Author Topic: Opened up my Uniqey Q100, measured thickness of pcb and case.  (Read 2162 times)
Offline ag36
PCB is 1.6mm, case is 2.0mm~4.6mm. It seems the aluminium case is also an antenna.
« Last Edit: Wed, 04 July 2018, 13:12:42 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Giorgio
Re: Opened up my Uniqey Q100, measured thickness of pcb and case.
« Reply #1 on: Mon, 16 July 2018, 02:06:06 »
Thank you very much for your measurements. I've used the q100 a long time ago, and I thought that the pcb was thicker than that, because of how rigid it felt. Are you overall satisfied with your purchase?
« Last Edit: Mon, 16 July 2018, 05:39:14 by Giorgio »
Offline ag36
« Reply #2 on: Mon, 16 July 2018, 09:32:45 »
Mostly. The proprietary detachable cable is very good quality however not designed for frequent removal also the tool for removing the cable broke after about three uses and unable to remap the keys are major inconveniences but otherwise the keyboard is perfect, I like it.
