Author Topic: [IC] hbcp - hineybush compact  (Read 190390 times)
Offline whinmeister
Re: [IC] hbcp - hineybush compact
« Reply #400 on: Mon, 15 July 2019, 14:40:53 »
got the alu proto built up!
Very nice!!!!
Offline ARSLOCK
  • CarolinaMech.com
    • Carolina Mech
« Reply #401 on: Mon, 15 July 2019, 15:03:57 »
can u take a pic of the both alu protos next to each other?
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #402 on: Mon, 15 July 2019, 15:18:05 »
Gimme a day or two, I have to put another plate/PCB combo and caps back in/on the first proto!
Offline bthezebra
« Reply #403 on: Mon, 15 July 2019, 15:33:59 »
Hiney you are building too much hype, my brain can't take it....
Offline Raekyn
« Reply #404 on: Tue, 23 July 2019, 01:20:32 »
made an account just to note - I'm so in for this.
also - will you be offering a version with hot swap sockets?
Offline Smoff
  • 817 785
    • Youtube
« Reply #405 on: Tue, 23 July 2019, 02:19:15 »
That would mean 2 different pcbs, making them both more expensive since the moq is pretty low. My guess is that there is only a handful of people wanting hot swap. So I highly doubt it.
Current boards: Matrix 1.2 OG | Matrix 8xv2.0 | Cherry g80-1000 | Cherry g80-3000 | Matrix 2.0add | Matrix Noah
Boards on the way: Duck Orion v2.5 | Matrix Falcon
Previous boards: BOK.CP | Duck Orion v3 | Mech27v2 | HHKB pro2 x3 | Cherry g80-11800 | NIU mini | Klippe r1 | Brutal60 | Duck Unicorn x Legend | Duck jetfire | Cherry g80-1800 | IDB60 | PC Salamander | Lin Whale r2 | LZ Physix | Duck Viper v3 |
Offline Raekyn
« Reply #406 on: Tue, 23 July 2019, 03:03:44 »
that makes sense i suppose - perhaps i can install some receptacles
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #407 on: Tue, 23 July 2019, 09:06:24 »
lrn 2 soldr
Offline Raekyn
« Reply #408 on: Tue, 23 July 2019, 09:14:15 »
lrn 2 soldr
I know quite well how to - it's about convenience and flexibility.
Offline hineybush
  • student of error
« Reply #409 on: Tue, 23 July 2019, 09:52:29 »
Yea sorry no hotswap for this. Maybe if I ever do a future version or something.
Plan atm is to probably do a hybrid MX/alps PCB as that'd be most cost-effective.
This will also likely be pushed to mid-late August release, as I was informed I need to take a work trip in early-mid August.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #410 on: Tue, 23 July 2019, 13:50:15 »
ne aek cap layout avail (half kidding)
Offline Zirylian
« Reply #411 on: Tue, 23 July 2019, 13:57:57 »
Looking forward to this board.
268.2 / HBCP
Offline MMKB
« Reply #412 on: Tue, 23 July 2019, 15:41:10 »
The indicator area is based on the original Cherry G80-1800 indicators. I'm considering getting some screen-printed polycarb or brass (or something else, idk) badges for the area with indicator symbols.
Interested! Could you give some examples of how the indicator area would look like?
Offline Smoff
  • 817 785
    • Youtube
« Reply #413 on: Tue, 23 July 2019, 16:56:42 »
More time for me to gather funds for this board ;D
Offline hineybush
  • student of error
« Reply #414 on: Tue, 23 July 2019, 17:10:46 »
at this point i'm forgoing a badge or something like that for the light pipes. looks cleaner and simpler imo
Offline clasicks
  • Formerly KeyboardUser4
« Reply #415 on: Tue, 23 July 2019, 17:22:48 »
this looks great  :thumb:
Offline mr scooty
« Reply #416 on: Tue, 23 July 2019, 17:32:18 »
defs agree with this choice. is this run still planned to have limited slots hiney? really hoping to get in on this one. end game 1800 for sure
Offline thornkin
« Reply #417 on: Tue, 23 July 2019, 17:53:49 »
Is there a reason PCB designers don't leave room for us to add kailh hot swap sockets ourselves? That would seem like the best of both worlds. Can solder if you want or can install hot swap.
Offline pixelpusher
« Reply #418 on: Tue, 23 July 2019, 17:58:03 »
Probably impossible at this point and overkill, but it would be immensely helpful to put the LEDS on a small breakout board that screws to the top and plugs into the pcb.  Sometimes top mounted boards have to go in at an angle and it’s easy to bend the leds in that spot. Might not be the case in the HBCP.
Offline hineybush
  • student of error
« Reply #419 on: Tue, 23 July 2019, 18:12:42 »
you can't have both hotswap sockets (like the Kailh ones) and solder pads with a diameter small enough to effectively/efficiently solder switch pins. you could always use holtite sockets however
Offline hineybush
  • student of error
« Reply #420 on: Tue, 23 July 2019, 18:13:21 »
exactly what I did. the indicator LEDs are RGB and you can adjust the color within the keymap file (for now, ideally will get this on VIA one day)
Offline pixelpusher
« Reply #421 on: Tue, 23 July 2019, 18:34:05 »
Woop woop  :thumb: :thumb:
Offline iaman
« Reply #422 on: Tue, 23 July 2019, 18:41:02 »
Holtites is exactly my plan, this will (if I’m lucky) be my first build with ‘em.
Offline psyc
« Reply #423 on: Tue, 23 July 2019, 19:18:48 »
When can we preorder? Have a busy August and dont want to miss
Offline hineybush
  • student of error
« Reply #424 on: Tue, 23 July 2019, 19:20:04 »
towards the end. i'll announce/post the gb thread in advance lol
Offline psyc
« Reply #425 on: Tue, 23 July 2019, 19:22:46 »
Lol ok well I might be behind the great firewall so hope i dont miss it
Offline thornkin
« Reply #426 on: Wed, 24 July 2019, 02:22:13 »
Thanks.  I knew there must be a reason I never saw that available.
Laser ALT sporting red Sky Pandas
Offline hineybush
  • student of error
« Reply #427 on: Wed, 24 July 2019, 08:16:25 »
you COULD do like a reversed thing with north facing being hotswap and south facing being normal pads, but you still have the issue of limiting compatibility and that'll be a lot of extra cuts i'd rather not have on my PCBs lol
Offline badboy731
« Reply #428 on: Wed, 24 July 2019, 17:56:44 »
*sigh*
How many units are up for grabs? Another lovely board that I will never touch.
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline hineybush
  • student of error
« Reply #429 on: Wed, 24 July 2019, 19:43:30 »
*sigh*
50ish alu 30ish polycarb
Offline blakstealth
« Reply #430 on: Wed, 24 July 2019, 21:33:26 »
This looks great. But not great for my wallet.
« Reply #431 on: Wed, 24 July 2019, 22:22:11 »
*sigh*
this is very passive aggressive
Offline Lil
    • designedbydark
« Reply #432 on: Thu, 25 July 2019, 04:00:51 »
ne aggressive avail?
Offline whinmeister
« Reply #433 on: Fri, 26 July 2019, 09:59:16 »
*sigh*
Still no word, hint or announcement on when GB will be?
Offline Captain Shwah
« Reply #434 on: Fri, 26 July 2019, 10:14:08 »
Further up this page hiney says late August.
Offline hineybush
  • student of error
« Reply #435 on: Fri, 26 July 2019, 10:19:15 »
reading can be difficult
Offline whinmeister
« Reply #436 on: Fri, 26 July 2019, 10:50:44 »
It has changed so many times though. So "late August" can mean a lot of things. I've seen May, June, July and now August lmao. Maybe I just can't read. Can you blame me for wanting a more specific time frame. Or it could be me just not having patience. Who knows.  :p
Offline hineybush
  • student of error
« Reply #437 on: Fri, 26 July 2019, 10:53:28 »
yea tru, been delayed a bit bc i've been busy with stuff lol. late august seems the most definite at this point. I actually got the new, deeper bottom piece today. I have yet to check it out, but assuming it's good to go, that's the last thing I need to do design-wise.
Offline pixelpusher
« Reply #438 on: Fri, 26 July 2019, 11:04:32 »
Is there a source for 1800 layout alps keycaps?
Offline hineybush
  • student of error
« Reply #439 on: Fri, 26 July 2019, 11:29:22 »
i have a unikey kb-6551
Offline Pheyn
« Reply #440 on: Fri, 26 July 2019, 12:02:30 »
As far as an easily available set, you can always look at the kprepublic xda alps set that just came out. They're blanks, but they'd get the job done at least.
Offline hineybush
  • student of error
« Reply #441 on: Fri, 26 July 2019, 12:04:56 »
using xda on this is a bannable offense  :p
Offline Lil
    • designedbydark
« Reply #442 on: Fri, 26 July 2019, 12:13:25 »
xda handarbeit for this when?
Offline whinmeister
« Reply #443 on: Fri, 26 July 2019, 13:45:35 »
That's very good to hear! Thank you very much. I promise this will be the one and only time I'll ask for another release date. I keep thinking I've missed the GB already.
Offline hineybush
  • student of error
« Reply #444 on: Fri, 26 July 2019, 14:00:02 »
kinda poop pics but yea
new bottom
purp pc turned out well
Offline whinmeister
« Reply #445 on: Fri, 26 July 2019, 14:46:42 »
Very promising! The silver one looks awesome as well.
Offline hineybush
  • student of error
« Reply #446 on: Fri, 26 July 2019, 14:51:09 »
couple more pics comparing the old (silver) and new (pink) bottoms:
i can confirm that the switch pins no longer hit the case when installed. it takes a good bit of flex to make them hit, so some sort of liner would probs be useful with a flexible plate. it also sounds a bit more hollow with the new bottom (as expected), once again which can be mitigated with liner
Offline pixelpusher
« Reply #447 on: Fri, 26 July 2019, 15:35:34 »
Not usually a fan of XDA but I actually own that set and it’s really nice for what it is.  Very thick caps make for a nice sound signature
Offline Photoelectric
« Reply #448 on: Fri, 26 July 2019, 16:47:41 »
The pink is so dreamy  :-*
Offline pixelpusher
« Reply #449 on: Fri, 26 July 2019, 17:07:36 »
Purple PC is where its at!
