Author Topic: [IC] Mill-Max Sockets (7305)  (Read 9515 times)
Offline pxlnght
« on: Fri, 03 August 2018, 10:32:46 »
Hey all, I don't really use GH all that often so forgive my formatting if it's off. I'm pxlnght on Reddit btw. I have several confirmed trades on mechmarket if you're leery about my short GH history.
Reddit link: https://www.reddit.com/r/mechmarket/comments/949oct/ic_millmax_sockets/
I'm looking to run a GB for Mill-Max Sockets, the 7305 variant. I was planning on using the 0305 variant, however it seems they're known for causing issues with stablizers not returning.
Copy paste of the Reddit post:
I want some Mill-Max sockets for an upcoming build, and there are some significant price breaks for higher order quantities. I don't like holtites because of their friction based 'locking' mechanism. These, you solder to the board. They're sure as heck not going anywhere. You'll need two per switch.
Product Link: https://www.digikey.com/products/en?keywords=7305&keywords=7305-0-15-15-47-27-10-0&pkeyword=7305&v=
Pricing guide: See link. Make sure you've viewing in USD.
Proposed Rules:
- Total MOQ will be 1,000 sockets. This is just to keep the price reasonable. We should be able to hit this pretty easily.
- I'll be invoicing based on the order quantity, rounded up the the nearest whole cent. So, 1,000 total sockets would be $0.25 per socket, 2,500 sockets would be $0.22 per socket. I'm currently contacting digikey for an extended MOQ list, beyond 2,500, just in case we get that far.
- Order quantities must be in increments of 10.
- MOQ per order is 50 sockets.
- Shipping CONUS is $5 dollars per order, regardless of quantity. (Shipped first class, but I also need to grab some bubble mailers and baggies).
- No international shipping will be offered, sorry lads.
This will be my first GB, so if there's something I'm missing please let me know!
« Last Edit: Fri, 03 August 2018, 10:49:57 by pxlnght »
Offline dohmain
Re: [IC] Mill-Max Sockets (7305)
« Reply #1 on: Fri, 03 August 2018, 12:15:15 »
arrow.com is having 30% off sale with free overnight for new users until Monday.
And they are cheaper than digikey to begin with.
https://www.arrow.com/en/products/7305-0-15-15-47-27-10-0/mill-max
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #2 on: Fri, 03 August 2018, 12:16:04 »
Not sure if you’d have the answer to this since you don’t have them yet but how would these compare durability-wise to Kailh hotswap sockets?
(credits to Kokaloo)
Offline dohmain
« Reply #3 on: Fri, 03 August 2018, 12:20:31 »
I haven't used these, but I am not a fan of the Kailh sockets as the contacts can stretch open after a bunch of swaps. I would imagine these would be more durable than the Kailh sockets. These are basically holtites in a sleeve.
However, between these and the Kailh sockets there's really no point in comparison because a PCB will support only one or the other. It's not like you can choose which to use on whatever PCB you have.
Offline pxlnght
« Reply #4 on: Fri, 03 August 2018, 12:54:35 »
Ah geeze... Might have to significantly speed up my timeline, in this case. Thanks for the info, I'm going to chat w/ the mods on /r/mm and see if I can bypass the 48hr rule for posting... Does GH have a post limit on GB/IC threads? I'm still pretty new here and I don't want to step on any toes.
Offline olivia
« Reply #5 on: Fri, 03 August 2018, 15:59:30 »
I think it is 25 posts?
Offline dyka.tran
« Reply #6 on: Sat, 04 August 2018, 02:25:34 »
Is this the alternative option for Holtite? I'm new to this field.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #7 on: Sat, 04 August 2018, 05:02:40 »
I'm in for another round if anyone wants to hold a GB!
Offline _ODIN_
« Reply #8 on: Sun, 26 August 2018, 10:06:33 »
Same question
Offline excluisve
  • Making & Thinking.
« Reply #9 on: Sun, 26 August 2018, 10:34:32 »
Offline plexabyte
« Reply #10 on: Fri, 28 September 2018, 10:05:57 »
Have you done any measurements to confirm these will fit into any holtite-compatible board?
Offline piit79
« Reply #11 on: Fri, 30 November 2018, 02:54:46 »
Hey, I started another GB for these: https://www.reddit.com/r/mechmarket/comments/a1heqs/gb_mill_max_sockets/
We're nearly there, just a few hundred sockets to go.
