Author Topic: How to safely disassemble a QuickFire Pro?  (Read 2369 times)
Offline Sgt_4Leaf
  • Formerly Row009 and StarCraftII
  • I have hands
« on: Wed, 11 July 2018, 16:57:00 »
Hello Ya'll,
I need to open up my Cooler Master CM storm QuickFire Pro (what a short catchy name, huh).
Where can I find reliable data of how to do that properly?
Also, would anyone happen to know if it is normal to be required to type a verification code and the same stupid "A Popular serial bus for keyboard connectivity" question prior to each and every post and reply?
Thanks in advance,
Re: How to safely disassemble a QuickFire Pro?
« Reply #1 on: Wed, 11 July 2018, 17:48:07 »
I've not disassembled a coolermaster in a few years but if there are any bottom screws remove them, probably one under the sticker.
Then use a spudger or some thin plastic pry tool and carefully separate the top and bottom half, there are probably plastic clips to release.
And the verification goes away after 10 posts I think.
I didn't search but there could be a thread on this buried in the deep.
Offline Sgt_4Leaf
  • I have hands
« Reply #2 on: Wed, 11 July 2018, 19:00:05 »
Thanks..
« Reply #3 on: Wed, 11 July 2018, 19:18:55 »
there was like a whole forum dedicated to modding qfrs lol
but yes it's 1 under the sticker and then pop the clips with a credit card
