Author Topic: [GB] TR60 integrated plate case & BLE PCB  (Read 123282 times)
Offline bball2
Re: [GB] TR60 integrated plate case & BLE PCB
« Reply #50 on: Fri, 06 July 2018, 01:00:46 »
Signed up!
Offline Gobluebro
« Reply #51 on: Fri, 06 July 2018, 07:01:08 »
I think I didn't fill in that shipping address part fully (it autofilled). Do you want me to resubmit?
Offline TriangleLab
« Reply #52 on: Fri, 06 July 2018, 08:10:17 »
Signed up for a black one with brass weight and hotswap pcb.
Will the invoice go out after the GB ends?
thanks!
You will receive it shortly today or tomorrow
Offline Poesjuh
« Reply #53 on: Fri, 06 July 2018, 08:20:52 »
No more finished build pics?
Offline TriangleLab
« Reply #54 on: Fri, 06 July 2018, 08:22:55 »
Some questions:
  • Would it be possible to get an extra acrylic back plate, even if we order the brass?
  • What other cases, if any, will the PCB support?
  • Any typing test for sound?
It's too bad that the Fusion60 group buy hasn't started yet. I don't have the budget for both boards, and I would want to see the final price on the Fusion.
1. Yes. PM me for details.
2. The compatibility of the PCB is the same with most 60% PCBs like GH60, Santan, DZ60, Zeal60, and so on.
3. No. I don't have a good speaker for recording sound.
I believe Fusion60 will be a good kit as well. However, TR60 is quite different from Fusion60 imo. Hope you can make the right decision by yourself.
Offline TriangleLab
« Reply #55 on: Fri, 06 July 2018, 08:26:35 »
No. Please me PM me with complete address.
Offline TriangleLab
« Reply #56 on: Fri, 06 July 2018, 08:27:51 »
Here you go
Offline lumpofunworth
  • I’m a guy, that does stuff, with things, for fun.
« Reply #57 on: Fri, 06 July 2018, 13:12:30 »
Hmm just a random question but I didn’t notice a hole for USB input on the case, it appears to be covered by the back plate? Is that correct, it could be on the other side and just not pictured, but I saw the area for it inside the case but no exterior hole.
Ok so I see it in the new pictures that you posted, I can the the hole through the PC back plate but it is definitely covered by that plate. Will the final version gave a hole in the back plate for the wired PCB?
« Last Edit: Fri, 06 July 2018, 13:15:07 by lumpofunworth »
I like keyboards like I like people... I like keyboards a bit more come to think of it... nvm
Offline Toilet
« Reply #58 on: Fri, 06 July 2018, 15:21:27 »
Can you show some pics with 3 AAA alkaline batteries installed/mounted to PCB?
Offline Windeh
  • a no name
« Reply #59 on: Sat, 07 July 2018, 00:11:49 »
My concern as well, will there be a special backplate for wired PCBs? Or will we have to create them ourselves (i.e. by dremel)?
Offline bard
« Reply #60 on: Sat, 07 July 2018, 01:02:37 »
ooh I have not spotted it, +1 for an answer,
Offline TriangleLab
« Reply #61 on: Sat, 07 July 2018, 01:32:32 »
The back plate in the photos doesn't have a cutout for USB port because there's no USB port on the prototype Bluetooth PCB. The back plates you receive will have cutouts for USB port.
Offline meluvis
« Reply #62 on: Sat, 07 July 2018, 02:36:27 »
PM'd for question about order  :)
Offline joe405
« Reply #63 on: Sat, 07 July 2018, 04:11:40 »
As the price makes this attractive for newbies, would you consider adding an option for assembly for the Bluetooth pcb?
Offline suddenZenith
« Reply #64 on: Sat, 07 July 2018, 09:26:51 »
Does the hot-swap PCB come with with a keyswitch puller?
Offline nickaster1
« Reply #65 on: Sat, 07 July 2018, 09:50:58 »
Anyway I can pay extra for the hotswap pcb to have another layout? Asking too late now but hoping it would work out
Offline Keebmeupscotty
« Reply #66 on: Sat, 07 July 2018, 14:18:19 »
Order placed and PM sent with a question about extra back plate, thanks!
Offline konstantin
  • Formerly constexpr
« Reply #67 on: Sat, 07 July 2018, 14:37:41 »
In the OP you mentioned that the Bluetooth PCB only works with the acrylic back plate. Why is that? Reception issues or something else?
Does the web configurator for the Bluetooth PCB have layer tap functionality (layer when held, key when tapped; LT() in QMK), or does it support something like TMK which does?
Offline Windeh
  • a no name
« Reply #68 on: Sun, 08 July 2018, 04:23:53 »
Just paid for my invoice. :thumb: Curious, where will the GB ship from? Just want to get an idea on shipping time and cost.
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #69 on: Sun, 08 July 2018, 06:26:00 »
Where will this be shipping from? Just to know if I will face import fees :)
Offline Poesjuh
« Reply #70 on: Sun, 08 July 2018, 07:28:41 »
Any chance at a different color? Would love this in a subtle gold or green
Offline TriangleLab
« Reply #71 on: Sun, 08 July 2018, 08:33:45 »
unfortunately, no
Offline TriangleLab
« Reply #72 on: Sun, 08 July 2018, 08:37:39 »
no
Offline TriangleLab
« Reply #73 on: Sun, 08 July 2018, 08:39:44 »
Could you elaborate? the hot-swappable PCB support only one layout.
Offline TriangleLab
« Reply #74 on: Sun, 08 July 2018, 08:44:50 »
1. All metal case will make the keyboard a faraday cage.
2. Yes, layer toggling is supported
Offline TriangleLab
« Reply #75 on: Sun, 08 July 2018, 08:46:05 »
will be shipping from Hongkong
Offline konstantin
« Reply #76 on: Sun, 08 July 2018, 11:19:15 »
I have an all-metal KBDfans 5° case and metal plate with a Bluetooth PCB and it works fine up to ~3 m. Have you tested this PCB with the metal back panel and can confirm that it doesn't work?
Can you share a link to the web configurator? I would like to see its full capabilities before I order.
Also, what firmware is it based on?
Offline coffeeshopcoder
« Reply #77 on: Mon, 09 July 2018, 01:23:40 »
Paid my invoice today... Can you give more info on the ble pcb, or point to the firmware or online configurator ?
Offline damagepoint
« Reply #78 on: Mon, 09 July 2018, 03:05:20 »
Hey i filled out a form, but I was hoping i could add a brass backplate as well?
Offline Poesjuh
« Reply #79 on: Mon, 09 July 2018, 03:12:18 »
I'm assuming you not replying to this question means it's a no? (As I always tell people, no is also an answer :) )
Offline jakl
« Reply #80 on: Mon, 09 July 2018, 03:30:38 »
1. Is the Titanium grey more like a silver or a light grey?
2. Is the brass polished or grainy?
3. What is the range of the bluetooth PCB?
Also interested in the web configurator.
« Last Edit: Mon, 09 July 2018, 04:09:05 by jakl »
« Reply #81 on: Mon, 09 July 2018, 16:05:38 »
Does the wired PCB support screw in stabilizers?
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #82 on: Mon, 09 July 2018, 21:24:12 »
Holy **** great pricing! If you are planning to make one with normal layout (non HHKB), I'll be down. For now, I'll just keep tabs on the thread!
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline bball2
« Reply #83 on: Mon, 09 July 2018, 22:22:11 »
There is a normal (non hhkb) layout available.
Offline kiwi99
  • that's a gnarly dookie
« Reply #84 on: Mon, 09 July 2018, 22:35:44 »
would it be possible to see some colour samples?
Offline cldskt
« Reply #85 on: Tue, 10 July 2018, 00:21:47 »
I’m obviously retarded. Thank you, not sure why I didn’t notice that in the OP.
Offline bball2
« Reply #86 on: Tue, 10 July 2018, 00:29:43 »
No worries! I jumped on the normal layout as well  :thumb:
Offline Yeoh
« Reply #87 on: Tue, 10 July 2018, 02:10:22 »
Was really on the fence with this one, but without a dedicated ANSI layout, I just couldnt do it.
Offline Aerizu
  • Professional Lurker
« Reply #88 on: Tue, 10 July 2018, 03:41:04 »
You might want to re-read the post again.
EDIT:
Not sure if you meant the case or PCB, but I'm pretty sure the case does.
« Last Edit: Tue, 10 July 2018, 03:46:03 by Aerizu »
Offline Koriko
« Reply #89 on: Tue, 10 July 2018, 19:16:08 »
EDIT:
All the more confusing because both support both.
Offline donkey
« Reply #90 on: Thu, 12 July 2018, 22:20:24 »
Got too caught up with work and missed this GB. Dang.
TR-60 could turnout to be a classic so, hopefully, there will be another GB.
Re conflict between hot-swappable and flexible layout, I think the best path forward is to ship unsoldered Kailh sockets for areas with multiple layout options. Soldering Kailh socket seems pretty easy according to this video
Offline bard
« Reply #91 on: Tue, 17 July 2018, 13:29:28 »
GB ends on July 10th
Lead time: 75 days
does it mean that it should be shipped late Sep/beginning of Oct?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #92 on: Tue, 17 July 2018, 22:21:39 »
Offline asury
  • /u/adsury/
« Reply #93 on: Wed, 18 July 2018, 03:20:09 »
I missed the GB  :( any chance for some extra PCBs available?
Grey Duck Sidewinder/GMK Hyperfuse Origins/MX Black retooled | Sage M60-A/GMK Camping/Holy Sky | LFK68/DSA Granite Alps/SKCM Orange Alps
Offline joe405
« Reply #94 on: Thu, 19 July 2018, 21:45:27 »
Would also be keen on getting the hotswap PCB if possible.
Offline wafflehigh
« Reply #95 on: Thu, 19 July 2018, 22:58:18 »
Please take my money.
« Reply #96 on: Mon, 23 July 2018, 22:46:40 »
Lead time: 75 days
if no delays
Offline speaktobrett
« Reply #97 on: Sun, 05 August 2018, 16:06:07 »
Can you please reply to your private messages?
Offline oldcat
  • 65% is Life
« Reply #98 on: Sun, 05 August 2018, 16:58:40 »
Very nice indeed! Great job!
« Reply #99 on: Sun, 05 August 2018, 21:47:56 »
I know it's probably early, but Any update on manufacturing ?
Sent from my Nexus 6P using Tapatalk
