Author Topic: [GB] Fox Lab Leaf 80  (Read 102862 times)
Offline Delirious
Re: [GB] Fox Lab Leaf 80
« Reply #50 on: Thu, 16 August 2018, 09:19:03 »
Senter, I notice that there isn't an option for an WK Alps kit. If I ordered the Winkey MX kit + extra Alps plate, would that offer WK Alps support?
The PCB was designed to support ALPS + WKL only. If you have some nice WK ALPS caps, I would suggest you to drill holes on the PCB and do the wiring. It requires some skills but it's feasible. I did it once. I can help you to change the case layout to WK if you want to do it. I can't guarantee it will work tho.
I can confirm the TIME pcb is actually very well put together for manual drilling.
« Last Edit: Thu, 16 August 2018, 09:49:21 by Delirious »
Offline Abec13
« Reply #51 on: Thu, 16 August 2018, 11:34:45 »
Is it possible to order the weight a different color from the plate?
I would love a white one, black plate, gold (yellow) weight.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline catamscott
« Reply #52 on: Thu, 16 August 2018, 12:57:38 »
see:
Will the brass have some kind of coating to protect it from getting a patina?
And is it possible to get a different color plate and insert color?
no coating and not possible
you could, however, get a separate aluminum or brass plate, or get a brass weight.
Offline BestShuckleNA
  • はあちゃまっちゃま~!
« Reply #53 on: Thu, 16 August 2018, 15:35:27 »
Any pictures of MAO white vs ecoating white?
Offline Jkush463
« Reply #54 on: Thu, 16 August 2018, 16:38:07 »
as he sated above in comments no.
Offline itskuroi
« Reply #55 on: Thu, 16 August 2018, 16:45:22 »
Can compare the electrocoated white case vs. the plate/insert on the yellow case, since that's MAO white.
Offline bminhz
« Reply #56 on: Thu, 16 August 2018, 17:38:28 »
Can we see some red samples?
Offline senter
« Reply #57 on: Thu, 16 August 2018, 22:49:53 »
Offline vtachkov
« Reply #58 on: Thu, 16 August 2018, 22:56:02 »
Wow that's like actual white unlike the greyish color that MAO is closer to. Sign me up Senter.
Offline Pell99
« Reply #59 on: Fri, 17 August 2018, 03:14:07 »
Is it compatible with Time tkl PCB?
Offline s3vv4
« Reply #60 on: Fri, 17 August 2018, 07:08:37 »
Thats so white, wow. How durable is ecoating?
Offline senter
« Reply #61 on: Fri, 17 August 2018, 07:34:06 »
I'll receive the color samples tomorrow.
Offline senter
« Reply #62 on: Fri, 17 August 2018, 07:37:30 »
Yes, Time TKL PCB can fit into leaf 80 housings
Offline senter
« Reply #63 on: Fri, 17 August 2018, 13:06:44 »
same level as anodizing. E-coating is widely used on vehicles and has been proved durable.
Offline parityb1t
  • 60% or less \m/
« Reply #64 on: Fri, 17 August 2018, 13:14:22 »
Is there no option for gradient plate?
Alps64 w/ Orange Alps | SatanGH60 Gartistotles
Offline senter
« Reply #65 on: Fri, 17 August 2018, 13:41:37 »
no, since the plate won't be that noticeable after you put the caps on.
Offline senter
« Reply #66 on: Sat, 18 August 2018, 10:45:16 »
Green prototype
Offline oumakavoula
Re: [GB] Fox Lab Leaf 80 - updated with green proto
« Reply #67 on: Sat, 18 August 2018, 11:00:27 »
hot damn
Offline Jkush463
« Reply #68 on: Sat, 18 August 2018, 11:37:15 »
ooo das nice
Offline s3vv4
« Reply #69 on: Sat, 18 August 2018, 12:46:29 »
That looks to fit very well to the hyper fuse origins green
« Reply #70 on: Sat, 18 August 2018, 18:01:11 »
nice
Offline bciamny
« Reply #71 on: Sat, 18 August 2018, 20:13:57 »
can we get a few shots of the weight? the shot of the green proto makes it seem like the weight may have a variable depth to it.
Offline bthezebra
« Reply #72 on: Sun, 19 August 2018, 00:06:09 »
Just noticed that after you pointed it out, looks like something similar to the tkl no. 1 except that it is not also part of the plate or an outside accent to the board.
Offline senter
« Reply #73 on: Sun, 19 August 2018, 03:03:33 »
Offline senter
« Reply #74 on: Sun, 19 August 2018, 03:05:10 »
Red prototype is finished as well
Offline MxBlue
  • buy my keyboard
Re: [GB] Fox Lab Leaf 80 - updated with green and red proto
« Reply #75 on: Sun, 19 August 2018, 03:16:06 »
Love the colour selection, gotta have a picture of all of them together too! :D
Offline oumakavoula
« Reply #76 on: Sun, 19 August 2018, 03:27:21 »
one does one even chose from all of those ...
Offline lovetree
« Reply #77 on: Sun, 19 August 2018, 05:06:45 »
Hi, Senter.
Is this the same color of TIME TKL's Opera Red?
Offline senter
« Reply #78 on: Sun, 19 August 2018, 10:14:06 »
Hi, Senter.
Not exactly the same color but close.
The blasting media used on Leaf will be finer to achieve a smoother finish. The finish also affects the color.
Offline Jkush463
« Reply #79 on: Sun, 19 August 2018, 10:38:04 »
my lord you are truly making it hard to not get another in red.
Offline spyruf
« Reply #80 on: Sun, 19 August 2018, 15:24:04 »
Great price! Could you take photos with Cherry profile caps on?
Will update photos in OP
Could you add these? I want to see how deep the caps sit before I purchase.
Offline kiwon0905
« Reply #81 on: Sun, 19 August 2018, 17:47:50 »
Does the pcb support north facing or south facing leds?
Offline Tree_
« Reply #82 on: Sun, 19 August 2018, 18:57:29 »
No pink? Figured it was going to be an option given it was in the IC renders.
Offline MxBlue
  • buy my keyboard
« Reply #83 on: Sun, 19 August 2018, 18:59:16 »
I suspect that was a play at a pastel red.
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #84 on: Sun, 19 August 2018, 19:14:53 »
Any chance you could make a custom silver-colored Leaf? I'd be willing to pay a lot extra.
Also, will the WKL Alps plate support traditional alps stabilizers or only cherry?
« Last Edit: Sun, 19 August 2018, 19:32:24 by GeneriksGiraffe »
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
« Reply #85 on: Sun, 19 August 2018, 19:23:27 »
Which one is which? Is the one on the left the ecoating?
Offline MxBlue
  • buy my keyboard
« Reply #86 on: Sun, 19 August 2018, 19:26:02 »
Yep, e-coating on the left, MAO on the right.
Offline lovetree
« Reply #87 on: Sun, 19 August 2018, 21:14:22 »
Hi, Senter.
Thank you for the information, Senter.  :thumb:
« Last Edit: Sun, 19 August 2018, 21:15:58 by lovetree »
Offline loud_asian
« Reply #89 on: Mon, 20 August 2018, 04:15:31 »
Is the plate/pcb compatible with other TKLs? I'd love to pick up an extra alps plate and pcb for my Mira or KE80.
Offline senter
« Reply #90 on: Mon, 20 August 2018, 16:00:35 »
haven't found a GMK set to match the case color but there's a photo if you're only concerned about the depth caps can sit
Offline senter
« Reply #91 on: Mon, 20 August 2018, 16:03:34 »
south facing leds
Offline senter
« Reply #93 on: Mon, 20 August 2018, 16:08:11 »
I don't have the dimensions of other TKLs. I can share the dimension files for both plate and pcb if you need.
Offline loud_asian
« Reply #94 on: Tue, 21 August 2018, 03:05:49 »
Could you post the dimensions of the plate and PCB?
The plate I have right now is 129.5mm x 351.5mm
Offline kawasaki161
« Reply #95 on: Tue, 21 August 2018, 04:55:11 »
If this PCB is the same size as the Time TKL one it will fit almost any common TKL, the Time TKL PCB fits the LZ CLS
Offline bthezebra
Re: [GB] Fox Lab Leaf 80 - last 4 days to join!
« Reply #96 on: Tue, 21 August 2018, 08:04:40 »
I am unfamiliar but would it also fit a TX keyboard?
Offline kawasaki161
« Reply #97 on: Tue, 21 August 2018, 09:15:15 »
Yes
Offline senter
« Reply #98 on: Tue, 21 August 2018, 12:35:59 »
The screw hole positions are different. For PCB dimensions you can refer to the file I attached.
Offline vonswoopington
« Reply #99 on: Tue, 21 August 2018, 18:56:42 »
Okay I really want the yellow but I can't figure out which caps would work with it besides Godspeed (which I don't have). If you're getting yellow what are you pairing it with?
I've got:
GMK Terminal (R2 soon)
GMK Plum
GMK Laser
GMK Coniferous
GMK Metaverse (in gb)
SA Pulse (recent MD gb)
SA Carbon
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
