Author Topic: Mechanical Split Keyboard  (Read 9620 times)
Offline Necroleachate
« on: Mon, 19 April 2010, 10:35:01 »
Is there anyone? Or I will have to make my own?
[SIGPIC][/SIGPIC]
Offline itlnstln
« Reply #1 on: Mon, 19 April 2010, 10:37:43 »
There's a few, but most are OOP.
IBM M15 (Good luck finding this one)
Northgate Evolution
Reveal Something-or-Other
Cherry Ergo-Plus (another one that's hard to find)
uTron (These are in production, but you would have to import one from Asia, and they are about $500)
Offline nraymond
« Reply #2 on: Mon, 19 April 2010, 11:07:39 »
Quote from: Necroleachate;173450
I really liked the old DataDesk Smartboard (ADB model), and about 8 years ago I bought their USB version, but at the time they changed the plastic from platinum to a semi-translucent white, and it was much more brittle.  It wasn't long before several of the keycaps cracked under normal use (near the stem).  I wrote to them, and they sent me replacement keycaps.  It looks like they've since changed their plastic:
http://www.datadesktech.com/desktop_sb.html
I also want to say the keyswitch they used changed between the old ADB version and the USB version, but I haven't tried a side-by-side in quite some time (and when I last had them both out was before I really became very cognizant of keyswitch brands and types).
Their front page also has this at the bottom:
"SmartBoard II - Coming Soon!  Our most sought-after product is getting even better. Every key re-definable w/o software, USB 2.0 Hub, and much more. Call 1-888-446-3222 or email sales@datadesktech.com for information."
Interesting.  I hope they build it well.
Offline itlnstln
« Reply #3 on: Mon, 19 April 2010, 11:27:05 »
I forgot about the Smartboard.  That "Smartboard II..." message has been there for about a year or so.  I wouldn't get too excited about it.
Offline itlnstln
« Reply #4 on: Mon, 19 April 2010, 11:30:31 »
The Apple Adjustable is another, but most people around here that have used it didn't like it.  Most of the split ergo keyboards you find are going to be ALPS-based.  The M15 (BS), uTron (Topre), Maltron (Cherry), Cherry Ergo-Plus and Kinesis (Cherry) are not, but they are much harder to find or fairly expensive (or both).
Offline salcan
« Reply #5 on: Mon, 19 April 2010, 11:41:30 »
Quote from: itlnstln;173461
Kinesis Advantage seems like the best bet right now for an ergo mechanical.
I'd forget about the M15 or the Cherry MX-5000 ErgoPlus as they are so hard to find at this point. Though the cherry might be possible if you are in Europe.
Ultimately I think there are three aspects here: reasonable price, split, and mechanical. Choose two.
« Last Edit: Mon, 19 April 2010, 11:41:47 by salcan »
Offline itlnstln
« Reply #6 on: Mon, 19 April 2010, 11:46:53 »
I really think the bigger issue is that split keyboards ended up being a fad more than a solution, and all of the better ones (Maltron, Kinesis, uTron, etc.) are niche items that command a higher price.  That said, the ones that are left are better solutions that the ones that are no longer in production with the exception of the M15 and Cherry Ergo-Plus.
Offline noctua
« Reply #7 on: Mon, 19 April 2010, 13:55:56 »
Do it, make your own! Be sure, your aren't alone with this! :tea:
I have found one, that has it done with a alternative layout called "NEO", 100% handmade look here (german): https://wiki.neo-layout.org/wiki/Neo-Tastaturen
The point is: ... There are nothing good, unless you do it! ...
« Last Edit: Mon, 19 April 2010, 14:25:40 by noctua »
Selfmade Keyboard I (done)
DT225 CH Trackball
Selfmade Keyboard II (95% completed)
L-Trac CST2545W-RC Trackball
both use Cherry MX Blue switches, an Teensy++ controller and have an Colemak layout
« Reply #8 on: Mon, 19 April 2010, 17:34:34 »
Thanks, guys, for all the information. Fast as always. :D
I wasn't specific enough at first.
What I am really looking forward is a two-piece keyboard united by a wire. Like the kinesis freestyle, which unfortunately is rubber dome.
But by the answers here I can figure it exists only in my dreams.
ps: uTron looks awesome, but a $500 keyboard is not for me.
[SIGPIC][/SIGPIC]
Offline itlnstln
« Reply #9 on: Tue, 20 April 2010, 07:24:47 »
There is an M15 for sale on eBay right now. Check the eBay Finds forum for details.
Offline ricercar
  • mostly abides
« Reply #10 on: Tue, 20 April 2010, 11:20:57 »
No, sadly that M15 auction was over when I placed my bid.
