Author Topic: [GB] CA66 Custom Keyboard Kit Round 2 (Shipping Now)  (Read 363475 times)
Offline PlayKeyboardTW
    • Shop
Re: [GB] CA66 Custom Keyboard Kit Round 2 (GB starts!)
« Reply #150 on: Thu, 30 August 2018, 10:23:20 »
Just for clarification purposes as I'm on the fence on buying either another CA66 or just an extra pcb:
The default pcb now supports programmable RGB LEDs, correct? The previous pcb wasn't programmable, just a light strip, if I remember it correctly.
How is the USB-C connector on YANG's BT pcb? I understand it's not on a daughter board so how is the fit when not using BT and using the USB-C connector instead.
Reeeally interested in that white CA66, even though I already have the luxurious dark red since last round. :cool:
It's still RGB LED strip, following animations that TMK and QMK provide.
BT PCB still has a daughter board, same as the default one. ;)
Offline Lyle88
« Reply #151 on: Thu, 30 August 2018, 22:23:46 »
I'm looking for people's opinions:
I'm unsure whether to buy the black or white case.
If money was no object I would buy the black case and buy SA troubled minds r2, but that's probably a bit much..
I have SA Carbon but I'm missing the modifiers extension so unless I can find it on mechmarket (unlikely) I may not be able to use it..
I'm thinking the easiest option might be to buy the white case and pick up a set of DSA Honeywell caps.
Has anyone seen photos of DSA profile caps on the CA66?
If they look alright I will get a white case, otherwise I'll get a black one and keep my eyes open for something in SA profile..
Offline cijanzen
« Reply #152 on: Thu, 30 August 2018, 22:34:38 »
The white case is much more unique and would pair nicely with many sets. That gets my vote!
Offline fo0jin
« Reply #153 on: Fri, 31 August 2018, 03:58:15 »
I have a little problem with my RGB strip. After I flashed my hex, I can't change the RGB anymore. It stays stuck on the flashing mode. Any help would be appreciated :)
Offline dondongler
  • Gotta Light?
« Reply #154 on: Fri, 31 August 2018, 20:21:19 »
I bought in a few days ago and want to add a brass plate to the order. Is it possible to bundle this shipping with the rest of the board so i don't have to pay additional post?
    • Shop
« Reply #155 on: Fri, 31 August 2018, 20:36:39 »
Hi, please send us an email directly for adding items. :thumb:
Offline Lyle88
« Reply #156 on: Sat, 01 September 2018, 07:16:04 »
I decided on the white in the end, I'm hoping I can either find the missing keys for my SA Carbon set, or sell them and look for a set of Honeywell keys that have the correct size mods. YEEET!
Offline Vizir
« Reply #157 on: Sat, 01 September 2018, 11:01:40 »
When does the group but end, ie. Is Sept 5th included? And which time zone? I am traveling and will be returning sometime on the 4th... Central US time. Want to make sure I don't miss this GB.
Offline Lyle88
« Reply #158 on: Sat, 01 September 2018, 17:02:13 »
Why not just join now rather than chance it?
    • Shop
« Reply #159 on: Sat, 01 September 2018, 22:05:12 »
It'll be PDT. Won't be too accurate so you might have some extra time to join. :p
Good saying hahaha :D
Offline soakedcardinal
« Reply #160 on: Sun, 02 September 2018, 21:18:12 »
I apologize if this has been answered before, but will it be possible to git an alps plate in place of the default plate at no extra cost? I don't need two :thumb:
Thanks
Offline cijanzen
« Last Edit: Sun, 02 September 2018, 21:29:48 by cijanzen »
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
« Reply #162 on: Sun, 02 September 2018, 23:09:05 »
When ordering spare parts how would we select colors for aluminum plates (both regular and alps)? There isn’t an option to select plate colors. Should we make a note somewhere?
    • Shop
« Reply #163 on: Mon, 03 September 2018, 01:01:08 »
Thanks
Sorry to say no. :-X
Would this battery: https://m.aliexpress.com/item/32820875729.html?pid=808_0000_0101&spm=a2g0n.search-amp.list.32820875729&aff_trace_key=6a61fd7838f946c4bc418407ca8645d1-1495827122980-06676-F233fuf&aff_short_key=F233fuf&aff_platform=msite work and do I need anything else like a connector? If I need a connector what should I look for?
You'll need a connector if you want to plug in/out easily. The size will be 1.25mm, 2 pin.
Or you can just remove the receptacle on PCB and solder wires in holes instead.
We already realized we missed the color choosing parts for both plates.
It's a bit complicate for setting up the page and we don't think change it during GB period is a good idea.
So we'll send emails to order owners for checking everyone's choice of colors.
Sorry for causing any inconvenience. :(
Offline konstantin
  • Formerly constexpr
« Reply #164 on: Mon, 03 September 2018, 07:27:01 »
Can you post a pic of the gold anodized alu plate? Preferably next to a brass plate so I can see how different they are.
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #165 on: Mon, 03 September 2018, 07:50:40 »
Seconded.
Offline cijanzen
« Reply #166 on: Mon, 03 September 2018, 10:03:54 »
Thanks
Sorry to say no.
Thank you for the clarification on the connector! Can you tell me why the battery in the PCB shot in the IC post has 5 pins? What do the other 3 pins do?
Edit: never mind. I just realized I was looking at the connector for the daughter board and thinking it was for the battery. My bad.
« Last Edit: Mon, 03 September 2018, 10:07:58 by cijanzen »
Offline jrfhoutx
« Reply #167 on: Mon, 03 September 2018, 10:18:57 »
[/quote]
No inconvenience really, thanks for the clarification!
Offline Rumblehotep
« Reply #168 on: Mon, 03 September 2018, 16:13:10 »
I just realized I forgot to grab an extra BT pcb with my order (#1134), would there be a way to add one in?
Also will the extra parts stop sale on Sep 5 as well?
« Last Edit: Mon, 03 September 2018, 16:20:55 by Rumblehotep »
    • Shop
« Reply #169 on: Mon, 03 September 2018, 22:18:14 »
Please send us an email for adding it to your order. :thumb:
Offline slxdegrees
  • Nerds With Keebs
« Reply #170 on: Mon, 03 September 2018, 22:19:21 »
How different is the gold alu plate from the brass plate? Any pictures?
    • Shop
« Reply #171 on: Mon, 03 September 2018, 23:18:40 »
Sorry for missing to reply your question.
Very much different. Gold alu plate is sandblasted, and brass will be mirror-like.
202915-0
Offline vonswoopington
« Reply #172 on: Tue, 04 September 2018, 00:44:36 »
Is that the grey blue color?
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
« Reply #173 on: Tue, 04 September 2018, 00:46:37 »
I could not resist. Ordered one CA66 in Grey with Titanium Badge and BT PCB....
With these sets do you think I am right?
My sets:
- SA Oblivion
- SA Calm Depths (whenever it appears on sight)
- SA 1965
- SA Pulse
- SA Jukebox
- SA Modern Selectric Black
- SA Hyperfuse
- SA Cabon
- SA Solarized Dark
White is heavy on me also... very nice also.
Similar I have a Black Exent, and Norbaforce is Grey also... I know I tend to grey colours in my keyboards... but I saw Oblivion in a Grey one with Ti badge and WOW!
Also, why buying anymore PCB or plates? From my other builds those tend to be left in boxes with nothing to say... may be I miss something?
Sent from my iPhone using Tapatalk Pro
Filco TKL Ninja Blues / CODE Greens / Pok3r Clears / HHKBpro2 / RF 87U 55g / Novatouch TKL / KC60 Clears / SSK and also regular Model M
    • Shop
« Reply #174 on: Tue, 04 September 2018, 01:12:46 »
Yes, the light was a bit too much.
Grey blue is a very hard one to shoot it right imo. :))
My sets:
- SA Oblivion
- SA 1965
- SA Pulse
- SA Jukebox
- SA Hyperfuse
- SA Cabon
- SA Solarized Dark
Some people buy them for spare parts. You can have two kinds of builds by swapping them easily. :))
Offline roymt76
« Reply #175 on: Tue, 04 September 2018, 05:45:03 »
you miss my question :(
Ordered <3
Sadly that i'm think about case color again
You guy have any image compare gray and black, in the same picture
Offline cijanzen
« Reply #176 on: Tue, 04 September 2018, 07:19:15 »
My sets:
- SA Oblivion
- SA 1965
- SA Pulse
- SA Jukebox
- SA Hyperfuse
- SA Cabon
- SA Solarized Dark
Grey or white would work with most of those sets but I think grey would win out. Jukebox would benefit most from white but most of the rest would either look better with grey or equally as good.
Offline slxdegrees
  • Nerds With Keebs
« Reply #177 on: Tue, 04 September 2018, 08:02:41 »
Nice, seems like the gold alu is more muted. Hmm what time on Sep 5th does the GB close by the way?
    • Shop
« Reply #178 on: Tue, 04 September 2018, 08:04:29 »
Ordered <3
lol sorry. :confused:
I didn't have a chance for shooting photos to compare them myself. Most cases were shipped directly from China. ^-^
Black is just a bit darker then dark grey, for satisfying some guys' desires.
PDT. But we'll extend a bit to 6th for everyone to join in time. :thumb:
Offline Troif
  • Carpe Diem!!!
    • Daniel Ferrer
« Reply #179 on: Tue, 04 September 2018, 08:54:44 »
My sets:
- SA Oblivion
- SA 1965
- SA Pulse
- SA Jukebox
- SA Hyperfuse
- SA Cabon
- SA Solarized Dark
Thanks for answering. I am torn between both but, as always, grey is winner. In this case even more for the speciality of the case itself.
Offline bcbishop
« Reply #180 on: Tue, 04 September 2018, 15:03:27 »
Love my grey CA66 from the last round, and just placed an order for a white CA66 from this one! Looking forward to pairing it with Symbiosis (and Godspeed)!  :D
Offline cijanzen
« Reply #181 on: Tue, 04 September 2018, 15:04:04 »
Gonna look so good!
Offline theo313
« Reply #182 on: Tue, 04 September 2018, 16:56:25 »
Anyone else having a hell of a time choosing which color? So torn between Black and White that I am considering splitting the difference and going for Grey. Help!
Offline cijanzen
« Reply #183 on: Tue, 04 September 2018, 17:00:28 »
What kits are you planning on using?
Offline theo313
« Reply #184 on: Tue, 04 September 2018, 17:37:33 »
The only notable kit I have coming is the GMK Space Cadet, but I wasn't planning on putting that on the CA66. I really like SA Oblivion so I'm looking for something with muted off-white or grey in the same vein. I have been toying around with Miami Nights since last night in my head  :cool:
Offline silversung
« Reply #185 on: Tue, 04 September 2018, 18:23:35 »
Ordered! Had to wait a while because of monies issue, but finally I'm in. Yay!
Offline cijanzen
« Reply #186 on: Tue, 04 September 2018, 18:28:29 »
Based on the kits you just mentioned I’d probably go with black
Offline Vizir
« Reply #187 on: Tue, 04 September 2018, 20:47:40 »
thinking of getting dark grey, but asking anyway. which color goes with modern dolch? /dev/tty beige/rgb?
edit: is this dark grey?
https://i.imgur.com/7WY5HqU.jpg
https://i.imgur.com/1Hmii7X.jpg
« Last Edit: Tue, 04 September 2018, 21:02:48 by Vizir »
Offline cijanzen
« Reply #188 on: Tue, 04 September 2018, 21:31:01 »
They’re just renders but looks like grey to me. I’d also recommend grey based on your sets.
Offline Vizir
« Reply #189 on: Tue, 04 September 2018, 22:38:29 »
order in. dark grey/red/BT WKL + brass plate. was a tough decision between hhkb and wkl, but in the end, the extra key won.
    • Shop
« Reply #190 on: Wed, 05 September 2018, 01:16:11 »
Love! They will definitely shine together. :thumb:
I can totally understand the feeling. :))
Thanks! ;D
Yes these are dark grey. Thanks to Janglad. :thumb:
Cheers! ;D
Offline DePulse
« Reply #191 on: Wed, 05 September 2018, 01:40:24 »
Hey PlayKeyb! I sent you a message. Kindly check your email  :D Thank you!
Offline ctrl
« Reply #192 on: Wed, 05 September 2018, 02:22:30 »
The default pcb is compatible with the brass plate from last round, right?
    • Shop
« Reply #193 on: Wed, 05 September 2018, 05:33:47 »
Okay! :thumb:
Yes they do. ;D
Offline ctrl
« Reply #194 on: Wed, 05 September 2018, 06:36:40 »
Yes they do. ;D
Great! I ordered two. Just in case my soldering messes something up. ;D
Could you give a breakdown of the major differences between this pcb compared to the previous round? I've picked up bits and pieces in the threads here and there, but it'd be really nice to just see a list. :)
    • Shop
« Reply #195 on: Wed, 05 September 2018, 10:39:45 »
Yes they do. ;D
The major differences are:
  • USB C to C supports
  • In switch LEDs IC pin out fix
  • RGB LED strip raised a bit for avoiding light leaking
Thanks for joining! :thumb:
    • Shop
Re: [GB] CA66 Custom Keyboard Kit Round 2 (Last day to join!)
« Reply #196 on: Wed, 05 September 2018, 10:42:52 »
Last day to join guys!
We refunded some extra parts orders which chose the wrong shipping method.
Please help us check you email and account status.
If you are still fancy getting these parts, place a new order with choosing DHL Express for shipping.
We appreciate it. :thumb:
Offline slxdegrees
  • Nerds With Keebs
« Reply #197 on: Wed, 05 September 2018, 11:15:13 »
Is it possible to underdeclare the value so we don't get taxed at customs? 7% or whatever VAT of the total value is painful T.T
Offline jrfhoutx
« Reply #198 on: Wed, 05 September 2018, 11:37:49 »
Will the BT plate .dwg files be made available after the buy is over?
Offline roymt76
« Reply #199 on: Wed, 05 September 2018, 11:44:30 »
Yes, it is
He say that in these previous page
