Author Topic:  C³-LDN RGB80% PCB(Complete)  (Read 118446 times)
Offline derpaphobia
Re:  C³-LDN RGB80% PCB
« Reply #200 on: Sun, 07 October 2018, 11:17:15 »
^this^
Offline C³—Ears
« Reply #201 on: Sun, 07 October 2018, 14:00:33 »
BTW,i would be really appreciate if anyone tell me if this pcb fit in other custom keyboards...i want to try to make another run later this year.
Would be great to have another round of these! USB-C maybe?
I have both size type c made for my future gb. But if you just buy type c pcb,can it fit in your case? I thought most of the case out there dont fit in type c
Offline Velvet_Crowe
« Reply #202 on: Sun, 07 October 2018, 14:17:57 »
well after a couple days of use, my c3 pcb just randomly died. Windows is giving me the USB not recognized error... I removed all my stabilizer screws as well but that wasnt the problem
edit: good guy C3 helping me with replacement
« Last Edit: Mon, 08 October 2018, 01:44:46 by Velvet_Crowe »
Current daily: OTD 356mini v1 (Red) | OTD 356CL (Gunmetal) | TGR Jane V2 CE (Black) | zekk.works Ogre (Dark Grey) | Noxary Vulcan Pro (Silver/Red) | 488 Pista Spider (Red)
Offline C³—Ears
« Reply #203 on: Mon, 08 October 2018, 01:29:59 »
well after a couple days of use, my c3 pcb just randomly died. Windows is giving me the USB not recognized error... not sure if unlucky or bad QC. I removed all my stabilizer screws as well but that wasnt the problem
Well, try to press B+L when you connect the PCB and see if it can enter bootloader,and if you can just upload the firmware again. If can't let me know,i will replace it for you. You know my QQ anyway,find me there.
Offline dorf
  • divine creator
« Reply #204 on: Mon, 08 October 2018, 03:51:55 »
This kind of support makes me wanna buy ten of these pcbs. Great work!
Offline C³—Ears
« Reply #205 on: Mon, 08 October 2018, 07:37:02 »
Thanks for the kind word,sir. It's just something we should do. It's normal to have issues,just need to fix them when that happens.Plus,this wont be the only round for the PCBs and i am trying to find out all the problems and improve them.Hopefully we can be a major maker in this community one day. :thumb: :thumb: :thumb:
Offline phatty
    • dailyclack.com
« Reply #206 on: Mon, 08 October 2018, 08:11:16 »
I'm keen for one of these. I'd love to test if it fits into my MIR.
Offline C³—Ears
« Reply #207 on: Mon, 08 October 2018, 09:37:12 »
what is MIR? also we have 2 kinds of size. Should fit a lot of borads.
Offline redbanshee
  • actually Dade Murphy
« Reply #208 on: Mon, 08 October 2018, 11:27:59 »
Ears, if i could suggest things for a new run it would be to modify your b.87 to be south spacebar stabs and change the footprint a little along the bottom like this: https://i.imgur.com/SuO2B9V.jpg
Or try the new pear shaped holes some guys are using now (h87a pcb) Very very few plates use north stabs anymore.
see tkl pcb compat list here (i think that i showed you this before but its much better now): https://docs.google.com/spreadsheets/d/1GpM--fKeDw_tIDZj4m2jmbMavSyXeOu3QHzfTJwz-IM
other then the north stab thing this b.87 pcb is pretty good! i will put one in keycult no.1 next week
« Last Edit: Mon, 08 October 2018, 11:33:18 by redbanshee »
Offline redbanshee
« Reply #209 on: Wed, 10 October 2018, 10:48:06 »
c3 ldn b.87 does not fit the keycult stock plate (spacebar stab wires hit plate) there is an aftermarket fr4 plate for the keycult that it does fit tho.
Offline C³—Ears
« Reply #210 on: Wed, 10 October 2018, 11:24:18 »
Thank you for your feedback,i really need this information. I will change the spacebar stabs next time. Let me make some samples to figure out what's the best options.
Plus,i know you made that form on google and i really appreciate all the work you done.
I am using 2 of these PCBs now and i have no issues so i really need people to tell me if there's any issues. So thank you,sir.You been so helpful. :thumb: :thumb: :thumb:
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #211 on: Wed, 10 October 2018, 11:39:36 »
Still one of my favourite GB runners here on GH. Cheers Ears!
Offline yonghf
« Reply #212 on: Fri, 12 October 2018, 05:32:19 »
Any extras or another buy soon?
Offline C³—Ears
« Reply #213 on: Fri, 12 October 2018, 19:07:09 »
No extras left and working on the next buy now.
Offline Darknight00z
« Reply #214 on: Sat, 13 October 2018, 17:24:50 »
Any chance for QMK in R2?
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #215 on: Sat, 13 October 2018, 21:46:50 »
60% when :eyes:
Offline C³—Ears
« Reply #216 on: Sat, 13 October 2018, 22:26:00 »
Sorry,no plan for QMK anytime soon.
Offline C³—Ears
« Reply #217 on: Sat, 13 October 2018, 22:28:03 »
60% when :eyes:
Around 2 months....We are working that and first sample is made.We still need to working on software and test for durability.
Offline taropaste
« Reply #218 on: Sun, 18 November 2018, 12:01:41 »
Are you going to do 60% next or round 2 80%?
Also, any updates on the keyboard kit you mentioned earlier? I would love to buy an all acrylic or all polycarbonate board for the full RGB experience with your pcb :)). Something like the TGR A17 or the GON Acrylic TKL or the acrylic Unicorn.
Offline C³—Ears
« Reply #219 on: Mon, 19 November 2018, 03:48:34 »
Round 2 80% comes first then 60% we still working on that 60% PCB.
We are making samples for that kit now,so stay tunned!!!
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
« Reply #220 on: Tue, 20 November 2018, 00:20:52 »
Hello, I have a C3 PCB and I turned off the RGB backlight (not the underglow) and I can't seem to turn it back on, please help!
Offline C³—Ears
« Reply #221 on: Tue, 20 November 2018, 06:51:23 »
Can you try to turn it on using our software? please wait a little bit when you turn it to another effect.
Thanks, and please let me know if that works.
  • formerly honsoo
« Reply #222 on: Tue, 20 November 2018, 19:38:13 »
I got it working! I just had to bind LED controls to a switch and it turned back on, thanks!
Offline C³—Ears
« Reply #223 on: Wed, 21 November 2018, 02:13:06 »
Good to know this. I never had that issue before. Lol :thumb: :thumb: :thumb:
  • formerly honsoo
« Reply #224 on: Wed, 21 November 2018, 20:54:58 »
How do I get to Layer 1 from Layer 0? I tried to assign trigger Layer 1 and it doesn't seem to do anything.
Offline C³—Ears
« Reply #225 on: Thu, 22 November 2018, 03:32:04 »
First enable FN key then set a FN key to each layer. then use FN to use another layer
Offline Quantastrophus
« Reply #226 on: Sat, 08 December 2018, 11:13:24 »
I'm also interested in a type c version of this.
Offline odd
« Reply #227 on: Wed, 13 February 2019, 10:59:52 »
I cannot seem to figure out how to change layers by binding a FN key. Following the directions in the manual does not seem to do anything. I only end up changing the default layer, can anyone help?
« Last Edit: Sun, 21 April 2019, 00:10:53 by odd »
Offline nevaenuf
« Reply #228 on: Tue, 09 July 2019, 20:40:16 »
Anyone know how to turn a led off?  Is it all or nothing?  I'd like to turn off leds that are under stabilizers, for example.
Offline C³—Ears
« Reply #229 on: Tue, 09 July 2019, 21:07:42 »
You got to change that using our software. What's version of your PCB? I can send it to you
Offline nevaenuf
« Reply #230 on: Tue, 09 July 2019, 23:42:47 »
It's version 1.  Did you already do a GB for version 2?
Offline odd
« Reply #231 on: Thu, 11 July 2019, 01:51:08 »
I would like a copy of that firmware too if possible
Offline C³—Ears
« Reply #232 on: Fri, 12 July 2019, 06:44:53 »
No, probably sell them in stock.
Down software here: http://www.c3equalz.com/col.jsp?id=107
Offline C³—Ears
« Reply #233 on: Fri, 12 July 2019, 06:45:53 »
Download it here:http://www.c3equalz.com/col.jsp?id=107
Offline gabbbe
Re:  C³-LDN RGB80% PCB(Complete)
« Reply #234 on: Sun, 10 November 2019, 18:23:59 »
I posted on Discord but posting here as well since I'm desparate:
Hey friends, I know it's a dumb question but how do I connect the c3 ldn pcb to the c3 software?
I tried the B + L while plugging it in, it seemed that it was on flash mode but the software doesn't seem to recognize it
I'm a noob in programming....uinfortunately
A little help would be very much appreciated.
oh yes, forgot to mention the pcb that I have: LDN 87KEY RGB PCB (B87). Hardware Version: 1.0.
Thanks so much!
Offline gabbbe
« Reply #235 on: Mon, 11 November 2019, 11:24:23 »
I manage to get the Version 1.0 of the software and it worked, I can manage the leds right now but I don't know why I can't change the keymap,
tried in normal and BootLoader mode...
Thanks so much!
Offline VipermanGT2
« Reply #236 on: Fri, 10 January 2020, 01:34:10 »
Is there any way to pick one of these up even though the GB is finished?? I really want something with per key rgb for an upcoming build, and this would be perfect.
Offline NightFox99
« Reply #237 on: Thu, 14 April 2022, 11:59:18 »
No Windows 10 support ? I got two PCBs and no way to make them work ?
Offline granola bar enthusiast
« Reply #238 on: Wed, 20 April 2022, 09:58:35 »
if i'm being fully honest I know little to nothing about PCB's or PCB design, although I will look at this as an option in the future
