Author Topic: Just built alps64 with ISO AEKII keycaps.  (Read 1936 times)
Offline ag36
« on: Wed, 23 May 2018, 20:41:10 »
Works fine while some of the keycaps didn't fit well so I have to improvise, the thick pbt caps sounds great with matias click and matias stabilizer kit and hasu's plate. Much better then my KBP V80 with tai hao double shot abs keycaps. So sad I can't get a cheap ansi aek in the UK. Feeling is much more satisfying then any MX keyboard.
two stabilizer wires had to be made from scratch using 1mm wires. I really should've ordered silver case for this.
« Last Edit: Wed, 23 May 2018, 20:43:21 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Sup
Re: Just built alps64 with ISO AEKII keycaps.
« Reply #1 on: Thu, 24 May 2018, 01:23:18 »
I would try to snatch a Apple extended keyboard II . But since you are are also from the EU you can't almost find no Apple II keyboards unless you pay 80-100 Euros. I would recommend looking on Ebay for Apple extended keyboard II auctions that include the world wide shipping program. I bought my apple extended keyboard for 70ish dollars with shipping.
current
Coming soon
Offline ag36
« Reply #2 on: Thu, 24 May 2018, 05:54:05 »
Thanks, I actually been watch ebay for weeks just waiting for a cheap one to pop up :)
