Author Topic: [GB] CA66 Custom Keyboard Kit Round 2 (Shipping Now)  (Read 362288 times)
Offline vonswoopington
Re: [GB] CA66 Custom Keyboard Kit Round 2 (GB starts!)
« Reply #50 on: Fri, 17 August 2018, 12:45:56 »
This is tough. If you are getting white, which keycaps are you going to use? I'm thinking of using Metaverse.
Metaverse would work pretty well. In my opinion anything with white alphas and non-white mods would look good.
True good point. Now I wish I went in for Serika.
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline befbef
« Reply #51 on: Fri, 17 August 2018, 13:41:17 »
I think space cadet would look great on white. Guess I'll try that or Maxkey Ashen on white or grey... or black...or silver.
Offline Mr_BeastQuake
    • Reddit
« Reply #52 on: Fri, 17 August 2018, 14:07:06 »
Always looking so good. if there was a board to get me to buy MX. . . it has me thinking.
Offline cijanzen
« Reply #53 on: Fri, 17 August 2018, 15:34:10 »
Just ordered this telephone cord I'm going to modify for use with the dark red CA66!
202131-0
Offline dondongler
  • Gotta Light?
« Reply #54 on: Fri, 17 August 2018, 15:46:14 »
What color is going to match my taro set the best? I was thinking gray blue may look gud but im not sure.
Offline kf1246
« Reply #55 on: Fri, 17 August 2018, 16:21:50 »
What stabs are intended to be used on the ALPS plate? ALPS style? If so, one should be able to use Matias or Costar stab inserts to put SP ALPS caps on this board, right?
Offline aslanxdeft
« Reply #56 on: Fri, 17 August 2018, 17:12:44 »
Is there any difference between the BT PCB and the normal one, other than the BT functionality? Also what kind of stabilizer and switches (PCB or platemount) do I need?
Offline PlayKeyboardTW
    • Shop
« Reply #57 on: Fri, 17 August 2018, 18:27:03 »
A bluetooth switch between Tab and Q
Just confirming, we will need to take of keycaps each time we turn on/off bluetooth?
[/quote]
You can use a toothpick to switch it. :))
Or you might consider not to switch it off, it's very very efficient (without lightning).
We'd love to see some new combination here as well. :eek:
Still a long time to consider. ;D
    • Shop
« Reply #58 on: Fri, 17 August 2018, 18:32:28 »
Wow all red huh! :eek:
Dark grey or black imo.
Yes! They are pretty like how KBP keyboards do.
Alps switches supporting is only in BT PCB. If you are planning to use Mx switches then no bother.
Both PCB and platemount switches work. PCB stabilizers are needed. :thumb:
Offline farfar
« Reply #59 on: Fri, 17 August 2018, 19:03:33 »
Aaaaaaaaaaaaand I can't join cuz I wasted 1000$ on golf  :-X
Hopefully I can get one on MM sometime later, because the CA66 is a beauty!
GL with the GB though! :D
Offline upintheclouds
« Reply #60 on: Fri, 17 August 2018, 20:52:38 »
You both think the purple is too much? It matches the Taro mods so well.
Offline cijanzen
« Reply #61 on: Fri, 17 August 2018, 20:56:13 »
I think purple would look nice. I can’t remember which page but someone did a rough mock-up of the purple with taro in the previous gb thread.
Offline roymt76
« Reply #62 on: Fri, 17 August 2018, 22:06:40 »
I'm considering about Black and gray one :(
Do you have any comparison between those two.
https://imgur.com/a/PcfAP
which one is black, which one is grey, there is too much filter on these photo that made me hard to imagine the different
Offline cijanzen
« Reply #63 on: Fri, 17 August 2018, 22:08:27 »
If I’m not mistaken those are all grey (except the purple) as the shots are from R1 and they had not made a black one yet at that time.
Offline JDragon
« Reply #64 on: Fri, 17 August 2018, 22:12:38 »
If we just want a BT PCB/plate, is it still 45 shipping? Would love to add BT to my R1 CA66.
    • Shop
« Reply #65 on: Sat, 18 August 2018, 00:49:21 »
Oh I know that one! Yeah purple might be great as well!
No, it will be calculated separately. You can choose 2 kinds of shipping when checking out. :thumb:
Offline roymt76
« Reply #66 on: Sat, 18 August 2018, 01:01:34 »
So all the picture in that link is gray right ?
it darker than i imagine
    • Shop
« Reply #67 on: Sat, 18 August 2018, 01:20:20 »
Yes it's our commercial grey. That's why we call it dark grey. :eek:
Offline macken
« Reply #68 on: Sat, 18 August 2018, 04:49:27 »
Don't now if this has been asked before, but how white is the white option? Is it plain white or off-white?
In the pictures on the site it looks similar to the silver option.
    • Shop
« Reply #69 on: Sat, 18 August 2018, 06:58:00 »
Milk white. The silver is still with a bit grey as you can see in pics. :)
Offline boxfrommoon
« Reply #70 on: Sat, 18 August 2018, 07:09:19 »
I too would like to know. I have been thinking that this would finally be the board to put my gmk 9009 on. That's why I would actually prefer off-white over pure white.
Sent from my ONEPLUS A5000 using Tapatalk
EDIT: Milky white actually sounds really good also!
Offline Tordp
« Reply #71 on: Sat, 18 August 2018, 08:03:01 »
This cable is a perfect match with Dark Red. Are you going to replace the RJ45s with USB connectors? You have enough wires for that inside the cable?
Offline cijanzen
« Reply #72 on: Sat, 18 August 2018, 08:35:16 »
Because I’m only doing USB 2.0 specs it only requires four connections so just enough to work. Still sourcing my USB connectors but Zap cables has them for example.
Offline coffeeshopcoder
« Reply #73 on: Sat, 18 August 2018, 14:37:44 »
I'm thinking I'll do either the grey blue / drak grey or black  (not sure which caps go well with it - I have nautilus, SA Carbon, SA Foundation, 9009, DSA Royal Navy and XDA Canvas ). I should have gotten in on Serika :(
I want to do a unique color, for such a nice case, which is why I'm thinking grey blue. thoughts ?
Offline cijanzen
« Reply #74 on: Sat, 18 August 2018, 14:42:29 »
The blue is really nice and unique and definitely goes well with Nautilus or neutral sets like 9009. That’s my vote for you!
« Reply #75 on: Sat, 18 August 2018, 14:44:53 »
On a separate note, I'm also wanting to try alps, I have some alps switches coming in from NovelKeys .
I'm thinking getting two PCBs and Plates - Alum ALPS/Blue-tooth PCB pair as well as a Brass Plate/Wired PCB pair for MX.
Question :
-- Is the default alum plate mandatory, can I switch that with an alum alps plate ? (can I pay the difference in price for the alps plate)
-- what stabs and caps will work ? I see stabs on the Mathias site, and caps on mechanicalkeyboards.com, would those work ?
« Reply #76 on: Sat, 18 August 2018, 16:04:18 »
Yah I'm zero-ing in on the blue... BTW, GMK Jamon might go well with your dark red as well.. if that happens to be run that is...
Offline cijanzen
« Reply #77 on: Sat, 18 August 2018, 16:39:25 »
Yeah, I’ve mocked up Jamon and Royalty and the bright red mods on Jamon just don’t do it for me. It still looks very nice though!
Offline ye_cole
« Reply #78 on: Sun, 19 August 2018, 06:29:53 »
the build you have planned seems ****ing dope and i cannot wait to see it
« Last Edit: Sun, 19 August 2018, 06:50:02 by ye_cole »
Offline cijanzen
« Reply #79 on: Sun, 19 August 2018, 08:20:47 »
Thanks! I will definitely be sure to share. I think your Royalty set will really pull it together nicely. I just hope it happens sooner than later!
Offline dondongler
  • Gotta Light?
« Reply #80 on: Sun, 19 August 2018, 09:57:54 »
Awesome thank you. I'll probably go purple and switch between my taro and laser sets.
Offline pixelpusher
« Reply #81 on: Sun, 19 August 2018, 14:23:27 »
I don't see a way to configure for WKL version on this site:
http://ydkb.io/
Am I overlooking something?
Offline Oatburner
« Reply #82 on: Sun, 19 August 2018, 16:05:10 »
I have a round 1 CA66 and am interested in getting a Bluetooth pcb for it. Could someone confirm that the new plates and PCBs will support the round 1 cases?
Offline cijanzen
« Reply #83 on: Sun, 19 August 2018, 16:06:44 »
Yep they’re the same!
Offline Vizir
« Reply #84 on: Sun, 19 August 2018, 16:29:49 »
What are the dimensions of the board? I am planning to get a carrying case for it.
Offline Ephemeral
« Reply #85 on: Sun, 19 August 2018, 18:04:17 »
This info is from the IC thread
365mm x 168mm, 1365g with SA keycaps approximately
Collection:
E6.5 (Lubed 50g MX Blacks) | Preonic (55g MX Clears) | CA66 (Zealios V2 65g) | budget96 (MX Red) | Infinity 60% (Zealios 78g) | Phantom TKL (Gateron Black) | MiniVan (Zealios 78g) | Helix (?)
[Incoming: Polaris (?) |  KBDFans 8X Mk II (v2 Tealios)]
Offline Vizir
« Reply #86 on: Sun, 19 August 2018, 18:51:30 »
Thanks
    • Shop
« Reply #87 on: Sun, 19 August 2018, 20:31:13 »
http://ydkb.io/
Here, need to mark up this option. ;)
202236-0
Sure they fit R1 cases. :thumb:
Thanks
Thanks for helping! :-*
Offline MisterKnife
« Reply #88 on: Mon, 20 August 2018, 01:50:55 »
qq does the bluetooth version of the PCB also come with usb-c?
Offline typischt
« Reply #89 on: Mon, 20 August 2018, 01:53:15 »
Is there a reason, that, according to the site, you have to pick the more expensive shipping methode?
    • Shop
« Reply #90 on: Mon, 20 August 2018, 03:06:41 »
Yes.
Because all CA66 stuffs are packaged and shipped in factory directly, which is located in CN.
They are not going to be shipped to TW first.
We have a guy supervise and QC there, so TW post is not available. ;)
« Last Edit: Mon, 20 August 2018, 03:10:27 by PlayKeyboardTW »
Offline typischt
« Reply #91 on: Mon, 20 August 2018, 03:08:34 »
Because all CA66 stuffs are packaged and shipped in factory directly. They are not going to be shipped to TW first.
Okay, perfect, thanks for the fast response!
    • Shop
« Reply #92 on: Mon, 20 August 2018, 03:13:34 »
Thanks for the understanding. We did have a debate for how to ship individual extra parts orders.
Sorry for making DHL Express the only option. We promise to keep this round as smooth as last one. :thumb:
Offline mushubanane
« Reply #93 on: Mon, 20 August 2018, 16:10:14 »
Anybody who has the CA66 from the first round can tell us about the status of their "CA66" badge? Does it take dirt easily and does it look bad with it? Or does it look even better a bit worn out  :) ? Struggling hard with the WKL version.
Offline fer.real
« Reply #94 on: Mon, 20 August 2018, 16:28:40 »
I have one from the last round.  The badge is still as shiny as the day I got it.
Offline teh_pengers
« Reply #95 on: Mon, 20 August 2018, 16:32:50 »
Are there any pictures of the plate colors other than the brass?
    • Shop
« Reply #96 on: Mon, 20 August 2018, 21:43:27 »
It's coated, don't worry. ;)
Good to hear that! :thumb:
Sorry, forgot to take photos for all alu plates. :'(
You can find them in last GB thread, starting on page 13 I think.
Offline mushubanane
« Reply #97 on: Tue, 21 August 2018, 03:34:06 »
Reassuring then  :thumb:
While I'm at it, anybody has a picture of a non-purple CA66 with SA Hyperfuse? I'd like to have a more polyvalent case than purple but can't decide which one  :rolleyes:
Offline roymt76
« Reply #98 on: Tue, 21 August 2018, 03:53:26 »
i want to see non-purple Ca66 with SA hyperfuse too :D
I have one new set and didnt use it yet
Offline Taques
« Reply #99 on: Tue, 21 August 2018, 17:59:02 »
Struggling with choosing a color :confused:
I'll have SA Symbiosis, SA Godspeed, SA Carbon, and SA Pulse that I would like to use on it. Maybe silver might be the best color choice for these sets?
