Author Topic: Illustrator file for plastic top case?  (Read 2980 times)
Offline delatroy
« on: Tue, 26 June 2018, 14:20:22 »
Anyone know where I could find a vector file for a plastic top keyboard case please? I want to get a custom layout created but I'm a bit worried about getting the dimensions wrong!  :)
Thanks in advance!
Re: Illustrator file for plastic top case?
« Reply #1 on: Tue, 26 June 2018, 14:28:52 »
I'm confused.  If you want something custom how is what anyone else uses going to help?? :confused:
Offline delatroy
« Reply #2 on: Tue, 26 June 2018, 14:49:12 »
haha I mean I want something custom yes but I want to use a standard 104 top case layout to begin if that makes sense  :)
Offline fpazos
« Reply #3 on: Tue, 26 June 2018, 15:59:55 »
keyboard-layout-editor.com open a 104 layout.
Copy raw data into http://builder.swillkb.com
Download .eps
Offline ErgoMacros
« Reply #4 on: Tue, 26 June 2018, 16:57:47 »
Illustrator + Keycap design sounds like WASD custom to me...
   https://support.wasdkeyboards.com/hc/en-us/articles/115009403848-Intro-to-Custom-Layouts
They have templates in Inkscape and Illustrator.
Today's quote: '...“but then the customer successfully broke that.”
