Author Topic: [GB] Zlant 40% QMK Keyboard GROUP BUY OPEN (for extras), SHIPPING  (Read 42946 times)
Offline ziptyze
  • Fart Supporter
I did mine with tealios with clear housings and the rgb turned out awesome.
Wow... that shines through a lot better than I was expecting! Hopefully I'll have some options for translucent plates before long though, and then it will really shine through
"we didn't choose the furt life, the furt life chose us"
Offline ziptyze
  • Fart Supporter
First batch of soldered boards for inspection has been ordered. I'll keep everyone updated on their build progress.
Also, I'm almost finished redesigning the printed case. Originally my case design used a large integrated plate. Since that's not the size of the one shipping with the kits, I needed to change that. The plate with the kits is small enough to allow for a drop-in style case, so at first I was just going to modify my existing case. However, that would mean anyone printing it would need to purchase additional hardware separately (threaded inserts etc.) which is not ideal.
The new style case doesn't use heat-set threaded standoffs. Instead, there are holes through to the bottom with slightly countersunk holes on the underside so anyone with the group-buy kit will be able to use the hardware that came with the kit to use the case, and no additional screws or standoffs will be required.
200503-0
Offline MikeTheTiger
Case is looking good.  :thumb:
"all the numbers or none of them cmon man" -Kokaloo
Offline sako
Since it's my first time doing smd soldering, is there a way to check if I messed up the board before soldering the switches? Should I just go ahead and try flashing the firmware?
Offline ziptyze
  • Fart Supporter
Absolutely. Test all before doing switches
Offline ziptyze
  • Fart Supporter
Added the file for the case to the first reply in the thread.
Offline vafan
Can I use this case for the 1st GB PCB?
Sent from my SM-A710F using Tapatalk
Offline ziptyze
  • Fart Supporter
Yes. You’ll use everything that came with the kit except for the bottom plate. If you look at the “render” you’ll see the six holes in the bottom. You screw the standoffs into those just like the bottom plate, and then put the plate and pcb in the top and screw it in place. That way very little is wasted from the original kit, and you don’t need anything new but the case.
Offline ArkadiusBear
I filled out the google docs form, but haven't received any email confirmation that I did so? Is this standard for most groupbuys (it's my first time participating in one). Thanks!
EDIT: Don't worry, found the email!
« Last Edit: Sat, 28 July 2018, 12:50:48 by ArkadiusBear »
Offline ziptyze
  • Fart Supporter
Last day for the group buy coming up. Also may want to check out the Keeblade group buy if you want a case.
https://reddit.com/r/MechanicalKeyboards/comments/94e0cc/keeblade_groupbuy_is_live_more_info_in_comments/
Offline Rumblehotep
Qlavier's zlant cases are different from the hipro cases you mentioned?
Offline ziptyze
  • Fart Supporter
They are different. The pcb must be soldered into place with those, so you’d need them before assembly. If you get/print a hipro you can just drop the board in from the assembled kit.
Offline chuckdee
And the other advantage is that you can change cases if you want with the hipro.  With the keeblade, you can't.  Thanks for spelling that out and preventing me from spending $100 more on it LOL
Offline ziptyze
  • Fart Supporter
Talk you out of? I need 5
Offline chuckdee
My Case came in today.
https://imgur.com/a/WK7AJ8S
It turned out nicely!  Got it done on Treatstock (through Thingiverse) - the actual shop that did it was Nicks Printing Services.  It cost $25 for the print in PETG.  I'll put up another picture once I get it done.
Offline ziptyze
  • Fart Supporter
Oh petg. Is it a little squishy???
Offline chuckdee
Not at all.  It's just as solid as ABS to pressure from my (admittedly limited) experiments.  I'd originally wanted ABS, but no printer was willing to guarantee the integrity of the print.
Offline ziptyze
  • Fart Supporter
Re: [GB] Zlant 40% QMK Keyboard GROUP BUY OPEN (for extras), PCBs ordered
« Reply #67 on: Thu, 09 August 2018, 14:00:44 »
PCBs have been ordered, and order form has been reopened until extra boards are sold.
Offline ygecko
« Reply #68 on: Fri, 10 August 2018, 00:01:20 »
Had a friend print me a case in black.  Turned out awesome!
Offline chuckdee
« Reply #69 on: Fri, 10 August 2018, 08:00:55 »
What material did you use?
Offline sako
« Reply #70 on: Mon, 13 August 2018, 03:39:17 »
I did a quick vector on inkscape for a zlant case, I was planning to have it lasercut but the place is closed for vacation until aug 26. If anyone wants to do a test print here is the vector file.
It's a 5-layer drop-in case, it's supposed to be printed on 3mm plexiglass. You can make the middle layer transparent if you have leds installed.
Again THIS HAS NOT BEEN TEST PRINTED YET, I just printed the bottom layer 1:1 on paper to check if the screw holes match.
« Reply #71 on: Mon, 13 August 2018, 08:37:20 »
Are there any extras left?
Offline ziptyze
  • Fart Supporter
« Reply #73 on: Mon, 13 August 2018, 13:44:02 »
Factory sent me pictures of the factory soldering.
201931-0
As soon as I receive the first 5 boards and test them, I will give the OK to solder the rest.
Also, group buy will remain open as long as I have extras.
Offline vafan
« Reply #75 on: Sat, 18 August 2018, 22:59:01 »
Just finished my keeb.
Happy with it.
Offline biograf
« Reply #76 on: Tue, 21 August 2018, 09:34:13 »
Happy with it.
I want to see the pic but I can't. :^(
Offline ziptyze
  • Fart Supporter
Offline vafan
« Reply #78 on: Thu, 23 August 2018, 05:48:51 »
Happy with it.
Sorry, Here you are
Offline ziptyze
  • Fart Supporter
« Reply #79 on: Fri, 31 August 2018, 20:38:33 »
Little update, I had a family member in the hospital this week, so I didn't get the first 5 boards sent out as soon as I'd hoped, but I'm dropping them off tomorrow. The factory sent me pictures of the boards that they are currently working on, so I'm hoping that they will ship very shortly.
Otherwise, (as before) I'm waiting on standoffs from Aliexpress. I'm obviously hoping they arrive before the PCBs, but trying to communicate with those sellers can be difficult.
Additionally, I discovered the location for my mounting holes was a little too tight between the switches when using MX clones. All of my pcbs (until recently) I had assembled using box switches. When I assembled a board using zealios and zilents I found that when I assembled them, some of the switches were skewed. This is because the screws were pushing into the switches when the plate is attached to the standoffs. I managed to find some smaller screws that are hex heads, and tested them... so crisis averted. All boards will ship with the new screws and a wrench (including the 5 going out tomorrow). Obviously none of this will affect anyone putting together a keeblade, but you'll get the proper screws regardless.
Offline the_high_5
« Reply #80 on: Wed, 12 September 2018, 18:10:58 »
Hey OP! I'm sorry to hear about your family member, and I hope they're doing better now.
I saw a post on your Instagram with some fancy PCB's and plates, so I thought I'd ask about any updates. Really stoked on this!
Offline ziptyze
  • Fart Supporter
« Reply #81 on: Wed, 12 September 2018, 19:05:03 »
I’ve been packing stuff. I hope to send some out tomorrow even. They’ll go out in order of the invoice numbers.
Offline the_high_5
« Reply #82 on: Thu, 13 September 2018, 00:42:17 »
Awesome! Thank yoy for the update. Looking forward to receiving it.
Offline smee
« Reply #83 on: Thu, 20 September 2018, 11:32:22 »
Hey all,
Super excited for this board. A coworker sent me a link here and am so happy to be able to join the group buy!! Looking forward to this.
Cheers,
~smee
Offline ziptyze
  • Fart Supporter
« Reply #84 on: Thu, 20 September 2018, 11:40:06 »
Hey all,
Cheers,
~smee
Glad to hear it, thanks for joining!
Offline ziptyze
  • Fart Supporter
Re: [GB] Zlant 40% QMK Keyboard GROUP BUY OPEN (for extras), SHIPPING
« Reply #85 on: Thu, 20 September 2018, 11:50:27 »
I updated the second post with information about what should be in the component bag that comes with the kits. Take note of the slight difference in length between the screws for the case and the screws for the stabilizers. They're the same thread, but the stabilizer screws are slightly shorter.
Also, if you ordered a Keeblade DO NOT SOLDER THE BOARD TOGETHER USING THE PLATE I PROVIDED. If you do so, you'll need to de-solder it to install it in your Keeblade.
Offline ziptyze
  • Fart Supporter
« Reply #86 on: Sun, 23 September 2018, 20:02:30 »
Offline polarsolar
« Reply #87 on: Sun, 23 September 2018, 23:39:13 »
Thanks for posting updates & the assembly info!  I'd otherwise be the person confused about two switches in the center of the board not fitting (hey, someone's gotta be that person).  Got the shipping label creation message today too.  :thumb:
Offline smee
« Reply #88 on: Mon, 24 September 2018, 10:44:28 »
Assembly album:
https://imgur.com/a/l3ak9eV
Thanks for that!
Can somebody help a noob out and point me in the right direction to source switches, 2u bracket/spacebar key, etc?
Thank you,
~smee
Offline Rumblehotep
« Reply #89 on: Mon, 24 September 2018, 11:13:33 »
Got my kits!
Switches and stabs lubed last night, can't wait to get home today to finish!
It's already flashed with the default planck layout, yes?
Offline ziptyze
  • Fart Supporter
« Reply #90 on: Mon, 24 September 2018, 11:15:34 »
I did have the wherewithal to put a sticker over them too, but I wanted to make sure I made it as clear as possible
Offline ziptyze
  • Fart Supporter
« Reply #91 on: Mon, 24 September 2018, 11:17:26 »
Assembly album:
Thanks for that!
Thank you,
~smee
There are probably hundreds of places you can get switches, even amazon. Do you at least have it narrowed down to linear, clicky, or tactile? The 2u bracket thing (a stabilizer) comes with the kit though. You’ll just need a 2u keycap in whatever set of caps you plan to put on the board. Sometimes that’s much easier said than done.
Offline ziptyze
  • Fart Supporter
« Reply #92 on: Mon, 24 September 2018, 11:17:50 »
Got my kits!
Yes, default Planck. Good luck with the build!
Offline chuckdee
« Reply #93 on: Mon, 24 September 2018, 11:18:32 »
Any planck set of keycaps should have a 2U spacebar.
Offline smee
« Reply #94 on: Tue, 25 September 2018, 13:54:33 »
Thanks guys! I think I've found what I'm looking for.
Last question: Is the connection type USB C or Micro USB? Getting a custom cable for this.
Also, I will be working with my father (CNC guy) who can cut wood, aluminum, brass, etc... to make a sweet case for the Zlant. I'll post results once the first one is cut!
Cheers,
~smee
Offline ziptyze
  • Fart Supporter
« Reply #95 on: Tue, 25 September 2018, 15:27:44 »
Cheers,
~smee
Mini actually. I’ll be interested to see what you come up with!
Offline RivieraS
  • Yutop
« Reply #96 on: Tue, 25 September 2018, 21:10:46 »
how to join in GB now???
Offline ziptyze
  • Fart Supporter
« Reply #97 on: Tue, 25 September 2018, 21:27:27 »
Offline smee
« Reply #98 on: Wed, 26 September 2018, 15:14:30 »
Damn that was some fast shipping!
Rubiks for scale:
Now I await the switches and keycaps I've ordered. :D
Thanks Zip!
~smee
« Last Edit: Wed, 26 September 2018, 15:16:16 by smee »
Offline ziptyze
  • Fart Supporter
« Reply #99 on: Wed, 26 September 2018, 16:19:04 »
Rubiks for scale:
Thanks Zip!
~smee
Always happy to see a safe arrival! What switches are you getting?
