Author Topic: [IC] GMK DMG - A Gameboy inspired keyset GROUP BUY IS LIVE!  (Read 236017 times)
Offline Corgiattackkk
Re: [IC] GMK DMG - A Gameboy inspired keyset - COLOUR GUIDE AND SIG ADDED
« Reply #100 on: Sat, 08 September 2018, 17:22:07 »
Love the theme and colors of this set. I don't think you have to go crazy with novelties, even just a couple artisans such as the translucent cap (green to represent the screen) or an artisan, like Rama's wave cap to represent the ridges on the back would be fun  ;D
Would love to see some text modifier, such as 'select' and 'start' along with the the magenta color arrow keys.
This is completely extra, but I love the IC picture based off the original box and would think it would be neat to have a deskpad with that kind of design or aesthetic.
I'd actually like to see an optional arrows pack the same color as the Gameboy's d-pad.
That's what I was thinking too. And maybe some Select and Start novelties too
Haha I mentioned those when the IC was first posted and don't know if it was seen. Hopefully since more people seem interested, there might be some of those included.  :thumb:
Offline Quakemz
« Reply #101 on: Wed, 12 September 2018, 02:17:33 »
This is an absolute winner. Can't wait until it hits GB phase! <3
Offline futurecrime
  • Get Zooted
« Reply #102 on: Thu, 13 September 2018, 19:55:30 »
I've been thinking on it. I'm gonna mock something up.
Offline warmaster
« Reply #103 on: Fri, 14 September 2018, 03:11:28 »
Love this - accents and windowed keys are perfect.
Offline Cbisquit
    • Twitter
« Reply #104 on: Mon, 17 September 2018, 16:02:25 »
This is one clean set.   :thumb:
Offline Jkush463
« Reply #105 on: Mon, 17 September 2018, 16:48:08 »
id like to see this happen great looking set with a nice color way.
Offline kchlam
« Reply #106 on: Mon, 17 September 2018, 19:41:49 »
Can't wait for the GB, literally my childhood right here
Offline axios67
« Reply #107 on: Mon, 17 September 2018, 22:38:36 »
Really like this idea, would like to see a novelty pack though.
Offline futurecrime
  • Get Zooted
« Reply #108 on: Tue, 18 September 2018, 03:52:32 »
TKC is currently getting quotes from GMK for the kits (including a novelty kit). We're also looking to keep the price down so you'll probably see some changes in the base kit. I want to please as many people as possible but if the kit is too big and expensive to hit MOQ then everyone loses. It's a tightrope act. Stay tuned.
Oh, and we're hoping to run the GB within two months from now.  :thumb:
Offline te_dulce
« Reply #109 on: Thu, 20 September 2018, 15:11:30 »
It would be amazing if you offered a 40s kit and icon mods.
Seconding icon mods.
Offline nasp
« Reply #110 on: Tue, 25 September 2018, 00:07:26 »
Two months from now!! Hype! I know what I want for Xmas!
Offline Nzo
  • wish I was back in CA
« Reply #111 on: Wed, 26 September 2018, 13:46:37 »
Aren't the A-B buttons on the gameboy red? The magenta really throws me off the theme although it probably does look better than red would.
Offline nasp
« Reply #112 on: Wed, 26 September 2018, 20:35:33 »
No, there's a photo on the first post
Offline futurecrime
  • Get Zooted
« Reply #113 on: Thu, 27 September 2018, 08:00:23 »
The colours will be matched to a Gameboy that I'm gonna send to GMK. I don't think there's any way to get a better match than that. But yes, as nasp said, the buttons are magenta, not red.
On another note, we're hoping to have a big update very soon - with renders and maybe some price estimates - probably after this weekend. In terms of set changes it looks like it'll just be very minor changes to the base kit, just subtle design decisions and corrections.
There will be an MOQ of 250 for this set, due to the custom colours, so please do spread the word if you want to make this a reality.
Offline Cktenders
« Reply #114 on: Thu, 27 September 2018, 09:08:54 »
Any chance for a r4 1.5u function/super/meta key in the base kit or one of the add-ons?
Offline nasp
« Reply #115 on: Fri, 28 September 2018, 13:19:19 »
I think I found your vendor  ;)
Offline Jkush463
« Reply #116 on: Fri, 28 September 2018, 16:49:36 »
sweet im in for a set cant wait to see pricing estimates so i can get ready.
Offline obertau
« Reply #117 on: Fri, 28 September 2018, 22:42:36 »
I’d love an epbt by changing the white font to purple on the pink keys. Pbt and no shine but captures the full look. Amazing.
Offline NINJER
« Reply #118 on: Fri, 28 September 2018, 22:47:55 »
This is an awesome set.
Will deffs join the GB.
Any novelties?
Offline finalarcadia
« Reply #119 on: Sat, 29 September 2018, 13:04:23 »
Not sure if it's been mentioned, but caps lock "select" and enter "start" novelties would be fitting.
Offline SolidCactus
« Reply #120 on: Sat, 29 September 2018, 15:37:51 »
I will def be picking up a set or two once this drops! Top work!
Offline Nerdbot5000
« Reply #121 on: Sat, 29 September 2018, 19:55:40 »
Love this idea, or anything else that would been ambiguous enough for the use of function where caps lock usually is.
Offline fractl
« Reply #122 on: Mon, 01 October 2018, 12:50:39 »
Not trying to critical... just had an observation when I was thinking about how I would use the set.  I was thinking about how I would use it on an ortho keyboard, like the Planck or Preonic.  I occurs to me that, if you use the esc and return keys with the magenta font, then this would look good with the raise key also with the magenta font, but, if you use the magenta esc and return with the white font, then all of the gray keys will have the blue font, except the raise key, which would be the single key with the magenta font.  The first layout seems like it would look good, but the second one seems like it would look odd, with only one key with a magenta font sitting there unbalance.
Anyway, like I said, I just tried to visualize it, and it didn't really seem right, if you used the accent keys, which I like.  Just my opinion, for what it's worth.  Also, if you were doing a Preonic build and wanted to have a caps lock and second shift, there wouldn't be dedicated keys for that, but I realize it's pretty common to use other keys, like meta or code for such things.
Offline dangboy
  • yes
« Reply #123 on: Fri, 05 October 2018, 01:12:24 »
100% in on this. take my fkin money
Offline qazeqaz
« Reply #124 on: Fri, 05 October 2018, 08:57:42 »
Definitely interested in this one.
Offline captsis
  • Formerly matt2dlg
« Reply #125 on: Sun, 07 October 2018, 15:24:31 »
im in!
Offline futurecrime
  • Get Zooted
« Reply #126 on: Tue, 09 October 2018, 06:47:24 »
I got a really nice condition box-fresh-lookin' Gameboy on ebay and it arrived today. This is the Gameboy GMK will try to match the cap colours to.
Renders are in progress, the kit has seen a few changes now. Big update very soon and group buy shouldn't be too far off (my guess is November, but possibly earlier).  And sorry if you've commented and I haven't addressed it specifically, but I am reading everything and taking everything into consideration. Peace.
Offline Hawkfriend
  • K E Y B O R T S
« Reply #127 on: Tue, 09 October 2018, 06:49:47 »
Looking forward to it futureman
Offline nasp
« Reply #128 on: Tue, 09 October 2018, 11:04:57 »
Futurecrime,
Great work! I'm curious to know where you get the keycap color samples with the labels. Also, I've seen other people with Pantone color wheels. As someone who is interested in designing keycaps, where would I find these things?
Thanks for the help.  :thumb:
« Reply #129 on: Tue, 09 October 2018, 20:54:02 »
From that last gameboy pic, seems the modifiers will be darker than the renders. Which I like more honestly.
Offline NINJER
« Reply #130 on: Tue, 09 October 2018, 20:57:24 »
Even though RO1 is more accurate, I like MG1 better!
Sent from my SM-N960F using Tapatalk
Offline forevermadrigal
« Reply #131 on: Tue, 09 October 2018, 23:50:16 »
Dank gameboy :cool:
Offline NorrisB
« Reply #132 on: Sat, 13 October 2018, 10:42:55 »
Perfect, absolutely perfect
Offline whitty
  • Formerly dsw_408
« Reply #133 on: Sat, 13 October 2018, 11:03:24 »
I personally like the look of the lighter mod color in the renders. It seems like the color you’re matching to the gameboy will be significantly darker. Is that a fair assumption?
Offline MMKB
« Reply #134 on: Sat, 13 October 2018, 12:10:47 »
 :cool: Love it. Very original and the colors matches well. Personally think icon mods are cooler.
Offline amnesia0287
  • Formerly Amnesia
« Reply #135 on: Sun, 14 October 2018, 09:50:50 »
Futurecrime,
They used to give them to people, now they sell them.
https://uniqey.net/en/gmk-color-ring?c=11
Offline Albatross
« Reply #136 on: Sun, 14 October 2018, 12:01:06 »
I also prefer the lighter mod color, it definitely blends in better with the set. It'd be understandable however if you decide to choose a darker color to best match the Gameboy.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #137 on: Sun, 14 October 2018, 13:46:10 »
Are you leaning towards DY for the legend colour?  I like it!
Offline garbo
« Reply #138 on: Mon, 15 October 2018, 04:42:13 »
Is there any cost to be saved by having only some of the colours be custom? Might as well go for max accuracy if GMK have the actual Gameboy to sample from.
« Last Edit: Mon, 15 October 2018, 04:44:55 by garbo »
Offline dantambok
« Reply #139 on: Mon, 15 October 2018, 04:47:54 »
Excited for this. Is there any planned timeline at all?
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline dangboy
  • yes
« Reply #140 on: Mon, 15 October 2018, 08:07:16 »
This. Wouldn't mind paying more if the colors were spot-on.
Offline futurecrime
  • Get Zooted
« Reply #141 on: Mon, 15 October 2018, 14:56:29 »
Futurecrime,
Yes. This. And Pantone colour wheels and books and chips are available from the Pantone website but he warned, they ain't cheap.
Offline futurecrime
  • Get Zooted
« Reply #142 on: Mon, 15 October 2018, 15:19:37 »
All the colours will be custom. I only put the GMK stock colour samples in those pics so everyone could get a reference based on existing sets, regardless of monitor calibration. Regarding the modifier grey, I want to match the Gameboy as much as possible, but the screen surround is very shiny and often appears lighter than it does in those pics. I also feel like the legends could get lost if the grey is too dark. There will be samples so I'll judge it as best I can and find the happy balance of fidelity and legibility.
Offline futurecrime
  • Get Zooted
« Reply #143 on: Mon, 15 October 2018, 15:23:35 »
Couple of weeks hopefully. Just waiting on quotes and renders.
Offline dantambok
« Reply #144 on: Mon, 15 October 2018, 18:41:35 »
awesome. Thanks man!
Stuff  I have
100+ GMK sets
Offline sJ1N
« Reply #145 on: Wed, 17 October 2018, 16:51:18 »
ooo looks good :)
« Reply #146 on: Thu, 18 October 2018, 02:30:58 »
I don't have Gameboy nostalgia, but I like the colour scheme. Dark purple legends on white background is a classic also on computers keyboards (e.g. Wyse, Sun), as is an accent colour on the Return key.
I don't see why the Insert, Home and PgUp keys need to have a different text colour though. Personally I prefer that the Return/Enter key should be named "Return" but I don't understand why the numpad-Enter should also be "Return".
BTW, I think it a missed opportunity to not name the Windows key "Start" (the "Start menu"!) and the Menu key "Select".  (Although, "Select" has a different meaning on vintage terminal keyboards, not many people remember it)
Offline Volsairine
  • hedonist
« Reply #147 on: Thu, 18 October 2018, 02:36:00 »
These are fantastic. Any place where I can join an email listing to receive updates? Sorry, I'm new to this forum. ^^"
Offline futurecrime
  • Get Zooted
« Reply #148 on: Thu, 18 October 2018, 10:32:08 »
Thanks for the feedback. The nav cluster colour is inspired by the two stripes on the screen border of the Gameboy.
I had designed Start and Select novelties among others but the kit I designed would have been unfeasibly large. There will be a novelty included with the final base kit (soon to be revealed). TKC will be working with other makers to produce some more Gameboy inspired keys available separately after the GB.
Offline futurecrime
  • Get Zooted
« Reply #149 on: Thu, 18 October 2018, 10:34:29 »
you can join TKC mailing list here: https://thekey.company/pages/sign-up
Follow my instagram (in my sig)
And/or follow this thread!
The buy is aiming to go live on Nov 1st. Renders are imminent!
