, C3.
Thank you!
Offline rainb1ood
  • so pretty so plastic
« Reply #116 on: Wed, 20 June 2018, 20:47:45 »
is it too late to order
Offline C³—Ears
« Reply #117 on: Thu, 21 June 2018, 02:00:46 »
sorry its late to join the buy. We will have extras only for a little bit more expensive.  ;D
« Reply #118 on: Thu, 21 June 2018, 09:15:14 »
I put in a form for a pcb but never ended up getting a invoice
Offline C³—Ears
« Reply #119 on: Fri, 22 June 2018, 03:30:07 »
sir your paypal address is not right and i have send you a pm. Please pm me your right paypal address.
Offline Butter
« Reply #120 on: Tue, 10 July 2018, 00:10:26 »
Any update?
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #121 on: Tue, 10 July 2018, 00:55:58 »
70 days after end of May though.
Offline rainb1ood
« Reply #122 on: Tue, 31 July 2018, 12:48:15 »
any extras yet available? :D
Offline redbanshee
  • actually Dade Murphy
« Reply #123 on: Tue, 31 July 2018, 14:14:59 »
We are on day 54 of 70
 :thumb:
Offline C³—Ears
« Reply #124 on: Fri, 17 August 2018, 07:34:32 »
PCB is ready and we have received them. We are testing them right now and will be send out asap.
Offline redbanshee
« Reply #125 on: Fri, 17 August 2018, 11:36:27 »
Offline pikku-allu
  • IG: @kinnalek
« Reply #126 on: Fri, 17 August 2018, 13:18:43 »
Great! How about the polycarbonate plates?
Offline Photoelectric
« Reply #127 on: Fri, 17 August 2018, 13:20:50 »
Thank you for the update!
Offline C³—Ears
« Reply #128 on: Sat, 18 August 2018, 00:15:41 »
Ready as well except custom ones,packing will be arrived in 1 or 2 days and we will starting shipping.
Offline vtachkov
« Reply #129 on: Sat, 18 August 2018, 13:26:20 »
The form is still open, are you still taking orders or have extras?
Offline C³—Ears
« Reply #130 on: Sat, 18 August 2018, 14:03:16 »
Sorry forget to close it....
Offline C³—Ears
« Reply #131 on: Sun, 19 August 2018, 06:32:26 »
Hi everyone
Packing is here. We are ready to go.
202181-0
« Reply #132 on: Sun, 19 August 2018, 10:32:08 »
Hi everyone
nice
Offline vtachkov
« Reply #133 on: Sun, 19 August 2018, 21:17:53 »
Aw, well if there are any extras after the current orders ship out, I'd be interested in one.
Offline C³—Ears
« Reply #134 on: Tue, 21 August 2018, 00:24:22 »
Yes,there will some stocks. Just you have to pay 10 more dollars each PCB.
Offline rainb1ood
« Reply #135 on: Wed, 22 August 2018, 10:39:47 »
Sign me up for extras please
Offline HouseofSuffering
« Reply #136 on: Wed, 22 August 2018, 12:15:36 »
I would also be interested in a leftover PCB as well.
« Reply #137 on: Mon, 27 August 2018, 17:52:07 »
Is there a possibility that this PCB will see a second run?
Offline C³—Ears
« Reply #138 on: Tue, 28 August 2018, 09:00:39 »
Yup,R2 will happen. We will do some feedbacks to see if this PCB is good enough.Then we can move on to R2 and other layouts
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #139 on: Wed, 29 August 2018, 21:57:41 »
Any word on when these will ship?
Offline C³—Ears
« Reply #140 on: Mon, 03 September 2018, 01:27:31 »
All shipped out. I will start filling tracking numbers today.Thanks everyone.
Offline macclack
    • Macclack
« Reply #141 on: Tue, 04 September 2018, 00:01:09 »
 :thumb:
Offline C³—Ears
« Reply #142 on: Tue, 04 September 2018, 08:20:48 »
Everyone please check your tracking number and let me know if there's anything goes wrong with shipping,thanks.
Offline derpaphobia
« Reply #143 on: Tue, 04 September 2018, 12:28:48 »
Omg... This is exactly what I've been looking for... and I missed out T.T GGlife
« Reply #144 on: Wed, 05 September 2018, 09:47:50 »
Got my PCB and polyplate. The packaging is so well done and protected.
Kudos to you, Ears!.
Offline razor_blade
« Reply #145 on: Wed, 05 September 2018, 21:46:23 »
I would be extremely pleased if someone with a TX87/TX84SE could double check fit. I'd love to snag an extra and a poly plate, if they do.
Offline Helldrop
« Reply #146 on: Thu, 06 September 2018, 02:37:28 »
Finally got my PCB! The packaging is gorgeous.
Thanks C³—Ears.
« Reply #147 on: Thu, 06 September 2018, 12:21:49 »
This is supposed to fit MIRA SE, and MIRA SE was distributed with TX87 PCBs.  So it should fit in TX86/TX84SE.
Offline redbanshee
« Reply #148 on: Thu, 06 September 2018, 12:36:48 »
The pcb offered here will fit both those boards but the polycarb plate c3 is offering will not fit either one of those boards
Offline razor_blade
« Reply #149 on: Thu, 06 September 2018, 22:14:04 »
Thanks! Looking forward to an extra.
