Author Topic: [IC] hbcp - hineybush compact  (Read 191234 times)
Offline hineybush
  • student of error
    • hineybush keyboards
« on: Wed, 13 June 2018, 10:36:26 »
hey
latest update here: https://geekhack.org/index.php?topic=96158.msg2761305#msg2761305
The 1800 and compact 1800 layouts are by far my favorite for keyboards, and I wanted to create an 1800-based layout board of my own. After experiences with the Leopold FC980M and seeing other compact 1800 boards around, I've come up with the HBCP.
The design is obviously very simple - something I definitely wanted to do. The indicator area is based on the original Cherry G80-1800 indicators. I'm considering getting some screen-printed polycarb or brass (or something else, idk) badges for the area with indicator symbols.
Case features:
  • CNC'd 6061 aluminum top/bottom, very possible polycarb version
  • FR4 and brass plates, brass weight.
  • No RGB underglow because I don't like it - but you can solder your own on if you'd like :)
  • Optional FR4 half plate
  • USB type C connector
  • Colors not finalized yet
  • 5 degree angle
  • optional burger mount o-ring dampening for plate - you literally just put o rings between the case/plate/screws
  • no switch top opening
  • might add some sound dampening as an extra thing if people would want it
Layout support:
  • Bottom row: 1.5-1.5-7-1.5-1.5; 1.25-1.25-1.25-6.25-1.5-1.5; 1.25-1.25-1.25-6.25-1-1-1.
  • ISO: PCB will support it. Plate may support it. I'll release ISO plate files.
  • Split backspace
  • Split vertical 2u keys on the numpad (ie four 1u's instead of two 2u's)
  • Stepped caps lock
  • KLE (thanks to AceRecon from discord):
PCB: I'll be designing this as well
  • Aforementioned layout support
  • Definitely QMK support
  • In-switch one-color LED backlighting
  • Underglow soldered on if needed (PC)
  • USB type-C connector
  • PCB-mount stabilizer support
  • 1.2mm thick PCB
I'll be ordering a prototype case very shortly, and I anticipate having a prototype PCB done and ordered in the next 3-4 weeks. Date for run is TBD, but I wouldn't expect it earlier than August.
More pics:
-old renders-
I'll probably add stuff as I go.
« Last Edit: Thu, 25 July 2019, 00:10:58 by hineybush »
Offline Pwner
  • soon™
Re: [IC] Hineybush Compact 1800 (HBCP)
« Reply #1 on: Wed, 13 June 2018, 10:37:40 »
nice
Offline futurecrime
  • Get Zooted
« Reply #2 on: Wed, 13 June 2018, 10:39:12 »
Nice.
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #3 on: Wed, 13 June 2018, 10:39:18 »
Lookin fine
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline russthebus27
« Reply #4 on: Wed, 13 June 2018, 10:40:01 »
definitely in for the funky plates.  Carbon fiber too?  Big fan.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #5 on: Wed, 13 June 2018, 10:40:14 »
I'd be interested depending on color options and qmk support.
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #6 on: Wed, 13 June 2018, 10:40:22 »
nice
Offline gt1989
« Reply #7 on: Wed, 13 June 2018, 10:42:16 »
nice
Offline kristmascane
  • emilia is trash
« Reply #8 on: Wed, 13 June 2018, 10:42:34 »
very nice hineyboi. much good. willbuy
Offline Tyson
« Reply #9 on: Wed, 13 June 2018, 10:43:21 »
Nice
Offline clasicks
  • Formerly KeyboardUser4
« Reply #10 on: Wed, 13 June 2018, 10:45:52 »
removed
« Last Edit: Wed, 04 July 2018, 15:17:56 by clasicks »
Offline MatchstickMan
  • CAD Jockey - YOLO Enthusiast
« Reply #11 on: Wed, 13 June 2018, 10:47:11 »
Nice
Current Projects:
- SouthPad -- Left-handed Numpad
- Full Split (Currently on hold)
Offline hineybush
  • student of error
« Reply #12 on: Wed, 13 June 2018, 10:47:39 »
If anyone has good ideas about plate design/acoustic holes/fancy crap like that let me know, bc I want this to not be a Bad Keyboard
also I'll take/upload a pic of the plate design later. imagine a boring flat base with a small inset for an old-style machine tag like this
« Last Edit: Wed, 13 June 2018, 10:49:16 by hineybush »
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #13 on: Wed, 13 June 2018, 10:47:51 »
nice
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline vtachkov
« Reply #14 on: Wed, 13 June 2018, 10:50:25 »
nice
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #15 on: Wed, 13 June 2018, 10:51:05 »
nice
Offline Yeoh
« Reply #16 on: Wed, 13 June 2018, 10:54:34 »
nice
Offline soba
« Reply #17 on: Wed, 13 June 2018, 10:56:57 »
nice
Offline kyoumau
« Reply #18 on: Wed, 13 June 2018, 10:57:09 »
nice
Offline eyedrop
« Reply #19 on: Wed, 13 June 2018, 10:57:53 »
I like it.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #20 on: Wed, 13 June 2018, 10:58:53 »
nice
Offline Artemie
  • Don't Let Your Memes Be Dreams
« Reply #21 on: Wed, 13 June 2018, 11:01:00 »
Nice.
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
« Reply #23 on: Wed, 13 June 2018, 11:32:01 »
A riveted (like actual rivets, not looking riveted but really just adhesive) plate on the base with some information and maybe like a serial number/article number stamped into it could be REALLY neat.
Model:
Version/Rev:
Designer:
Article #:
Compatible software (something like that):
Controller:
It might have to go on the back and I imagine a lot of that would be silk-screened on, but stamping some of the information could be really cool. I'd definitely be willing to help with some of that, if needed.
Current Projects:
« Reply #24 on: Wed, 13 June 2018, 11:33:55 »
y'all on my steez
Offline hineybush
  • student of error
« Reply #25 on: Wed, 13 June 2018, 11:36:14 »
Model:
Version/Rev:
Designer:
Article #:
Controller:
Not sure if i'd do actual riveting. Probably some low-height buttonhead screws or like you said, adhesive. I'd def like to do the information you included, I'll have to play with the design/idea a bit
Offline wholypantalones
  • text and icon mods plz.
« Reply #26 on: Wed, 13 June 2018, 11:56:08 »
Love it, nice and simple.
Offline fcoury
« Reply #27 on: Wed, 13 June 2018, 11:56:44 »
My only feedback is to stick to QMK or both :)
Offline hineybush
  • student of error
« Reply #28 on: Wed, 13 June 2018, 11:58:33 »
Yeah it'll definitely be QMK. Keyplus would be a nice secondary if anything.
Offline forumusername
« Reply #29 on: Wed, 13 June 2018, 12:12:53 »
Nice
Sent from my PH-1 using Tapatalk
Offline megaforce
« Reply #30 on: Wed, 13 June 2018, 12:14:48 »
nice
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline olivia
« Reply #31 on: Wed, 13 June 2018, 12:18:56 »
Offline Corgi Butts
« Reply #32 on: Wed, 13 June 2018, 12:45:15 »
nice
Offline _ODIN_
« Reply #33 on: Wed, 13 June 2018, 12:49:26 »
iso :D
Offline shadowrealmwarez
« Reply #34 on: Wed, 13 June 2018, 12:49:40 »
Will it support switch top opening?
Offline hineybush
  • student of error
« Reply #35 on: Wed, 13 June 2018, 12:58:43 »
No, I personally don't care for switchtop opening so this plate won't offer it
« Reply #36 on: Wed, 13 June 2018, 13:01:11 »
I appreciate the reply, I do look forward to it anyways since its 1800 and possibility of a brass weight :)
Offline dimo
« Reply #37 on: Wed, 13 June 2018, 13:20:07 »
I'll be in whenever the GB happens if there's a dark gray like the renders
« Last Edit: Wed, 13 June 2018, 16:52:27 by dimo »
Offline mike52787
  • Alps Aficionado
« Reply #38 on: Wed, 13 June 2018, 13:26:01 »
****ing Sexy
gotta have it
Offline Remsky
Offline maxf
« Reply #40 on: Wed, 13 June 2018, 13:30:09 »
nice
Offline nu_types
  • Formerly Iredeus
« Reply #41 on: Wed, 13 June 2018, 14:29:18 »
Nice
« Reply #42 on: Wed, 13 June 2018, 14:37:35 »
I've never been that into a custom before but this has my interest.
Offline alisonica
« Reply #43 on: Wed, 13 June 2018, 14:38:16 »
Noice
Offline dyrdevil
« Reply #44 on: Wed, 13 June 2018, 14:39:34 »
Yup
Offline tanvir175
« Reply #45 on: Wed, 13 June 2018, 15:12:59 »
nice
Offline Panzerhawx
  • Endgame is a lie. You just end up buying more.
    • cartel
« Reply #46 on: Wed, 13 June 2018, 17:15:31 »
good job son
Offline mgsickler
« Reply #47 on: Wed, 13 June 2018, 18:52:43 »
Count me in!
Offline hineybush
  • student of error
« Reply #48 on: Wed, 13 June 2018, 21:24:26 »
KLE of layout added, thanks to AceRecon.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #49 on: Wed, 13 June 2018, 21:33:31 »
No.
(j/k, nice)
« Last Edit: Wed, 13 June 2018, 21:45:21 by Wilba »
