Author Topic: 【IC】JER-A06 PCB-Mounted Custom Keyboard  (Read 29923 times)
Offline neralo
Re: 【IC】JER-A06 PCB-Mounted Custom Keyboard
« Reply #50 on: Sun, 17 June 2018, 20:22:19 »
B-series
Not familiar with B-series? Can you share some information about how I would go about programming the keymap on this? Is there a GUI?
I’ve been told b-series means b.87, so ps2av, ie bootmapper. Correct me if I’m wrong pls.
Also how does the pcb mount to the top casing? Clips? Screws?
I just built a J80 last night. The PCB mounts to the top of the case with M2(?) screws, kinda like a top mount plate
Cheers fam! I saw the screwholes, but wasn't sure if the PCB was shapped to have nubbins that went into those little indents, or if they would just use larger flat head screws that would hold the pcb in place without actually screwing through. I like this way a lot more.
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline alisonica
« Reply #51 on: Sun, 17 June 2018, 21:20:48 »
能不能加个雅宝线,德国这里买不到 :'(
Offline xueyao
« Reply #52 on: Sun, 17 June 2018, 23:37:12 »
那边应该有转运的吧 我人在新加坡 淘宝还是很方便
Sent from my SM-G965F using Tapatalk
Offline TerryMathews
« Reply #53 on: Mon, 18 June 2018, 00:04:50 »
I must have this.
Any chance we can get measurements of the angle and height? I'm hoping that the pad will match up with my E8-V1 since it appears Exclusive is never going to run their numpad.
Offline shower_king
  • Pain is weakness leaving your body
« Reply #54 on: Wed, 20 June 2018, 20:21:27 »
The group buy is live here
https://geekhack.org/index.php?topic=96264.0
Sorry for not immediate response to some questions.
If you have any questions, please reply in the GB link. thank you.
