Author Topic: I like MX Blues, am I crazy?  (Read 15284 times)
Offline carnagex9
Re: I like MX Blues, am I crazy?
« Reply #50 on: Fri, 08 June 2018, 11:12:39 »
I used to dislike clicky switches, but then I got the box navy switches and fell in love!
Offline giangtran19x
« Reply #51 on: Fri, 08 June 2018, 13:43:38 »
I think everyone have their own taste. Try as many switches as you can then pick the one that you like best  :thumb:
Offline sublyme
  • sublyme_keys
« Reply #52 on: Sat, 09 June 2018, 10:40:18 »
You're crazy. I liked blues for about 20minutes then I could not un-notice how loud they were. If you can tune it out then more power to you. ;)
Offline NewbieOneKenobi
« Reply #53 on: Sat, 09 June 2018, 11:50:31 »
MX blues is arguably the most elegantly designed mechanical switch..
It's a technical marvel.
The optical style switches that have come out, could be said to be the next level..
But the center slide mechanism of the mx-blue is already tactile perfection.
What he said. I have to downgrade to a lighter switch, but blues are far more pleasant if you don't have pain issues.
