Author Topic: Finally, we got GK64 and GK84 in stock  (Read 26487 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Thu, 02 August 2018, 02:34:36 »
GK64 60% Custom Keyboard
  - Full RGB with a dedicated software for programming and RGB lighting.
  - Rosewood Case
  - PBT 5 Sides Dye-subbed Keycaps (cherry profile)
  - USB type C port
  - Hot-swap for switches (Similar to Holtites). (Allows you to change switches without soldering)
  - Dedicated arrow keys with split RSHIFT
GK84 75% Custom Keyboard
   - Bluetooth+Type-c Dual Mode
  - Rosewood Case
  - USB type C port
Detail PAGE
Offline Poblopuablo
Re: Finally, we got GK64 and GK84 in stock
« Reply #1 on: Fri, 03 August 2018, 07:54:49 »
Do they come with switches?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Mon, 06 August 2018, 01:27:23 »
Yes. you will receive a complete keyboard.
Offline zumu
  • Professional Typist
« Reply #3 on: Mon, 03 December 2018, 12:15:34 »
Any plans for a aluminum version(s)?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #4 on: Fri, 07 December 2018, 19:12:17 »
Em, we hope the supplier has aluminium version as well.
We have another similar keyboard from them, which is aluminium case, GK68.
https://kprepublic.com/products/gk68-rgb-aluminum-mechanical-keyboard-cherry-rgb-blue-brown-black-red-switch-type-c-hot-swappable-switch-with-dye-subbed-keycap
