Author Topic: How tall is the Cooler Master masterkeys S (pbt) ?  (Read 2135 times)
Offline AmigaDisk
  • Formerly ohm-ish
« on: Sat, 14 July 2018, 15:06:40 »
All I can find is that it's "33mm in height"..
I assume that's the tallest side? It has an angle upward like most other keyboards
How tall is it at the bottom lowest side?
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
Re: How tall is the Cooler Master masterkeys S (pbt) ?
« Reply #1 on: Sat, 14 July 2018, 15:12:50 »
21.5mm. They measured including the bottom rubber feet by the way, which are 2.5mm tall.
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Sat, 14 July 2018, 15:28:16 »
Allright thanks
