Author Topic: Thoughts on GMK keysets  (Read 7716 times)
Offline killyou
« on: Tue, 07 August 2018, 12:12:04 »
I just got my first GMK set and fist Cherry profile set at that. Until now I was using OEM profile keycaps only and it's not a mystery that I got used to it. GMK looks absolutely gorgeous and crisp but comparing to my default Pok3r PBT OEM keycaps GMK set sounds higher pitched, less bassy and profile of the keycaps is flatter and all that is making me crazy. Have anyone else experienced something similar? I'm not sure whether that's something that I will be able to get used to and I'm thinking of selling it despite loving how it looks :/
Offline 9999hp
Re: Thoughts on GMK keysets
« Reply #1 on: Tue, 07 August 2018, 12:15:35 »
GMK is made from a different plastic
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Tue, 07 August 2018, 12:30:19 »
That is because GMK keycaps are made out of ABS plastic. ABS has a specific gravity value of about 1.04 and PBT has an SG of about 1.3. It's a measure of density, so PBT is "denser".
Offline syris226
« Reply #3 on: Tue, 07 August 2018, 13:10:06 »
I think that this picture will help you out in terms of seeing how flat / steep keysets are.
As others said PBTs are thicker and therefore sound different. They also wear much differently. I've had PBTs on one board roughly 1 year longer than my GMKs -- and the GMKs are starting to shine whereas the PBTs are not. However, GMKs stuff is very pretty indeed. It's a trade-off that I'm willing to put up with.  ;D
Offline stolenweapon
« Reply #4 on: Thu, 09 August 2018, 03:26:29 »
thick pbt usually sounds deeper
OTD 356CL Black | 2x OTD 356CL Gunmetal | OTD 356.2 Factory Gray Ano 1/2 | 2x OTD 356.2 Blue Grey | 2x OTD 356mini Military Green | 5x OTD 356mini Red | OTD 356mini Black | 9x OTD 360C Apple Silver | 2x OTD 360C Hyper Grey | OTD 356L | 2x OTD 356N MKII Black | OTD 456GT Pink & Black | 3x OTD 356 Pad (2x Black, 1x Military Green) | 2x OTD Koala WKL Silver & Black | OTD Koala WK Silver & Black
TGR Jane V2 Pink Prototype 1/1 | TGR Jane V2 1/2 Brushed Toblerone Weight | 8x TGR Jane V2 | 6x TGR Jane CE V2 | TGR 910RE | TGR 910 VKC | TGR Alice Purple 1/5 | TGR Alice Red | TGR-03 | TGR Tris
LZ-SE | 3x LZ-RE | LZ-CP | LZ-MP SE
Keycult No.2 Stainless Steel | 2x KMAC Happy | 2x DK Saver MX & Alps
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Thu, 09 August 2018, 03:45:54 »
I disagree, ABS sounds deeper than PBT, and thick sounds quieter than thin. For the deepest, fullest sound, I recommend thin ABS.
Offline killyou
« Reply #6 on: Thu, 09 August 2018, 04:10:25 »
I compared GMK Cherry profile set to PBT Pok3r OEM keycaps which are a bit thinner and the latter sounds deeper. I think that might be OEM profile more than the material the keycaps are made of. Also I noticed that my Zealio 67g are snappier with OEM keycaps while more mushy and less snappy on Cherry profile keycaps which is interesting. I decided to get rid of GMK keycaps.
Offline Legonut
« Reply #7 on: Thu, 09 August 2018, 06:40:37 »
My GMK keycaps wore down pretty quickly (a few months) in the WASD area. I wouldn't recommend them if you're gaming.
Offline Giorgio
« Reply #8 on: Thu, 09 August 2018, 07:22:27 »
"wore", they shined, that's all.
Offline Sup
« Reply #9 on: Thu, 09 August 2018, 18:45:19 »
I noticed the higher pitch when i switches from PBT cherry profile key caps. Other then that i like ABS more feels softer :).
current
Coming soon
« Reply #10 on: Thu, 09 August 2018, 19:29:56 »
i like GMK
Offline nogoodnames444
  • I like keyboards
« Reply #11 on: Fri, 10 August 2018, 00:42:51 »
Yeah my pbt cherry profile caps have a much louder sound signature that any of my other keycaps
