Author Topic: Need a guide for compiling QMK for Zeal60  (Read 64567 times)
Offline tofgerl
« on: Mon, 09 July 2018, 14:02:21 »
I don't use Windows. I'm used to programming my Satan boards with TMK, but have never used QMK. There's a link to a fork, but the fork doesn't even have a zeal60 subdirectory under keyboards.
Is there a guide that connects some dots for me without trying to force me to use a for-pay OS?
Offline eeymiel
Re: Need a guide for compiling QMK for Zeal60
« Reply #1 on: Mon, 09 July 2018, 14:16:15 »
I think  you need to switch to the zeal60 branch or follow this link : https://github.com/Wilba6582/qmk_firmware/tree/zeal60
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #2 on: Mon, 09 July 2018, 14:27:57 »
Depends on how/when the commits were made. You'll want to use Wilba's repo that eeymiel linked. You'll either run
Code: [Select]
make zeal60:default
while in the main QMK directory, or switch to qmk_firmware\keyboards\zeal60 and run
Code: [Select]
make default
Optionally replacing 'default' with the keymap you'd choose.
Make sure you have your dependencies set up, you can find them in the qmk_firmware\util directory. There's directions for that on the QMK website: https://github.com/qmk/qmk_firmware/blob/master/docs/getting_started_build_tools.md
Offline tofgerl
« Reply #3 on: Tue, 10 July 2018, 00:37:22 »
This is really weird, but when I clone the repo I don't have the keyboards/zeal60 directory... That's what confused me. Guess I need to solve that problem first.
(Yes, I cloned the fork, not the parent repo...)
https://asciinema.org/a/dXQoMGuryVCljDYWlaLdxNt7I
« Last Edit: Tue, 10 July 2018, 00:45:10 by tofgerl »
Offline JianYang
« Reply #4 on: Tue, 10 July 2018, 01:05:16 »
You have to switch to the zeal60 branch.
git checkout zeal60
Offline tofgerl
« Reply #5 on: Tue, 10 July 2018, 02:15:36 »
Huh, didn't think of that. Yep, that works. Small tweaks, and I am able to compile my default Satan GH60 keymap to Zeal60 right away. Now to get rid of those horrible flashing colors..
