Author Topic: Whitefox Ergo-Clear Mod Help!?  (Read 2884 times)
Offline Pavilions
« on: Sun, 10 June 2018, 05:19:10 »
I just received my Whitefox with Cherry MX Clears, I and it's really stiff, so I found some articles about the Ergo-Clear mod but I couldn't find anything that is related to the Whitefox...
can I do this process without desoldering the Keyboard? is it possible to do it from the exterior only by removing the keycaps?
also, what are the things that I'm going to need? I do have some cherry MX brown switches with their springs can I swap them?
Thanks
Re: Whitefox Ergo-Clear Mod Help!?
« Reply #1 on: Sun, 10 June 2018, 07:31:08 »
The important thing to do the mod without soldering is holes in the plate - pop off a keycap, if the holes are tight around the switch you'll need to desolder, if there's a long thin gap or two short gaps down the sides you can take the tops off and do the mod.
If you can do it you'll need a tool to take the switch tops off, you can make one or if you're in the US you can buy these, if you're non-US send a PM to 00zeRo (who runs the site) and he can send a paypal invoice without the expensive insured shipping.
As to the springs it's personal choice, if you use heavy keycaps you may find they don't pop up reliably using brown springs but they're free so could be a good place to start.
Offline Pavilions
« Reply #2 on: Sun, 10 June 2018, 20:02:20 »
I have uploaded pictures here you can check the switch and if it can be disassembled or not?
197811-0197813-1197815-2197817-3197819-4
« Reply #3 on: Mon, 11 June 2018, 03:43:41 »
Yes those are the best switch cutouts with two short gaps on each side so you can take the tops off while still supporting the switch.  Not surprising on a community designed board :thumb:
Offline JianYang
« Reply #4 on: Mon, 11 June 2018, 04:21:12 »
But it does not work with the led installed like in the photos - at the very least they will have to come out.
« Reply #5 on: Mon, 11 June 2018, 06:35:01 »
Good point!  LEDs are worse to remove than switches too.
I really should wake up before posting :-[
Offline Pavilions
« Reply #6 on: Mon, 11 June 2018, 06:36:14 »
Yes, I bought the needed tools to open it and mod it, but one of the LEDs is damaged where can I buy the same white LED so I can replace it?
Offline Pavilions
« Reply #7 on: Mon, 11 June 2018, 06:37:26 »
do you know where can I find similar LED? I need to buy one since one of them is damaged and I need to replace it :)
Offline donut_sauce
« Reply #8 on: Mon, 11 June 2018, 07:35:46 »
A lot of vendors on eBay sell LEDs.
