Author Topic: [GB] Southpaw Full Size - Shipping and remanufacturing  (Read 133718 times)
Offline reconsiderit
  • I'm actually not left handed www.switchplate.co
Re: [GB] Southpaw Full Size - GB open till 7/29 - 27 spots left
« Reply #50 on: Sat, 28 July 2018, 17:38:21 »
Any possibility that the case will have an underglow diffuser option?
If you chose to have a brass weight, I'm sure you could make some kind of transparent insert.
Yep I did choose the weight option.  Anyone know of anyone who does diffusers like this?  Does the SP PCB have underglow?
From the prototype board above, the layout doesn't seem to support surface mount RGB leds. Maybe there's a spot for them and I'm just not seeing them. Anyway, to make diffuse would be really simple, you just measure the hole size (from the inside) and the height and then laser cut a piece of acrylic to fit in that spot and screw in via the screw holes. Won't sit flush with the bottom side, but I guess that wouldn't matter so much.
Gonna clear this up a bit, but even if you do this, it most likely won't work too well. The gap that separates the top and the bottom sits right under the plate and if you were to put a diffuser there, it would have to be pretty damn thick (more than the standard 1.5mm found on duck or other boards) to show and lighting from SMD LEDs placed underneath the PCB. Effectively, the diffuser would be between the PCB and the plate.
Southpaw 65 || Southpaw Full Size || Trinity XT TKL || TGR Jane V2 || TGR 910 RE || Duck Jetfire || Matrix Lab 1.2 OG || Jubi || Lunar || Lunar II || g80-1800 HEU
switchplate.co
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #51 on: Sat, 28 July 2018, 20:49:55 »
If we don't reach the 65 units, I assume this still going to production, right? Is there an moq? Or just an order cap?
Offline att1cus
« Reply #52 on: Sat, 28 July 2018, 20:51:33 »
I believe the MOQ on this one is 45 units.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #53 on: Sat, 28 July 2018, 21:27:51 »
So we need 7 more entries o.O
Offline att1cus
« Reply #54 on: Sat, 28 July 2018, 21:30:03 »
Yep I've been keeping track.  I think one person posted here since reconsiderit updated the topic, so hopefully that brings it down to 6. Really hope we hit it!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #55 on: Sat, 28 July 2018, 21:32:40 »
I'm going to be devastated if this doesn't go to prod
Offline att1cus
« Reply #56 on: Sat, 28 July 2018, 22:18:36 »
Re: [GB] Southpaw Full Size - GB open till 7/29 - 22 spots left
« Reply #57 on: Sun, 29 July 2018, 00:27:53 »
I know at least two people who are planning to buy one, i'll harass them in the morning
Offline ag36
« Reply #58 on: Sun, 29 July 2018, 09:09:47 »
Ordered two of these instead of one because shipping cost :)
« Last Edit: Sun, 29 July 2018, 09:39:43 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline babyphil
« Reply #59 on: Sun, 29 July 2018, 09:26:47 »
Hopefully it makes moq. I sold 3 boards to afford buying this board.
Offline spooknik
« Reply #60 on: Sun, 29 July 2018, 10:07:13 »
Me too! I sold my SA Godspeed set to join this GB. By my very rough and non-official calculations, I think we'll just hit MOQ. We'll find out tomorrow I guess.
Offline nevaenuf
« Reply #61 on: Sun, 29 July 2018, 12:17:31 »
I joined last night.  At least that's one more toward MOQ.
Offline o3okevin
« Reply #62 on: Sun, 29 July 2018, 14:07:29 »
Ordered! Hope we can make it  :D
Offline spooknik
« Reply #63 on: Sun, 29 July 2018, 14:50:25 »
All these last minutes orders! It's really great, I think we can make it.
Offline att1cus
« Reply #64 on: Sun, 29 July 2018, 14:52:07 »
According to reconsiderit on Reddit, we've reached MOQ!
https://www.reddit.com/r/mechmarket/comments/90ic5i/gb_southpaw_full_size/e38p22o/
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #65 on: Sun, 29 July 2018, 15:05:18 »
Offline babyphil
« Reply #66 on: Sun, 29 July 2018, 16:06:05 »
Awesome!
« Reply #67 on: Sun, 29 July 2018, 17:27:49 »
nice
good spot
im hype for this
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #68 on: Tue, 31 July 2018, 21:16:34 »
So what's the dillio? We met moq. Orders are being submitted?
« Reply #69 on: Wed, 01 August 2018, 18:50:02 »
Yep. All of the rest of the orders came on the last day.
switchplate.co
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
Re: [GB] Southpaw Full Size - Finalizing Orders
« Reply #70 on: Wed, 01 August 2018, 23:40:02 »
awesome design, so sad I missed this...
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #71 on: Wed, 08 August 2018, 20:08:42 »
Sent you an email but I figured I'd follow up here.
I saw the email for the re-invoice, but I haven't seen a refund for the original yet. Will you be processing those soon?
I don't want to pay the new invoice until the refund has been issued.
Offline StrangPrisoner
« Reply #72 on: Thu, 09 August 2018, 00:40:07 »
I emailed him will be waiting for the reimbursement as well. My PayPal invoice(?) says that I will be reimbursed Friday August 10th to my pay pal balance. So it seems to be a PayPal thing.
Offline alisonica
« Reply #73 on: Thu, 09 August 2018, 13:23:00 »
Sent an email to Glorious GB leader. Paid the re-invoice, also received the refund.
Following up here:
1) Since hard anodization black is not possible, can I go for normal anodizing with Grey color?
2) Need KLE files for Alps plates. :thumb:
« Reply #74 on: Thu, 09 August 2018, 19:29:27 »
What's this about a reinvoice? I haven't heard anything.
Offline alisonica
« Reply #75 on: Thu, 09 August 2018, 20:33:38 »
Only for those who chose Hard Anodizing :)
« Reply #76 on: Thu, 09 August 2018, 21:45:04 »
i chose hard anodizing
Offline o3okevin
« Reply #77 on: Thu, 09 August 2018, 22:00:32 »
Hard anodizing + 7075 aluminum
« Reply #78 on: Thu, 09 August 2018, 22:05:48 »
ah ok
i got 6061
wkl w/ red half plate
was just unclear about what was going on, thanks friends
Offline Paopawdecarabao
« Reply #79 on: Fri, 10 August 2018, 10:43:30 »
Ugh! I wish I saw this sooner. Missed the GB  :(
« Reply #80 on: Fri, 10 August 2018, 12:49:37 »
Just checked my PayPal to see if the refund processed. It is now saying: "We're processing your refund and your money will be available on August 23, 2018We're processing your refund and your money will be available on August 23, 2018". I really don't want to tie up a grand in this group buy so I'm hoping to wait until the reimbursement is issued.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #81 on: Fri, 10 August 2018, 12:59:13 »
At least it see the refund in PayPal. I haven't seen anything.
Offline sangoan
« Reply #82 on: Fri, 10 August 2018, 13:27:20 »
i chose 7075+hard anodized
but nothing happen
Offline forumusername
« Reply #83 on: Fri, 10 August 2018, 17:54:49 »
Are ppl getting Alps plates?
« Reply #84 on: Fri, 10 August 2018, 19:42:47 »
Hey guys, a quick update, but I just visited the factory yesterday and discussed everything with them and had them go over all the important parts.
There are some issues with refunds and organizng the hard ano orders which need to be changed because my computer decided to try and update with 2% in the battery and basically bricked itself. I'm going to see what I can do locally and try and get my computer back up and running so I can get those refunds through and finalize the orders to submit to the factory on Monday.
If you have any questions, it's better to PM me on discord as that's the easiest way to communicate atm.
switchplate.co
« Reply #85 on: Sat, 18 August 2018, 07:59:23 »
Did those orders end up getting submitted to the factory?
« Reply #86 on: Sat, 18 August 2018, 09:29:41 »
Still waiting on a number of people to pay their reissued invoices as they're waiting on the system to process their refunds. It'll probably be submitted at the end-ish of this week or next week when I'm back in the US.
switchplate.co
« Reply #87 on: Sat, 18 August 2018, 10:08:20 »
Cool. Thanks for the update.
I saw a hard anodized norbaforce last night and it made me even more excited for this board.
Offline HappyCatFish
« Reply #88 on: Fri, 24 August 2018, 12:29:43 »
Has the order been placed? It feels like this GB is already off to a rocky start...
« Reply #89 on: Fri, 24 August 2018, 19:23:38 »
as long as the runner sticks around im not that worried
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #90 on: Fri, 24 August 2018, 23:14:55 »
I've got complete faith in reconsiderit
« Reply #91 on: Sat, 25 August 2018, 02:54:19 »
I've finalized numbers and am waiting on a final invoice from the factory. Shouldn't be too long before I start sending out pics of things being made.
It took a little while to get things started as I went to China to check up on things to make sure things wouldn't fall apart midway though the GB. Just got back this Tuesday. I'll have some pics to share later.
switchplate.co
Offline spooknik
« Reply #92 on: Sat, 25 August 2018, 04:28:33 »
Woah, you went to China to check things over? That's really reassuring! Can't wait to see some pics.
« Reply #93 on: Sat, 25 August 2018, 10:50:12 »
damn, impressive
excited
Re: [GB] Southpaw Full Size - In Production
« Reply #94 on: Mon, 17 September 2018, 01:10:11 »
been like 3 weeks, any updates?
« Reply #95 on: Mon, 17 September 2018, 02:09:05 »
Order submitted and paid for. The factory hasn't started anything yet but they're in the process of ordering materials. The typhoon that hit just this week will probably slow things down a ittle bit, but once I get a solid date back from them I'll start doing updates.
switchplate.co
Offline ctrl
« Reply #96 on: Mon, 17 September 2018, 04:30:11 »
Damn. Found this just now. Left handed full size would pretty much be the *only* full size kustom I'd be really down for. Will there be extras down the line? Or any thoughts about an R2 (myabe to early to tell now)?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #97 on: Mon, 17 September 2018, 07:58:31 »
Sweet! Thanks for the update man!
« Reply #98 on: Mon, 17 September 2018, 11:37:34 »
Beauty. Hope everything is cool there after the typhoon. Thanks for the update.
« Reply #99 on: Wed, 19 September 2018, 13:21:33 »
In case anyone didn't get it, there was an email update stating that machining has begun.
