Author Topic: i am not able to see pictures in some posts, only "white dot" showing  (Read 10852 times)
Offline sl70309
Hello,
i am not able to see pictures in some posts, only "white dot" showing.
Could someone please help me.
Thank you.
Offline joey
Re: i am not able to see pictures in some posts, only "white dot" showing
« Reply #1 on: Fri, 29 June 2018, 16:49:13 »
There is an ongoing issue with imgur.
« Reply #2 on: Fri, 29 June 2018, 17:01:50 »
Pics are visible only for those who own the most expensive keyboard on this forum.
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #3 on: Fri, 29 June 2018, 17:18:13 »
:)) Well played.
Offline manitoid
« Reply #4 on: Fri, 29 June 2018, 17:23:36 »
Same here.
« Reply #5 on: Fri, 29 June 2018, 17:36:53 »
Issue is fixed now.
    • Viktus
« Reply #6 on: Fri, 29 June 2018, 17:38:45 »
Issue is fixed now.
Wait so I can remove the chrome extension now?
« Reply #7 on: Fri, 29 June 2018, 18:08:41 »
Issue is fixed now.
Should be able to, yeah.
    • Viktus
« Reply #8 on: Fri, 29 June 2018, 18:17:45 »
Nope...It was still broken when I removed the extension.
« Reply #9 on: Fri, 29 June 2018, 20:00:16 »
try clearing your cache
Offline sl70309
« Reply #10 on: Fri, 29 June 2018, 20:42:51 »
lol. you saw my another post.
