Author Topic: Quick question on Cherry switches  (Read 3047 times)
Offline Austinl08
« on: Mon, 30 July 2018, 19:45:39 »
If i have some Cherry reds that i want to swap to blues, can i just open the switches and swap the internals or do i need to replace the entire bottom of housing as well? i swapped the internals of 2 loose switches and it seemed to work fine. just wanted to see if someone has done this with success or not and to make sure im not missing something else different on the inside besides the core slider and spring tensions.
Thanks in adavance.
Re: Quick question on Cherry switches
« Reply #1 on: Mon, 30 July 2018, 21:39:27 »
Yes you just swap the stems and springs.
Offline Austinl08
« Reply #2 on: Mon, 30 July 2018, 21:58:53 »
Thank you!
« Reply #3 on: Tue, 31 July 2018, 15:37:47 »
Actually, Reds and Blues are supposed to have the same type of spring, so all you would need to swap are the stems.
« Reply #4 on: Tue, 31 July 2018, 15:44:53 »
Assuming you can get the switch tops off it will work - most non DIY boards have plates with no cutouts so you can't swap them without desoldering the whole switch.
Offline Austinl08
« Reply #5 on: Fri, 24 August 2018, 23:21:26 »
yeah all mine are DIY with the cutouts, thanks for looking out for me though!!
