Author Topic: Custom 6.5u Alps Stabilizer!  (Read 2353 times)
Offline Acereconkeys
  • Happiness = life - expectations
« on: Sat, 07 July 2018, 01:29:47 »
Hello Geekhack!
I just wanted to share how I was able to cut/bend a 9u stabilizer wire from a WYSE board down into a 6.5u length so I can use it with plate mount stabs. Hopefully it helps someone. For context, the reason I wanted to do this was I want to use Cherry stabilizers in my next custom alps build which uses a 6.5u mx stabilizer (like from PMK, the currently running alps throwback, etc).
Basically, what I did was take the 9u stab wire, cut the end, then meticulously bend it with pliars to try and get it as close to a tight 90 degree angle as possible.
Here's some photos and a video.: https://imgur.com/gallery/MSlBXEr
Next step is to get a tool to try and help me do this better at a tighter angle as you can see in the photo the angle isn't tight enough to sit cleanly in the housing. I'll also be trying to bend another see if i can figure out a way to do it more tightly with just pliers.
« Last Edit: Sat, 07 July 2018, 01:31:58 by Acereconkeys »
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
