Author Topic: the tallest escape row key that you'd be comfortable using.  (Read 3194 times)
Offline proto
« on: Sat, 16 June 2018, 14:31:31 »
I have been prototyping an idea I had for a novelty keycap but it would require the key to be little less than half an inch higher than the standard size. Would that put anyone off from buying something like that?
Thanks
