Author Topic: [IC] CA66 Custom Keyboard Round 2 (follow lastest quote for updates!)  (Read 101090 times)
Offline Lormania
Re: [IC] CA66 Custom Keyboard Round 2 (Adding BT PCB option, true final GB)
« Reply #200 on: Wed, 18 July 2018, 12:30:59 »
Hoping for that purple!
Offline swan_soup
« Reply #201 on: Wed, 18 July 2018, 13:11:29 »
Definitely interested
Looking to cop the black
Offline ricrackem
« Reply #202 on: Wed, 18 July 2018, 13:24:50 »
Definitely in for this, has there been a timeframe announced?
Offline cijanzen
« Reply #203 on: Wed, 18 July 2018, 13:57:37 »
I think they were aiming for end of month early August if I’m not mistaken
Offline ricrackem
« Reply #204 on: Wed, 18 July 2018, 14:00:00 »
Exciting!! Thanks :D
Offline _ODIN_
« Reply #205 on: Wed, 18 July 2018, 16:10:03 »
could we get stepped caps lock support?
Offline dondongler
  • Gotta Light?
« Reply #206 on: Wed, 18 July 2018, 16:37:49 »
Pretty stoked for this, definitely in for a dark blue.  :thumb:
Offline Nostril
  • Synth Labs
« Reply #207 on: Wed, 18 July 2018, 19:08:24 »
Looking forward to another group buy! :D
Offline ctrl
« Reply #208 on: Thu, 19 July 2018, 02:51:08 »
If I recall correctly, the original pcb already has stepped caps lock support. It's just not in the KLE layout image.
As for the new bt pcb, it looks like it'll have stepped caps lock support. Just look at the pic of the pcb. In the position for the caps lock key there are cutouts for two different keys: one centered and one off-center.
Please correct me if I'm wrong. I also like stepped caps lock keys. ;)
Offline 11
« Reply #209 on: Thu, 19 July 2018, 10:19:46 »
I saw this keyboard on r/MechanicalKeyboards and fell in love. I am new to all this but I will definitely buy a set once Round 2 opens up.
« Last Edit: Thu, 19 July 2018, 11:14:47 by 11 »
Offline regallegion
« Reply #210 on: Fri, 20 July 2018, 03:41:26 »
Now the big question is... Gray, Burgundy, or really splurge and get both?
Offline Devkey
« Reply #211 on: Fri, 20 July 2018, 17:10:03 »
I would be onboard to get a BT PCB for my round one keyboard
Offline EvergreenTree
« Reply #212 on: Sat, 21 July 2018, 11:45:53 »
Very interested.  Been looking for a portable on-the-go keyboard for a while and this could be it.
Offline Lyle88
« Reply #213 on: Sat, 21 July 2018, 17:25:53 »
I would not consider this portable. It is relatively large, heavy, and I don't think you would want to risk scratching up the anodised finish.
Offline cijanzen
« Reply #214 on: Sat, 21 July 2018, 17:30:18 »
Haha says the person sending from a Pixel XL!
Offline Kerasan
« Reply #215 on: Sun, 22 July 2018, 00:56:01 »
do not believe it is so heavy, it seems to be but it is not.
KMK Labs.
Offline Lyle88
« Reply #216 on: Sun, 22 July 2018, 02:59:26 »
KMK Labs.
How much does it weigh once it's fully built?
Offline Vadurr
  • Valar Morghulis
« Reply #217 on: Mon, 23 July 2018, 00:10:55 »
KMK Labs.
Curious about this as well. I was hoping this thing was gonna be hefty haha.
Offline YisSerL
« Reply #218 on: Mon, 23 July 2018, 00:28:14 »
I read the metal is kind of thin and since there is no weight, it is not heavy at all.
But I think that's the designer's intention for this to be more of a travel board.
Offline beekey
« Reply #219 on: Mon, 23 July 2018, 01:16:31 »
KMK Labs.
In one of the older threads somebody wrote 1.2-1.4kg. One message I found: https://geekhack.org/index.php?topic=93542.msg2549121#msg2549121
Offline PlayKeyboardTW
    • Shop
« Reply #220 on: Mon, 23 July 2018, 01:58:17 »
Just had time to measure.
The size is 365mm x 168mm, 1365g with SA keycaps on approximately. :D
Offline wowremy
« Reply #221 on: Mon, 23 July 2018, 04:24:30 »
Can we make switch pin holes bigger so hot swap sockets will fit?
Offline ipreferpie
« Reply #222 on: Mon, 23 July 2018, 04:47:15 »
Second this as well!
Offline befbef
« Reply #223 on: Mon, 23 July 2018, 05:19:12 »
A version with kailh sockets would be so nice. For the limited layouts available it shouldn't be a big problem to realize. Really no chance to get this option?
Offline Lyle88
« Reply #224 on: Mon, 23 July 2018, 05:40:57 »
KMK Labs.
I dunno about you guys but I don't think 1.2kg is particularly portable. If I was after a take-anywhere board I would probably go for a hhkb.
Offline konstantin
  • Formerly constexpr
« Reply #225 on: Mon, 23 July 2018, 06:45:36 »
+1 for this, but I don't think it's going to happen. If they wanted to keep the layout choices and have Kailh hotswap sockets, it would likely require some of the switches to be sideways; kind of like this:
I don't think that would be much of a problem, as none of the sideway ones would be on R3 (the row that's problematic for Cherry profile caps), but it's kind of... eh, iffy.
« Last Edit: Mon, 23 July 2018, 06:47:55 by constexpr »
    • Shop
« Reply #226 on: Mon, 23 July 2018, 07:02:45 »
KMK Labs.
Everyone has their capability though. I don't carry it myself but I know some guys really do. ;D
No sorry, it may cause shorting for the bottom row.
Uhmmm... no, not going for this.
« Last Edit: Mon, 23 July 2018, 07:05:13 by PlayKeyboardTW »
Offline Hokabuki
« Reply #227 on: Mon, 23 July 2018, 08:54:12 »
Lol that is a very large board to be carrying around.
Offline wowremy
« Reply #228 on: Mon, 23 July 2018, 15:25:50 »
Just confirming, I dont mean Kailh hot swap sockets... The pin holes just need to be like .002 mm or something larger to fit Mill Max socket receptacles...https://www.mill-max.com/products/rec/7305
« Last Edit: Mon, 23 July 2018, 16:28:16 by wowremy »
Offline ideus
  • Björkö.
« Reply #229 on: Mon, 23 July 2018, 15:49:18 »
What is the BT for in a case this heavy? I do not see how this board may benefit of BT. It is an honest question. Do people want to pair this with their phones?  :'(
Offline bthezebra
« Reply #230 on: Mon, 23 July 2018, 15:55:09 »
I was thinking of using the Bluetooth just to have one less cable on my desk. I also think given the cable placement that Bluetooth would allow the board design to be appreciated more and look better on a desk. I am just wondering if there lag when using a Bluetooth on this board.
« Last Edit: Mon, 23 July 2018, 15:59:44 by bthezebra »
Offline cijanzen
« Reply #231 on: Mon, 23 July 2018, 16:40:31 »
I want to use it to play keyboard games in my living room from time to time.
    • Shop
« Reply #232 on: Mon, 23 July 2018, 20:46:47 »
I didn't reply your quote about Kailh sockets. The PCB maker said that it may cause short circuit if expanding switches holes for bot row.
It's not reasonable to make any change just for a demand from few guys.
When a modification is made means we should test it. And what if there are other people wanting to use other sockets?
Hope you can understand. ;)
With a BT option doesn't mean that you need to carry CA66 around. There are people always desiring to make their table cleaner when working.
The BT PCB was just an product made by YANG, and we bring it in this round for guys who are interested in it. :D
Offline cijanzen
« Reply #233 on: Mon, 23 July 2018, 20:48:50 »
I for one am glad to just solder this board and will be damn happy with the switches I choose! Right now leaning towards Kailh Pro Heavy Plum both for heavier linear I want to try and also aesthetically matching the dark red case.
Offline ideus
  • Björkö.
« Reply #234 on: Mon, 23 July 2018, 21:39:52 »
You are right. A wireless CA66 may be attractive for many. Still, not sure if a heavy wireless KB is really that useful. But that is only me. Good luck with the GB.
Offline godlikekitten
« Reply #235 on: Tue, 24 July 2018, 00:35:25 »
200508-0
This is from the last round just wanna say if you aren't hopping on it this time you're missing out ;)
Offline redleaf
« Reply #236 on: Tue, 24 July 2018, 02:11:41 »
That red is the best red I have seen on a keyboard.
Offline Reicheous
« Reply #237 on: Tue, 24 July 2018, 07:54:50 »
can't wait
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
« Reply #238 on: Tue, 24 July 2018, 09:24:30 »
I don't carry mine around with me or anything, but it's really not that heavy. it's no ultra-lightweight like a plank or a HHKB with a plastic case, but it's also not a 4kg monster.
I could see a BT version being used as a travel board by some people.
Personally, I just want BT so I can get rid of one more cord snaking across my desk...
Offline roymt76
« Reply #239 on: Wed, 25 July 2018, 05:03:44 »
As a Graphic designer. I prefer one keyboard with Ctrl,shift,alt in the left hand and full arrow in the right hand
I love this keyboard but the blocker made me think too much :(
https://imgur.com/a/upFduQA
Offline gregoryturtle
« Reply #240 on: Wed, 25 July 2018, 08:35:05 »
Made this account to reply to the GMK Blue Samurai Interest Check and this!
100% in for a BT CA66 and an extra PCB! If custom color request are open to the panel can I suggest a dark navy / blue black color?
Eitherways, I am in for a unit with spare parts and am super hyped for this interest check to transition into a group buy asap!
Thanks for being such a champion Barry!
DZ60 | M60A LAKE | M60A KURO
Offline Owl-
« Reply #241 on: Wed, 25 July 2018, 16:49:49 »
If one only wants to get the BT PCB, would a plate be included? It was mentioned the plate would be improved to allow better wireless BT transmission.
Bumping this question since I've joined the previous round.
That's a 660 layout, it already exists. Leopold, Clueboard and KBDfans are simple sources.
Offline jrfhoutx
« Reply #242 on: Wed, 25 July 2018, 22:17:10 »
I know the BT PCB is going to be available separately for people from the previous round, but will the titanium badge also be available for purchase alone? I didn’t get one last round and I’ve regretted not getting one ever since my board arrived.
Offline forevermadrigal
« Reply #243 on: Thu, 26 July 2018, 04:59:12 »
Idk if this has been asked before, but is there a chance for a 5mm plate?
Offline merlin64
    • MechMerlin
« Reply #244 on: Thu, 26 July 2018, 10:09:42 »
What's the reasoning behind wanting a 5mm plate? Going the way of the Zephyr?
    • Shop
« Reply #245 on: Thu, 26 July 2018, 11:13:10 »
Haven't got mine yet. :-[
It's a big motivation for getting a BT PCB to make your desk cleaner. :))
That's not a CA66 though xD.
Really thankful man. :thumb:
Good ask. I'll note that! :o
I think we'll make some parts to be available to purchase individually. ;D
5mm for a PC plate will be meaningful. We haven't made one before, so there won't be.
Offline Photoelectric
« Reply #246 on: Thu, 26 July 2018, 11:39:34 »
Can there please be a bright dip anodizing option?  It's an extra step before the normal anodizing bath.
Offline befbef
« Reply #247 on: Thu, 26 July 2018, 11:40:04 »
Will the colors be different to the last gb?
How are the chances for white?
Offline Kallus
« Reply #248 on: Thu, 26 July 2018, 19:39:20 »
White anodization is impossible due to the white pigment being larger than the pores of aluminium
« Reply #249 on: Thu, 26 July 2018, 19:46:43 »
He probably means Microarc Oxidation, which is a different type of converting the top layer of aluminum to an oxide and is silver-white in color.  A fair number of recent group buys have used MAO for the "white" color finish.
