Author Topic: Kalih Choc Switch Kicad Footprints  (Read 7810 times)
Offline Aydenvis
  • Mistakes have been made.
« on: Mon, 20 August 2018, 20:46:44 »
Where can I find some? Are they even different from the Cherry MX footprints?
Offline fpazos
Re: Kalih Choc Switch Kicad Footprints
« Reply #1 on: Tue, 21 August 2018, 07:55:47 »
Yes It's different. I don't know if there are kicad footprints but you can check the specs sheet in kailh website
Offline DiodeHead
« Reply #2 on: Tue, 21 August 2018, 13:11:03 »
https://www.dropbox.com/s/wj7h7r838r9ai6a/kailh_low.kicad_mod?dl=0
there you go with all my love :P, it has no led yet if anyone can tell me wich footprint the led uses I can add it, I would make a test PCB first if you're really going to use it in a project, since I have no khail low profile I can't test it myself.
by the way, made with kicad 5, you should really update if you're not on version 5.
hope it helps :)
Offline Aydenvis
« Reply #3 on: Tue, 21 August 2018, 19:11:20 »
@DiodeHead
Thanks, I'll try it and see how it works out.
Offline DiodeHead
« Reply #4 on: Wed, 22 August 2018, 01:24:59 »
no problem, if you see any errors tell me so i can modify the footprint :)
Offline regack
« Reply #5 on: Wed, 22 August 2018, 21:03:51 »
I've attached an older Kicad footprint that has the cutout space for the LED marked on silkscreen.  I had some of these made, they worked fine, even if I never finished my project.   I used 0603 LEDs and there was lots of room to spare within the cutout.
For reference:
I'm not on Kicad 5  :(
« Last Edit: Wed, 22 August 2018, 21:24:41 by regack »
Offline marhalloweenvt
« Reply #6 on: Wed, 22 August 2018, 21:43:15 »
For reference:
Your PCB look so fantastic. Can u share your work? I want to know what is 3 ics (they are the same, right?) on your PCB
Offline DiodeHead
« Reply #7 on: Thu, 23 August 2018, 01:25:05 »
thanks :) I'll add the led then, I would bet those IC are for driving the LEDs, I'm curious too, do you have any links to your project ??
thanks.
Offline regack
« Reply #8 on: Thu, 23 August 2018, 08:54:57 »
I haven't posted anything about it, I was thinking about starting a thread, in general, maybe I'll do that when I get some time, rather than clogging up this thread :)
Those are 74hc138 3-8 decoder/demux, I was trying to keep the controller small and narrow using an atmega32u2, but I needed more pins.
Offline DiodeHead
« Reply #9 on: Thu, 23 August 2018, 09:56:19 »
ouch T_T my module was made with love, but not accuracy, I did mine backward.
Yeees post something, only a couple of pictures and the kicad files can help other people learn (me included doing footprints backward ¬¬)
regards :)
Offline regack
« Reply #10 on: Thu, 23 August 2018, 22:26:30 »
regards :)
Here we go : Failed Experiments : https://geekhack.org/index.php?topic=97113.msg2652203
