Author Topic: PS/2 pcb  (Read 2070 times)
Offline Bjack795
PS/2 pcb
« on: Wed, 29 August 2018, 02:29:19 »
Hi all!
I need to make a keyboard with PS/2 port.
Searching on the web I didn't find any pcb with that port instead of standard USB one.
Can you help me?
(The dimensions are 60% or 75% keyboard)
Offline Sup
Re: PS/2 pcb
« Reply #1 on: Wed, 29 August 2018, 06:39:30 »
There is so far i know no 60% or 75% keyboard with a ps2 port. I think you have to do some deep research and frankenstein modding to a existing pcb.
current
Coming soon
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: PS/2 pcb
« Reply #2 on: Wed, 29 August 2018, 07:09:49 »
Yea agree with Sup, unless you wanna bust out a soldering iron and remove the mini-usb connector and reprogram and reflash the PCB, just get a passive converter that you put on the end of the USB cable
Offline Bjack795
Re: PS/2 pcb
« Reply #3 on: Wed, 29 August 2018, 07:35:14 »
Thank you both!
The problem of the passive adaptors is that are compatible in the 10% of the boards and I don't know if this is the case.
