Author Topic: Few questions about things I need for my build... :)  (Read 2979 times)
Offline Luciqueii
  • 【Luciquell & Co.】
« on: Sun, 26 August 2018, 07:37:34 »
Hello, everyone, I have ordered some parts for my 60% build, but there are some parts missing.
So for lubing is there special lubes I have to get for switches and stabs or any lubes does the jobs?
So I will provide some link from Sweden where I can buy them, can you guys tell me which one does work for switches? :)
1. https://www.kjell.com/se/sortiment/hem-kontor-fritid/kontorstillbehor/kemi-spray-lim/spray-olja-isopropanol
2. https://www.kjell.com/se/sortiment/hem-kontor-fritid/kropp-halsa/harvard/harklippare/smorjolja-till-hartrimmer-p62124
3. https://www.teknikmagasinet.se/produkter/aktiv-lek/vapen/soft-air-gun/tillbehor/crosman-pellgunoil
4. hahah this is made for sex idk it works?  ;D https://www.teknikmagasinet.se/sokresultat?q=glidmedel
So that was the links for lubs... I need to order a cable to my keyboard I ordered SATAN GH60,
So does the GH60 use mini usb or micro usb... a,b,c tell me please bcs I dont know and the part that will connect to my pc has to USB Type A? :)
I am a beginner so don't be surprised by those questions...  :)
Ty for the help in advance and have an awesome day!  :thumb:
Re: Few questions about things I need for my build... :)
« Reply #1 on: Wed, 29 August 2018, 15:40:32 »
Lets start with the easy question - you probably want an A to mini cable for most GH60 PCBs, but the satan version is a name given to many dodgy Chinese copies so hard to be sure.
As to lube you're lubing plastic not skin, so definitely not 4 :))  1 is a spray so that will probably make a big mess trying to get it on tiny switch stems!  There isn't a lot of text on the other links and I don't speak Swedish...
Generally speaking the only way to buy the lube we use in a keyboard compatible quantity is through a dedicated vendor, such as zeal or techkeys.
Offline Auslander
« Reply #2 on: Wed, 29 August 2018, 16:37:18 »
GH60 Rev A/B/C and Satan use USB A to Mini USB. The GH60 Satan is a good PCB aside from the switches being mounted upside down which prevent Cherry profile keycaps from reaching full travel.
HHKB JP | Realforce 104UB-DK | HHKB Pro 2
